Question about Zanussi 22 in. ZGG642C Gas Cooktop
Where is the battery on a Franke cooktop? ( No manual)
I have Franke gas 4 burner cooktop without a manual.
I have just purchased the house and the pre-ignition does not work.
The cooktop is built in and there does not seem to be any panel that screws out etc.
Where do I find the battery to replace it?
I am not sure of the model number but the gas cooktop was purchased in 1998. The 2 burners on the left side all of a sudden are not ingiting. There is no gas and the igniters are not sparking. the other...
Hello Sharon,
are the two left hand burners "simmer burners" that low come on and go off to simmer a pot?
and the right side just set on and turn off without the simmer option?
if yes this pretty much describes your cooktop the part called the potentiometer is going the be the problem.
Aug 26, 2011 | Thermador SGS36GS Gas Cooktop
Can a GE profile black 4 burner with down draft gas cook top be converted to propane gas? How?
Hi and welcome to FixYa, I am Kelly
Everything I am reading says this unit comes with an LPG conversion Kit. It may have been removed by the detailer / retailer that you purchased it from (when ever that was.)
The 0.0354 orfices are supposed to be in the front of the inside of the cooktop and are labeled LP.
It is a matter of removing the 4 Natural Gas orifices and installing the LP orfices and then adjusting the air-flow of the grill burner Air Shutters as shown in the manual on page 32.
The center nut has to be removed from the top of the internal gas regulator and the mini post / plunger inverted and then the nut is reinstalled.
Just note that any conversions are supposed to performed by a qualified gas technician as stated by the WARNING in the manual on page 30.
The manual is here:
http://www.hammerwall.com/tempmanuals/L0603449.pdf
The step by step instructions are in the product user guide on page 30
or you can go to this link and click on info and guides:
http://www.ajmadison.com/cgi-bin/ajmadison/JGP990.html
then download the use and care guide.
Thanks for choosing FixYa,
Kelly
Jul 22, 2011 | GE Profile Nonstick Griddle for Downdraft...
My GE Gas cooktop model # JGP975EKSS is trying to ignite without any burners being turned on.
If all the burners are trying to ignite at the same time - the ignitor module is to blame.
If it is one specific burner - take a look at that individual knob.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 04, 2010 | GE Profile JGP636 Gas Cooktop
Missing manual and gas diffuser
May I get the make and model # to help you get the manual.
Also from the gas supply from house to cooktop it should go like this.
gas valve
gas line
regulator
then cooktop
May 31, 2010 | Maytag MGC5430BDS Gas Cooktop
Dacor sgm304s, Ignitor constantly snapping.
under burner control knob broken plastic cam that operates switch.
Sep 07, 2009 | Dacor Preference SGM304 Gas Cooktop
Constant sparking
I don't have a Thermador cooktop but here is ma taught.
Could you unplug the two faulty igniters and see if problem remained
Could you plug one of the faulty igniter at the location of a good one. The goal is to isolate the problem. Is it the igniter or the electronic board.
Faulty ground problem may occur also after an spillover on the stove. In that case, use a cotton swab dipped in scrubbing alcool and clean the spark area on the igniter and the burner.
Good luck
Mar 31, 2017 | KitchenAid 31 in. KGCC505 Gas Cooktop
Old Thermador cooktop continues to spark even after turned off
sounds like you have a bad switch. maybe on the large burner.. some of those switches can be replaced without the whole harness.
Dec 22, 2008 | Thermador PSC364GDZS Gas Cooktop
GE 36" Monogram Gas Cooktop - low flame
I would have someone come out. Perhaps a gas plumber first. Gas is not something you want to fool around with yourself.
Aug 01, 2008 | GE 36 in. JGP628 Gas Cooktop
Jenn-Air 30 in. JGD8130 Gas Cooktop
Yes. Buy a burner module. Sears sells them also most appliance part stores. (I am assuming you have the model with 2 knobs on the grill side) The electric version of burner modules is around $100 Gas should be similar price.
Jun 08, 2008 | Jenn-Air JGD8130 Gas Cooktop
Thermador Gas Cooktop Won't Stop Clicking : SGC304RS
theres a part in the cooktop called a spark modual. replace it. when i goes bad the problem your having is what it causes
Nov 29, 2007 | Cooktops
Zanussi 22 in. ZGG642C Gas Cooktop Logo
191 people viewed this question
Top Zanussi Cooktops Experts
Brian Coughlan
Tom Chichester
Are you a Zanussi Cooktop Expert? Answer questions, earn points and help others
