Question about Ovens
I have a turbo oven, recently the oven have light and power but the oven is not heating up. What could cause it?
My oven won't heat up
to many things can cause this to get into here call service
Feb 26, 2015 | Ovens
Both oven lights out
Are you buying hi quality oven grade lamps for this purpose that'll take the intense heat inside an oven? I wonder if they're halogen or tungsten filament lamps. Defective solder, frosty joints and/or ring fractures on lamp driving areas of a circuit board ARE indeed capable of causing problems with lamps.
Mar 16, 2014 | Dacor MCS130 Millennia Electric Single...
My Electrolux EOB5610 fan oven will not heat up. The power light is on. The oven light is on. The fan works. There is some heat in the oven but not enough to cook with.
Only two possible causes. The oven element is faulty or the oven thermostat controller is faulty. Probably the first thing to do is test the oven element and check the resistance. If the element is okay then the oven thermostat will need replacing.
Feb 23, 2011 | Electrolux EOB5610 Ultrafan Electric...
We have a fan oven, which started not heating, but fan and thermostat light still on! We thought it was the element! But now the oven is working very occasionally, still heating as normal! We can try to...
Elements don't heat intermittently - if the element is good it will heat up every time. If the element is blown / burnt-out it wont ever heat.
As your oven is heating sometimes but not others, this means the power supply to the element has an interruption somewhere. This could be caused by any of the following:
1. Loose connection in the wiring at the switch or the element
2. Faulty switch
3. Faulty thermostat.
4. Faulty oven timer
The thermostat is effectively just a heat-sensitive switch. By default it should be "closed" allowing power to the element. When the oven reaches the desired temperature, this switch opens, cutting power to the element until the oven cools enough for the switch to close and allow power to the element again.
Any of these four could be the cause of your fault. Loose connections can often by located visually, however testing a thermostat for correct operation and calibration is more complicated and ideally requires test equipment. The timer is the least likely cause, so I would concentrate on the others first.
Repairing your oven or any other electrical appliance can be dangerous and many repairs require specialist knowledge and/or electrical test equipment. Please bear this in mind before and when attempting any repair or consider having your appliance professionally inspected.
If you are intending to investigate this problem yourself, please ensure the power is disconnected at the wall/breaker first. Initially, I suggest that you visually check the connections at the element and the switch. You may find a wire at one of these locations that is partially broken or detached. Personally, I suspect your thermostat may be faulty.
Hope this helps.
Regards,
BElectric
Jan 01, 2011 | Ovens
I have a diplomat 4510 electric oven, the pilot light is constaintly on even when the oven is not on,the oven does not heat up, i recently replaced the element
If you have replaced the element, and it does not heat up, then I would suspect the thermostat as being the cause of the problem, more so if it is the oven pilot light that is on.
To be certain, you really need to see if you are getting a feed to the element when you you set the thermostat.
Hope this helps.
Jan 31, 2010 | Belling XOU592 / XOU593 Electric Double...
I have a Competence 52081 double oven. Ity has
Thermostat may need adjusting OR air may be entering the oven causing the problem
Sep 01, 2009 | Ovens
MY HOTPOINT SELF CLEANING STOVE
how do I get my self cleaning to come on in my hotpoint stove
May 22, 2008 | Ovens
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
