Question about In Microwave Ovens
Moving tray in may tag over stove microwave has stopped moving
2 Suggested Answers
  • 1531 Answers
SOURCE: turntable not turning
you should be able to repair this your self the turntable motor is fairly easy to get to.it does sound as though your motor has gone bad.
Posted on Jan 31, 2010
Why does the microwave have the turntable keep moving/light stay on/keep vibrating whenever the door is closed?
< - contact me directly for free advice.
Remind me of your exact symptoms and the full model number from the tag in the cooking cavity or elsewhere on the oven.
May 10, 2014 | Sharp R-530ES Microwave Oven
GE spacemaker profile xl 1800 moving vent will not close
I'm betting your base model number is JVM1860, JVM1861, JVM1870, JVM1871, JVM3660, or JVM3670.
That's the automatic louver you're having trouble with. There are micro switches in the louver assembly which tell the controller when the louver is open or closed.
If one of those switches or the louver motor fails, the louver will not work correctly.
Did your cooktop lights recently fail?
Sometimes the surge from them shorting will cause damage to the circuit board, which can be repaired.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
There is a video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
May 03, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
Siemens HF26066GB plate is moving when door closed and not moving when open
Have a shop look at this---there usually is a recessed safety switch inside the jam that will prevent the unit from working with door open--sounds like the problem may be with it.
Nov 03, 2012 | Siemens HF26066GB 1000 Watts Microwave...
MICROWAVE STOPPED WARMING.
If the tray is moving and light is also on during the warming time .Then, its probably the transformer or the magnetron.
use DMM and check resistance of both .
If you find OL in any of the component then replace it and you should be okay.
NOTE MICROVAVE HAS CAPACITORS WHICH HOLD VERY HIGH CAPACITY CURRENT .IF YOU KNOW TO DISCHARGE IT THEN ONLY DO THE JOB.
THANKS
please rate my work
Sep 17, 2011 | Frigidaire Microwave Ovens
The round plastic tray is not moving, rotating and while I'm heating something there's a groaning noise?
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Nov 15, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Turntable not turning
Jan 31, 2010 | Dacor DCM24 Convection/Microwave Oven
Sharp Microwave Oven over stove fan goes on by itself
Please note that FixYa is not currently notifying us Experts when Clarification Requests are answered.
So please post a
NEW question, and please include your brand name and the full model number from the tag in or on the unit, as well as the answers to these questions:
Which fan is it?
The
internal cooling fan, which comes on automatically whenever the unit is microwaving?
Or the hood vent exhaust fan which you can turn on and off manually?
Or the convection fan, if it is a convection model?
When is it coming on?
Is it coming on whenever you cook on the stove top?
Thanks!
Oct 09, 2009 | Sharp R-1870 Convection/Microwave Oven
Remove a whirlpool over the range microwave oven
Jim here. In cabinet above microwave, locate 2 mounting bolts.
Place a box on the stove top to support the microwave once the mounting bolts are removed (you may wish to cover the box with a thick towel or small throw rug).
Procedure:
1. Unplug microwave.
2. Remove both mounting bolts from top of microwave (they secure it to the overhead cabinet).
3. With microwave front angled down onto box, pull some of power cord out of hole (to provide some moving space).
4. With microwave hand supported, remove box from stove top (a second set of hands would be helpful here).
5. HARD PART- detach top of microwave back from wall mounting plate by placing a hand under the bottom rear of the microwave and pushing up. (Wall mounting plate is screwed into the wall behind the microwave and provides both top and bottom support to the back of the microwave.)
6. Lower front of microwave until you can see about a 1-inch clearance between the top-rear of the microwave and the cabinet above it.
7. Firmly lift the microwave straight up and then bring forward. It should be free of the wall mounting plate.
Sep 30, 2009 | Maytag MMV4205 Microwave Oven
How do you remove a microwave above the stove
Take the glass tray out and unplug it. Remove the 2 or three phillips screws in the top of the cabinet going into the micro. They should be towards the front. Hold up on it while removing screws. When all screws are out, let it tilt forward and lift it up off of the hooks. Some require help, so be carefull and put blankets on your stove to set it on when it first comes out.
Apr 10, 2009 | Kenmore 63762 Microwave Oven
Microwave Ovens Logo
27 people viewed this question
Top In Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you an In Microwave Oven Expert? Answer questions, earn points and help others
