Messenger has 3 notifications for me. What are they?
I have an apple 1how do I delete my notifications from messenger please ,
You could turn off the notification from the app by going to settings>notifications and turn off notifications from whichever app you need.
Mar 15, 2016 | Apple iPad (16 GB) WiFi Tablet PC
Quickly hide all windows - Windows Live Messenger
<span><span>1.When</span> <span>software installation</span> <span>Messenger</span> <span>Plus!</span><span>.</span> <span>check</span> <span>the</span> <span>option</span> <span>I refuse</span> <span>to</span> <span>give my</span> <span>support</span><span>, do</span> <span>not install</span> <span>the</span> <span>sponsor</span> <span>to</span> <span>avoid</span> <span>the installation</span> <span>of</span> <span>adware</span><span>.</span></span> 2.When <span>finished</span> <span>copying</span> <span>files</span><span>,</span> <span>click</span> <span>Close</span><span>.</span> <span><span><span>3.</span> <span>when</span> <span>you use</span> <span>Windows</span> <span>Live</span> <span>Messenger</span><span>,</span> <span>simultaneously press</span> <span>the</span> <span>Ctrl</span> <span>and</span> <span>space</span> <span>to</span> <span>hide</span> <span>all windows</span> <span>Windows</span> <span>Live</span> <span>Messenger</span> <span>open</span><span>.</span><br /><span>4.the</span> <span>first time,</span> <span>you</span> <span>will need to</span> <span>confirm by</span> <span>clicking the</span> <span>Lock</span> <span>Messenger</span><span>.</span></span></span> <span><span><span>5<span>.After</span> <span>your</span> <span>boss</span> <span>is gone</span><span>,</span> <span>you</span> <span>can find</span> <span>the</span> <span>windows</span> <span>of</span> <span>Windows</span> <span>Live</span> <span>Messenger by</span> <span>double</span> <span>clicking</span> <span>on</span> <span>an icon representing</span> <span>a</span> <span>networked hard drive</span> <span>that appeared</span> <span>in</span> <span>the</span> <span>notification area</span> <span>to the left of</span> <span>the clock</span><span>.</span></span></span> </span>
on Jan 03, 2011 | Computers & Internet
How Do I delete notifications from my Facebook messenger page
Go to Settings: Notifications (left column), then look for the messenger selection on the right. Turn notifications off.
Mar 15, 2016 | Apple iPad 2
NO sound when i receive a text message, how do i fix it?
First make sure that all volumes are all the way up. Go to settings, sounds, and rise up all of the volume.
Second, select a notification sound for your default notification, go to settings, sounds, notifications, tap it and choose a notification sound.
Third, whether you are using the native messenger or a third party messenger, go to the messenger settings, notifications sound and choose a sound for it.
if possible, download Zedge, this will help you choosing different ring tones and notifications sound.
Mar 15, 2015 | Android Zte-z990
How come the ding goes away on messenger. This is on a I phone 5
Marie, are you talking about the Text Messenger or Facebook Messenger? If it is the Text Messenger, try going to Settings -> Notifications -> Message. Once there, check if the "Notification Sound" is shown as set to "None". If so, click there and chose the ding you want. If you're looking for a solution to the Facebook Messenger, go to Settings -> Notifications -> and scroll down until you find the Facebook Messenger icon. Click on it and check if your notification is setup correctly as: Notification: On; Sounds: On. You can also check if the "Do Not Disturb" feature is disabled - this will put your phone to just ignore any income call, text, or notifications in general. Please follow the following link for more details about this feature.
Jan 30, 2015 | Apple iPhone 5
How can i fix this error 40402 i my yahoo messenger box
Clear your Yahoo Messenger cache in Windows If you are seeing error -40402, your contacts cannot see your display image, or you cannot see there's. We've go help for you
Learn how to clear your Yahoo Messenger cache to resolve a variety of issues:
  • "An error occurred while trying to access the 'SocialView' plug-in."
  • "The last Address Book operation did not succeed due to a server error. (error code: -40402)"
  • Your contacts can't see your avatar or display image - the picture appearing next to your name in message windows, or your contact list.
  • You can't see your contacts' avatars or display images.
Note: These steps apply to Windows XP, Windows Vista, Windows 7, and Windows 8; including 32-bit and 64-bit versions.
  1. In the notification area located next to the clock at the bottom-right corner of your screen, right-click the Yahoo Messenger smiley icon, then select Exit.
    • Note: Windows 7 and Windows 8 users may have their "Messenger smiley" icon hidden in the notification area; if so, move your cursor over the up arrow in the notification area to display the hidden icons, right-click the Messenger smiley icon, then select Exit.
  2. On your keyboard, press the key combination Windows + R.
  3. Type cmdand press Enter.
  4. Copy one line at a time from the list of command prompts below, then right-click within the Command Prompt window to paste the command.
    • After pasting each command, press Enter on your keyboard.
Note: If you receive the "The system cannot find the file specified," continue with the next command. These errors are harmless.
rd "%AppData%\Yahoo!\" /s /q
rd "%ProgramFiles%\Yahoo!\Messenger\Cache\" /s /q
rd "%ProgramFiles(x86)%\Yahoo!\Messenger\Cache\" /s /q
rd "%LocalAppData%\VirtualStore\Program Files\Yahoo!\Messenger\Cache" /s /q
rd "%LocalAppData%\VirtualStore\Program Files (x86)\Yahoo!\Messenger\Cache" /s /q
  1. Click the X button to close the Command Prompt.
If you get an "access is denied" error follow this process: Substitute this for step 3 above - Start ' Programs (or All Programs) ' Accessories.Make sure to right-click Command Prompt and select Run as Administrator, and then continue with step 4 above.
  1. Restart Yahoo Messenger.
Jul 30, 2014 | Yahoo Messenger
How do i change my message alert on my sony x10
1)Connect your phone to your computer.
2)Mount your SD Card.
3)If you have PC Companion, goto file manager... if not goto My Computer and open your SD card.
4)Create the following folders "SD Root folder":\media\audio\notifications
5)Unmount SD Card
6)Open Messenger
7)Open Settings
8)Open 'Select ring tone' (You better have notifications already selected...if not...this little list is too much for you to handle.)
9)Select Ring tone, it is labeled however the file was named.
Oct 21, 2010 | Sony Ericsson XPERIA X10 Cell Phone
If you are running yahoo messenger 10, can u switch back to yahoo messenger 9.0 plus, i cannot get my yahoo messenger email alerts to come up at the bottom right side of task bar.
If you wanted to downgrade your yahoo messenger, better uninstall it and install version 9.0
here is version 9. Click it and save to start downloading
1. yahoo messenger 9.0
You can enable the setting of Alerts and Sounds of your yahoo messenger.. to appear a short notification on your taskbar, just follow these steps.
1. Log in to your yahoo messenger
2. On your yahoo window, find the on the top the Messenger menu. Click it and select Preferences.
3. On Category, select Alert and Sounds
4. Click to check the box for "Showing a message at the bottom right corner of the screen.
(you can also enable alert sounds)
5. Click OK.
that's it. I hope that helps.
Please do rate this answer and give me a better ratings.
Thanks for using Fixya.
Aug 26, 2010 | Yahoo Messenger
Im trying to use a email notification system that I downloaded off the internet, and it says that I need to contact my email service provider. The email notification is Incredimail.
What mail service do you use? If you use Gmail, install Google Talk or if Yahoo, use yahoo messenger and for hotmail use live messenger.
Jan 03, 2009 | Computers & Internet
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
