Question about Water Garden
Hi I have a north star power washer, motor runs but no pressure at all , no water at all seems like I have a clog somewhere
  • 2651 Answers
SOURCE: No water from dispenser
remove the crispers, youl find a water tank. chances are its frozen, somtimes thers a fitting right there to disconnect and try. IF not, it discharges from the left side of tank.Hold a hair dryer on that goose neck top portion of tank for a few minutes. water shloud start flowin now. if thats the case:::::
Order and install Water Reservoir Anti-Freeze Kit PN W10177505. Follow the instructions supplied with the kit.
Posted on Mar 14, 2008
  • 32 Answers
SOURCE: maytag neptune mah8700aww wont drain, spin or put water in
if you remove the oval cover in the back of the mach,you will find the pump.there are 2 hose clamps to remove.usually you will find change stuck in the pump.remove the screws on the bracket that holds down the pump and you can take the entire pump out...good luck
Posted on Sep 29, 2008
SOURCE: engine keeps shutting down
Most Honda engines have an oil pressure switch that prevents engine damage due to low/no oil pressure. Make sure there is sufficient oil in the engine and that the wire is connected to the pressure switch.
Posted on Jun 01, 2009
SOURCE: pressure washer not working
OK here is the solution. There are six plastic vaules inside the pump if you have any mechanical skills you can fix this.
These plastic valves melt when you leave your pressure washer running for a short period when you are not pressure washing. once this happens the pump becomes cloged and does not function. I spent alot of time and research on finding the parts for replacement. I called the main company of this washer pump and here is the toll free number
800-999-2245 and the web sight but to save time just call and talk to the service tech tell him you model number and he will give you the part number.
I only paid $13.75 plus shipping around $5.50 I do not work or have any intrest in this comapny but I tell you after all the frustration and run around I had trying to fix this Home depot power washer I deesided to help eveyone else out
I can be reached at if you have any other questions
Posted on Oct 02, 2009
  • 68 Answers
SOURCE: I want to remove the 4gpm pump on my pressure washer.
HI, It sounds like it is just stuck on the keyway as these can be very tight. You need to force the pump of evenly on either side and should come of if patient.
Posted on Feb 08, 2010
Testimonial: "I'm sure the answer is correct. Over time my use of harsh chemicals no doubt corroded the key-way."
I have a Husky power washer 2600 psi starts & runs until it seems to build Pressure and will not spray then motor boggs to a stall
Some models have a tiny orifice in the adjustable spray head.(if equipped) Which can become clogged by debris or calcium buildup. Water should flow through even when unit is off and sprayer handle(on/off) is operated if there is no water then you definitely have a clog.
Oct 31, 2013 | Garden
Have a honda gvc 160 power washer. It works ok for a while then loses all pressure. It seems as though when it is not running and the water is attached there is not as much water coming through. Is there a...
Sounds like the machine is not getting enough water.
Please check your water pressure to the machine and also the water inlet filter in case its a little dirty.
Jun 16, 2010 | Campbell Hausfeld PW2102 Gas Pressure...
Water does not come out of the lance when I squeeze the trigger
HI it sounds like you may just have a blocked jet on the end of your lance. Please remove and clean.
May 31, 2010 | Northstar Professional Series Pressure...
Oil grade and level in pump reservoir? Motor is shutting down, all else seems fine, assume is oil level. North Star with Honda GX340 - pressure washer.
15-40 there will be a fill mark that is easy to see when you remove the cap or it will have a dip stick
Second your oil pressure switch may be bad or have a bad connection
Mar 06, 2010 | Hardware & Accessories
North star petrol pressure washer. working fine, then no high pressure, checked water feed, water filter , pressure relief valve and gun nosall well work sometimes and keep working, when you release the...
Sounds like the regulator is sticking or is airbound. loosen the water connection and then tighten it back. Could also be that the trigger gun is faulty or needs adjustment. Hope this helped
Mar 12, 2009 | Karcher 2500 PSI Pressure Washer
have you checked to make sure that keyway is installed between electric motor and pump. also adjustment on unloader valve may be incorrect. If the big brass nut on the unloader is able to be turned by hand, then this is probably your problem (running pressure and spike pressure needs to be set and locked down using a pressure guage). does water come out of nozzle at all? if not, tip being stopped up may be the problem. trash between unloader ball and seat can also cause no pressure (usually caused by a burr left inside brass pieces during the manufacturing process). I have seen all the check valves stuck on a brand new unit from sitting on the shelf for so long, but this is usually the case with General Pumps.
Jan 07, 2009 | Northstar Pressure Washer 3000 PSI
Garden Logo
Top Water Garden Experts
Vernon Taylor
Are you a Water Garden Expert? Answer questions, earn points and help others
