Question about Radio Communications
POLICE SCANNER SD ACCESS CARD ERROR - Radio Communications
4 Suggested Answers
Bajanguru
  • 7752 Answers
SOURCE: Have 2 gb kingston micro
the card is not damaged the phone is just not reading the card...the phone needs to be checked
Posted on Dec 01, 2008
  • 18 Answers
SOURCE: LG Ally Android phone says it's checking the SD
you can try plugging the SD card into your computer with an SD card adapter and see if you can access your files.
You may have to format your SD card if you cannot access your files this way. from the phone go to settings, SD Card - phone storage (some phones its labeled different) From there you can format your SD card, depending on your phone you may have to choose Unmount SD card first.
If you continue to receive errors or are unable to format the card, it is most likely that the SD card is bad and needs to be replaced.
Posted on May 04, 2011
  • 455 Answers
SOURCE: I get memory card error when trying access my SD card
do you mean you switched to a NEW sd card or to a DIFFERENT one you had laying around? sometimes if you put a card into a different device, say maybe a laptop, and you don't go to 'safely remove disc' on the computer it will wreck your sd card when you remove it. make sure you try a new card from a package before you do anything else-if that doesn't work your camera has a problem.
Posted on Jan 04, 2015
Two things- first, you might be able to use an SD card adapter on your computer to move the files. Second, if you have Windows 7, 8, 8.1 or W10, the 'driver' for your scanner most likely is an "unsigned driver" and you will have to load the cable driver using a special startup F7 or something, so that you can go ahead and load an 'unsigned driver' regardless. Go to "Radio Reference dot com" and search for your scanner type- there is a wealth of information there after you set-up an account. Try their website for help and then you can get back ahold of me, and maybe I can be of more help. okay? What scanner model is it?
May 01, 2017 | Radio Communications
Tip
Overcoming with SD card "write error"
SD cards are flash memory devices which allow a user to store huge amount of data. Being reliable and durable, these cards have become the hot choice to store data and are used in various host devices like digital camera, PDAs, video game consoles, MP3 players etc. Despite so many advantages, these cards are also prone to errors. Most of these errors occur due to reasons like interruption in read/write process, virus attacks or file system corruption. While some SD card errors can be dealt by cleaning the contacts of the card and re-inserting it, others can be rectified by formatting the card. After formatting, the SD card data can be retrieved by using either a valid backup or SD card recovery software.
Consider a situation, you have taken your family to an exotic locale and while clicking pictures through your digital camera (which is using a SD card) you witness an error on its LCD screen:
“Write error”
The above error is not rare in case of SD cards. The moment the error erupts, the data stored on the SD card becomes inaccessible. Moreover, the SD card becomes useless as you can't even store new data on it.
Cause
The above error which rendered the SD card ineffectual can be accounted to corruption. The other reason can be relatively less memory space to accommodate new data.
Resolution
In order to rectify 'write error', you can try the following possible techniques:
  • Turn the camera off, re-insert the card and then turn it on again
  • If you are still not able to access the data, connect the camera to a computer
  • You can use a card reader to access the SD card data
  • In grim situations where nothing of the above works, format the SD card and restore the data using a backup
After formatting, the SD card becomes functional and can perform read/write operation. If a backup of the data is corrupted or invalid, you can rely on a SD card recovery software. A SD card recovery tool employs improved scanning algorithms to extract data in the event of corruption.
Stellar Phoenix Photo Recovery, a well-known SD card recovery tool, is designed to recover lost/formatted/deleted multimedia files from a variety of memory cards like SD, SDHC, XD, MMC, CF etc. The easy-to-use tool is available in two versions, one each for Windows and Mac operating system.
on Apr 27, 2010 | Computers & Internet
Sd card access error keeps coming up on my police scanner
have you accidentally slid the write protection tab down on the mem card your using, it needs to be slid up for access, also ensure the mem card isn't full
May 01, 2017 | Cameras
What is the best scanner to receive local police reports
The all depends on what the police are using in your area. If the police are on a simplex frequency or a local repeater, just about any scanner will do. If you are in an area with P25 digital trunking, you are going to need a more expensive scanner such as the Uniden BC396XT or the brand new Uniden BCD436HP.
