Question about Exercise & Fitness
My E95 sole elliptical is reading E2 Motor error could anyone help
5 Suggested Answers
SOURCE: Power ramp does not work.
Ignore everything above - most of the time this is an easy fix. Usually, it happens with a brand new console, or a machine that has reset itself.
Hold down the incline up (on the console itself) button and the start button at the same time. Then follow the instructions on screen.
It will run through an initial calibration, and once complete, the ramp will now work. Just did this with mine, and my ramp is now working perfectly.
Posted on Nov 30, 2011
  • 12223 Answers
SOURCE: kettler mondeo e2 fault
Dear Sir:
Press the keys> stop+enter +quick start in sucession and go with key down up, until the error presss SELECT, for to quick star to clear the error log. Anyway read your instruction manual.
If you do not have go for free download:
sincerely. God bless you
Posted on Apr 23, 2012
  • 74999 Answers
SOURCE: I have a Sole E20 elliptical. I'm getting a E1 error/ eeprom err message. What is the problem? How do I fix it?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Posted on Dec 10, 2015
  • 48272 Answers
SOURCE: Sole 235 elliptical causes static that interferes with the tv and pvr.
the machine has has front drive system which indicates an electric motor
static can be caused by brushes arcing on the commutator bars
that would require a check by an electrician or technician
removing the rubber mat will do nothing as I suggested
the arcing is causing the static so it is severe
if the machine is under warranty , get it checked by a warranty technician or service agent
failing that the capacitor is fitted across the power and neutral points at the back of the power point
Posted on Feb 07, 2017
Testimonial: "Thank you, Where is the power point, an neutral points? It is not under warranty, and is 2nd hand. Kind of confused as to why this would need to be done. Thanks."
Motor error messege on E25 sole ellipticle
proceed according. God bless youDescriptionThis error monitors the treadmills power bit reading. Power bits indicate the relative time that themotor controller drive circuit is turned on. Therefore power bits is an indication of the amount ofpower the load is demanding from the motor controller. The treadmill software sets a maximumallowable power bit limit. Error 25 indicates that the maximum power bit limit is being exceeded.Possible Causes1. The running belt and/or running bed is badly worn.2. On treadmills utilizing an SCR motor controller, a leaky or shorted drive motor filter capacitorcould raise the current demand sufficiently to cause the error 25.3. On treadmills utilizing an SCR motor controller, a leaky or shorted drive motor inductor couldraise the current demand sufficiently to cause the error 25.4. A shorted or de-magnetized drive motor is causing the high power demand.Possible Remedies1. A clamp-on A.C. ammeter must be used to determine the amount of A.C input current beingdrawn by the treadmill under no load and loaded conditions. The current readings can beused to determine the condition of the running belt and/or running bed. These same readingsshould be taken on a similar unit with a known good running belt and running bed. Thosereadings can then be used as a benchmark for future use. Replace the running belt and/orrunning bed as required. Remember, many running beds are double sided and the bed canbe flipped over rather than being replaced.2. A clamp-on ammeter should be used to measure the A.C. input current at no load. The filtercapacitor should then be electrically isolated from the drive motor circuit. The drive motorleads must be kept intact so that the drive motor will operate with the filter capacitor removedfrom the circuit. The no load A.C. input current should be measured again, if the A.C. inputcurrent is significantly lower, replace the filter capacitor.3. Use the same procedure as in step 4 above, except remove and isolate the inductor from thedrive motor circuit instead of the filter capacitor.4. A known good drive motor must be substituted for the existing drive motor.
Apr 02, 2013 | RTO Sole Fitness Package F85 Treadmill &...
I need schematics for Manufacturer's Product Number: 022670
Step 1:
you must find it. in www.
however see the diagram attached FOR troubleshooting and fix it.
God bless you
Step 2:
Step 3:
Jan 08, 2013 | RTO Sole Fitness Package F85 Treadmill &...
Sole treadmill says "INITIAL" on the screen and won't run. This occurred after I removed the magnetic emergency stop switch.
Normally you must put the key in the hole, after you press the button start and ready.
However I recommend you to follow the instr. manual for easy start. Since that every manufacturer has a little diferrent mode of start. If you do not have it download free from
God bless you
Dec 17, 2012 | RTO Sole Fitness Package F85 Treadmill &...
E3 error on sole E95 elliptical
The E95 incline motor is out of calibration. Recalibrate the incline by holding the UP INCLINE button and the START button simultaneously for 5 seconds. This will put the machine into incline calibration mode. Press ENTER to start the calibration and let it run. It will take a minute or two.
Refer to page 25 (the last page) of the user manual, hidden right at the bottom.
Sep 20, 2012 | Exercise & Fitness
Operating manual sole e35
go to for free download
Good luck,sincerely. G-d bless you
Dec 12, 2011 | RTO Sole Fitness Package F85 Treadmill &...
SOLE E95 "Ramp Error" Message
Thanks! It was the calibration!
But in order to get to calibration mode I had to press "Resistance Up" and "Start", not "Incline Up" and "Start"
Aug 07, 2011 | Exercise & Fitness
Exercise & Fitness Logo
162 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
