Question about Cameras
Sd card access error keeps coming up on my police scanner
    Scholar:
  • 70 Answers
Have you accidentally slid the write protection tab down on the mem card your using, it needs to be slid up for access, also ensure the mem card isn't full
Posted on May 03, 2017
POLICE SCANNER SD ACCESS CARD
Two things- first, you might be able to use an SD card adapter on your computer to move the files. Second, if you have Windows 7, 8, 8.1 or W10, the 'driver' for your scanner most likely is an "unsigned driver" and you will have to load the cable driver using a special startup F7 or something, so that you can go ahead and load an 'unsigned driver' regardless. Go to "Radio Reference dot com" and search for your scanner type- there is a wealth of information there after you set-up an account. Try their website for help and then you can get back ahold of me, and maybe I can be of more help. okay? What scanner model is it?
May 01, 2017 | Radio Communications
SD card access error keeps coming up on my screen
have you accidentally slid the write protection tab down on the mem card your using, it needs to be slid up for access, also ensure the mem card isn't full
May 01, 2017 | Cameras
I keep getting a Card Access Error message on my Sharp VE-CG40U, what could be causing this?
Actually, you didn't. You put in a new 4GB SDHC card. The camcorder works with SD cards, not with SDHC cards. You need to use SD cards, 2GB and smaller.
May 03, 2012 | Sharp VE-CG40U Digital Camera
LG Ally Android phone says it's checking the SD card for errors. Can't access SD card.
you can try plugging the SD card into your computer with an SD card adapter and see if you can access your files.
You may have to format your SD card if you cannot access your files this way. from the phone go to settings, SD Card - phone storage (some phones its labeled different) From there you can format your SD card, depending on your phone you may have to choose Unmount SD card first.
If you continue to receive errors or are unable to format the card, it is most likely that the SD card is bad and needs to be replaced.
Mar 21, 2011 | LG Ally Cell Phone
Memory card unformatted
If there are sd card error, you cannot format your sd card. you may get messages like
"No SD memory card inserted" messages appears when using digital cameras,
"A media card hard been inserted that contains errors. Do you wish to repair the Media Card now?"
You can read the files on SD memory card, but you cannot write new files or you cannot edit files on SD memory card,
"Access denied", when SD card is corrupted or broken,
you can fix sd memory card errors first and them format you sd card.
Nov 05, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
Scanner frequency for Villa rica, Ga. police
If you have access to a computer go to www.scanatlanta.com and click on scanner frequencies, when the map of GA comes up, click on your county, which I think would be carrol and they have all the county and city frequencies listed.
Sep 30, 2009 | Uniden Bearcat Pro PC68LTW 40-Channels...
Tom tom go 300 ''unable to store settings'' ''file access error'
You might have the switch on SD card set to "read only" , This would stop your tomtom being able to write to the SD card ... hence , " unable to store settings " message . .... OR ... the folder where your tomtom wants to store the settings is corrupted ( on your SD card ) so it can't store them.... or similarly , the file is corrupted on the SD card ( maybe the card is damaged ) so the existing file cannot be overwritten . Check out all these possibilities before suspecting any hardware fault on your tomtom ..... GOOD LUCK
Nov 24, 2008 | Tomtom GO 300 GPS Receiver
SD Card Error
I had a similar problem and after a bit of tooling around, I was able to get this to work for me. There are a couple of steps. Basically the problem is that the memory card wasn't properly disconnected from the player at some point so it's reading filesystem errors on it as a result. (Kinda like pulling out a USB key from a computer before you've "safely removed hardware". While your computer will tolerate this, your zen will not.) Here's how to safely remove disconnect your SD card after copying files to it.
1. First, if possible, reformat your SD card. This is not critical, but is a good practice so that you can sart from scratch with a totally fresh card.
2. Next, plug in your SD card to your player and turn it on. Navigate to the memory card menu, and place the memory card in "removable disk".
3. Plug the Zen into your computer, and go to "my computer". There should be a new disk called "removable disk" which is now shown along the rest of your hard drives. (Kinda like when you plug in a USB key drive. You're essentially doing the same thing here.)
4. Copy your files to the "removable disk".
5. VERY IMPORTANT: When you are done, right-click on the removable disk and choose "eject" fromt the menu that comes up. When a popup appears saying that your hardware is safe to remove, you can unplug the zen from the computer.
6. Now navigate to your memory card using your zen player, and choose "browse". It should come up now without any error.
Jul 08, 2008 | Creative Labs Zen Digital Media Player
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
