Question about Vacuums
How do we get to the belt? The brush will not rotate we want to check the belt but can't figure out how to get to the belt?
  • 4 Answers
Most uprights have several screws holding the panel on the underside of the vacuum. You need to turn the vacuum upside down and remove the screws and the panel. This will give you access to the brush and the belt..
Don't forget to make sure the vacuum is unplugged prior to doing this!! Hope this was of some help.
Posted on May 02, 2017
I need a diagram to show me where and how to install the front belt< I think the motor belt) on my Hoover Windtunnel, self propelled Model U6634-900 series x12-0 60HZ 120 V
Most vacuums are pretty well the same belt set-up...remove the metal plate covering the rotating floor brush and pull it out...place new belt over motor pulley and and stretch other end over rotating floor brush in the space provided for it....pull and place ends into slots on the sides....if the belt is not straight flip the brush the other way...you will figure it out. Just be sure to buy the right belt!!!
Regards,
Dennis
Aug 15, 2014 | Vacuums
Spinbrush not working on eureka as1104
If the belt is intact, the brush roller ends may be so jammed (usually with hair) that it cannot rotate. Also, if the brush roller cannot rotate, the motor shaft may be rotating in one spot on the belt and eventually will burn it out. The solution in the case of the brush roller is to remove it and check for free rotation. If the ends are binding, the brush roller will have to be disassembled to remove debris.
Aug 10, 2014 | Eureka Vacuums
Brush not turnning
The brush roller is driven by a belt installed on the motor shaft. The belt could be broken or off the shaft. The brush roller could be clogged inside the end caps with debris which prevents rotation. To solve the debris problem, it will be necessary to remove the belt from the motor shaft, then note the orientation of the end caps and remove the brush roller. Next, remove one end cap and check for clogging material. Remove the material. Slide the brush roller shaft away from the end of the brush roller to check for clogging material at the opposite end. Remove the material. Slide the brush roller shaft back into position and reinstall the end cap. Reinstall the brush roller in the correct position. Reinstall the belt. Check for proper rotation of the brush roller.
Apr 08, 2014 | Electrolux EL8905A Nimble Brushroll Clean...
Brushes don't rotate during floor cleaning
Check that no strings or other debris is clogging the brush wheels. If it isnt that check that the belt isnt broken connecting the brush to the motor. If that is ok, most likely the motor is blown and not turning the belt.
Sep 20, 2012 | Hoover F7425-900 SteamVac V2 Widepath...
Carpet brush not rotating
Did you check the drive belt for the roller? If not do so, the smell was the belt drive burning up.
Jan 16, 2012 | Kenmore Vacuums
Brush roller not spinning. belt, spindle okay. roller taken out and cleaned, no thread. replaced but no dice. ???
Use only BISSELL Style 10 Replacement Belts (#32074) in your BISSELL PowerForce Bagless.
  1. Unplug cleaner from electrical outlet.
  2. With Rotating Floor Brush removed from vacuum cleaner, grasp old Drive Belt and remove from Motor Pulley. Discard old Drive Belt.
  3. Place new Drive Belt over Motor Pulley and stretch other end over Rotating Floor Brush in the space between the bristles.
  4. Place ends of Rotating Floor Brush down into slots on sides as shown.
  5. Turn Rotating Floor Brush by hand several times in the direction of Motor Pulley. If properly installed, Drive Belt will center itself on Rotating Brush.
  6. Reposition Brush Cover and snap back into place. Check to be sure all three latches are secured.
  7. When you turn on the vacuum, do you see the motor that spins the belt spinning at the bottom? If not, it sounds like you may have a burned out motor.
If suggested solutions do not correct the problem, call:
BISSELL Consumer Services 1-800-237-7691
Monday - Friday 8 a.m. - 10 p.m. ET
Saturday 9 a.m. - 8 p.m. ET
Jun 01, 2011 | Bissell 6594 PowerForce Bagless Upright...
Need to replace belt and cannot figure how to take it apart to get at the belt --- Took Screws off on the bottom but could not get to the belt
You have already removed the screws so lift the brush cover off. Then grasp rotating floor brush at both ends and lift. Clean strings,hair and other debris from rotating brush, paying close attention to the brush ends. Clean the debris from motor pulley and drive belt areas.Grasp old drive belt and remove from motor pulley. Place new drive belt over motor pulley and stretch other end over rotating floor brush in the space between the bristles. Place the ends of the rotating floor brush down into slots on the sides. Turn the rotating floor brush by hand several times in the direction of motor pulley. If installed properly, drive belt will center itself on rotating brush. Reposition brush cover and screw back into place. I hope that this helps you!
May 26, 2011 | Bissell 3591 CleanView Bagless Upright...
My brush won't rotate. i have replaced the belt once already but it melted because the only thing rotating was the motor pulley. I have cleaned all the excess hair off the brush, checked everything, and...
The most probable cause is improper tension on the belt. What would cause this problem is the wrong belt, or improper adjustment of belt. Once installed, the belt should only move slightly when pushed down by your finger. Too loose and the belt won't rotate the brush and will quickly burn out. Too tight and it will cause excessive stress on the motor and shorten it's lifespan.
Another problem could be that the belt wasn't centered properly. When the new belt is installed, the brush needs to be manually rotated a few times to center it. This will prevent it from getting caught in or on a part of the power head, thus quickly breaking or melting.
If you still have problems you may need to take it to a reliable service center.
Dec 21, 2010 | Bissell 3576 CleanView II Bagless Upright...
Fantom fury vacuum
HOW DO I CHANGE THE BELT ON THE FANTOM® THUNDER® AND FURY®? a.gif fantombeltchange1.jpg
  1. Unplug the machine.
  2. From the front of the machine, remove the collection bin.
  3. Facing the back of your vacuum, remove each of the Philips head screws located above each of the rear wheels. (Figure 1)
  4. To remove the base cover, place your thumbs in the two screw holes in the back of the machine. Push forward and up on the screw holes to disengage the 3 cover locking tabs. Put the cover off to one side, and go to the front of the machine. (Figure 2)
  5. Check the drive arm for any black streaks which indicate residual rubber from the last belt. The drive arm is located on the right side of the motor. The easiest way to remove any residual rubber is with some nail polish remover on a rag or with steel wool.
  6. To attach a new belt, remove the brush from the base of the machine by pulling up straight up with two hands.
  7. Take the new belt and hook it over the steel drive arm. Pull back on the belt slightly, to create some tension.
  8. Put the brush inside the belt loop so that the track for the belt is aligned with the belt itself.
  9. Replace the brush by aligning the metal end so the points face downward. (Figure 3)
  10. Rotate the brush by hand to check that the belt is running freely and easily in its designated space between the bristle.
  11. Replace the cover by placing the nose in first. Once in place fasten with the two cover screws and then replace the collection bin.
May 13, 2008 | Fantom Vacums Lighting Canister Vacuum
Vacuums Logo
22 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
