Question about Dishwashers
BOSCHE SHX2AR55UC/14 FD940500389 My dishwasher is not draining and also the Active led is not on
2 Suggested Answers
  • 10865 Answers
SOURCE: Not draining; about an inch of graywater in bottom. Dishes not clean. Unit is about 5 years old.
hi there. let me help you. check these things below and get back if we did not isolate the problem for you.
If the water doesn't drain from your dishwasher, check these:
Drain line/air gap
Drain valve and/or solenoid
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Posted on May 28, 2009
My bosche dishwasher is not filling with waqter
Here is a tip that will help you to find out why water will not come into thedishwasher...
Dishwasher Trouble No Water entering Dishwasher
Sep 16, 2011 | Bosch Dishwashers
We have a hobart am 14 hotwater sanitizing dishwasher that no one knows how to use, how can I get an instruction booklet?
Go to instuction manual are available on its site to download.
Makes sure all screens are in nothing in tank under them (spoons especialy). turn power switch on, shut door and it fills, should say fill on led display. once its filled open door and put tray in shut door and it starts wash cycle. led will say wash then it will go into rinse. when risnes dispaly turs of its finished. open doors take tray out. put next tray in. to drain out to clean there is a little moon shaped lever right above basket it will life the drain stand pipe greay plastic tube under screens and it will drain out shut door turn on the switch and it will fill back up and off you go. Soap wil be with a privet vendor if you have a already installed soap system call them and they most likely have reps who cann show you you basics.
Best Dishwasher Hobart ever built is the Am-14
Aug 19, 2011 | Hobart AM14-253 Free-standing Dishwasher
I have an older bosche dishwasher and the I know the water is flowing into the unit and collecting at the bottom of the drain but it is not getting into the spray arms in the middle and top to work at all....
there is a chacne that the main wash motor is not drawing enough water into the pump to spray through the can try and add some more water to the dishwasher and see if there is any change.
if there is no change then you migh need to replace either the contol board or the main wash motor
Sep 08, 2010 | Dishwashers
1- machine operates with the door open. 2 - water
So if I fixed it you want me to give that info to you for free but otherwise you want to charge me for an answer?
Oct 29, 2009 | Bosch SHU9922UC Built-in Dishwasher
I have a Bosch Exxcel Dishwasher, stuck at 1 minute to go
Make sure the drain pump is clear of any blockages and obstructions and that the drain hose wasn't kinked when you re-installed it.
Sep 04, 2017 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 24 in SHU66C05UC/14
small_9_26.jpg For a detailed Dishwasher illustration, click below.
redarrow.gif Built in
Warning!To avoid personal injury or even death, always disconnect yourappliance from its power source--that is, unplug it or break theconnection at the circuit breaker or fuse box--before you do anytroubleshooting or repair work on your appliance. Also, because somecomponents may have sharp edges, use caution while working on yourappliance.
There's an error code on the digital display
It cleans poorly
There's no water entering the machine
The water doesn't drain from the machine
It's noisy
It leaks
The dry cycle has problems
The door has problems
The cycle doesn't complete
I see an error code
The detergent cup doesn't open
The cycle times are too long
Jul 08, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Dishwashers Logo
Top Dishwashers Experts