Uniden BCD436HP HomePatrol Series Digital Handheld Scanner
Mar 25, 2014 | Radio Communications
I keep getting a Card Access Error message on my Sharp VE-CG40U, what could be causing this?
Actually, you didn't. You put in a new 4GB SDHC card. The camcorder works with SD cards, not with SDHC cards. You need to use SD cards, 2GB and smaller.
May 03, 2012 | Sharp VE-CG40U Digital Camera
LG Ally Android phone says it's checking the SD card for errors. Can't access SD card.
Mar 21, 2011 | LG Ally Cell Phone
Memory card unformatted
If there are sd card error, you cannot format your sd card. you may get messages like
"No SD memory card inserted" messages appears when using digital cameras,
"A media card hard been inserted that contains errors. Do you wish to repair the Media Card now?"
You can read the files on SD memory card, but you cannot write new files or you cannot edit files on SD memory card,
"Access denied", when SD card is corrupted or broken,
you can fix sd memory card errors first and them format you sd card.
Nov 05, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
Have a programable police/fire scanner and no local codes?
Hello there:
here is a couple of links that will get you to where you can find them
  1. Police Scanner Frequencies & Scanner Frequency Resourcessafe.gif Police scanner frequency page where you can find scanner frequency resources from across the net US including free and commercial databases and listings.
    www.police-scanner.info/police-scanner-frequencies.htm - Cached - Similar
  2. Police Scanners, Scanner Frequencies, & More Police Scanner Stuff!.avgnotice { width: 320px; font-size: 7px; line-height: 7px;}.avgimage { height: 7px;}.avgborder { border-color: #00A120; border-style: solid; border-width: 0 3px; font-family: Arial, Helvetica, sans-serif; font-size: 10px; line-height: 13px;}.avgsep { border-color: #C0A8A6 #C0A8A6 #FFFCF7 #FFFCF7; border-style: solid; border-width: 1px 0; font-size: 0px; line-height: 0px;}.avgtop { text-align: center; background: #F4FBF4 repeat-x url(chrome://searchshield/content/background_top_green.gif); padding: 0 5px; height: 30px;}.avgmiddle { background: #C3E5CA repeat-x url(chrome://searchshield/content/background_middle_green.gif); padding: 5px 10px; word-wrap: break-word; overflow: hidden;}.avgbottom { background: #00A120; padding: 10px 5px 0 10px; border: 1px solid #00A120;}.avgbottom td { font-size: 10px; color: #ffffff;}a.avgbutton { color: #0000ff; display: block; padding-top: 3px; width: 69px; height: 20px; text-align: center; background: no-repeat url(chrome://searchshield/content/click_here_green.gif);}.avgtitle { color: #00A120; font-size: 11px; font-weight: bold; margin-bottom: 8px;}.avgnote { font-size: 9px; font-weight: bold; padding-top: 5px;} --> Safe: This page contains no active threats. Explanation:
    It is safe to proceed to this page.
    Domain:
    IP Address: 207.217.125.50
    Owner:
       Name:
       Address:
       Country Code:
    Scanned on: 10/13/09 20:44:43
    (1.08 seconds to scan this page)
    Ratings are provided by AVG. Site owners please contact AVG Technologies for questions. Keep up to date with the latest AVG news and updates. Visit the AVG website.
    click here Get our most complete protection against online threats. Get AVG Internet Security today. Find out how. click here ')" id="XPLSS_389644331U1" src="chrome://searchshield/content/safe.gif" border="0" hspace="5" /> Find everything about police scanners; general police scanner info, police scanner frequencies, live police scanner feeds, police scanner websites & more ...
    www.police-scanner.info/ - Similar
  3. you can also go to police scanner live to get some local codes ok
  4. I really hope that this is verry helpfull
  5. best regards michael
Oct 14, 2009 | Uniden Radio Communications
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
