Question about Mercury Boating
Want to find out what year my mercury 50hp serial number a710504
3 Suggested Answers
  • 52099 Answers
SOURCE: where is the serial number on mercury 115hp 6 cylinder boat motor
http://www.marineengine.com/mfr/mercury_models.html
Posted on May 01, 2010
  • 5687 Answers
SOURCE: I have a mercury outboard 50hp engine that will not start
If you are saying the Flywheel is locked or Frozen then I imagine the starter Bendix was found extended and jammed against the Flywheel.
If the motor ran when it was shut off last, then your rings and/or bearings rusted in place. You don't want to grab the prop to turn it because it will strip the Rubber hub.
I would take out all the spark plugs, tilt the engine up as close to level as you can get it and spray WD40 into the cylinders. If you did not have water connected to the engine the pump may have crumbled but if the engine did not turn at all the pump may still be good.
Give the WD some time to penetrate and crank the engine to see if it broke loose. If it did not, you may as well drop the lower unit and eliminate jammed gears with a second try at cranking the engine.
If still no luck, you might try to rig an Air fitting to the Sparkplug holes and hit each with about 80PSI and another squirt of WD. This will force the WD deeper and force the pistons down with no damage.
Still no luck, then its disassemble time. Good luck on this.
Posted on May 27, 2010
I have a 50hp mercury outboard s/n 7115968 want to know what year it is
Can you please double check the serial number. That does not come up as a valid number.
Jul 22, 2017 | Mercury Boating
What year is my 75 hp mercury 4 cylinder serial number 0a986452
Locate the serial number plate by looking on your motor's transom bracket; the plate will have "Mercury Marine" written on the top. The serial number is the top number on the plate. The number directly beneath this is the year it was manufactured.
The year will be determined by the number of cylinders,,,
A 4 cyl. is a 1986 .
75 - 4 Cyl. 1986 ELPTO, ELO A197882 - B249479 = U.S. Serial Numbers A70708 = Canadian serial numbers
Jun 25, 2017 | Mercury Boating
50hp Mercury outboard electrical schematic
Hey David,
Yo should find all the info you need here..this will be very very helpful...' Mercury Outboard Manuals by Seloc 1965 2014
Jun 07, 2017 | Mercury Boating
Evinrude 50hp engine details, year etc service information serial no C64038
model number is what evinrude uses to identify motors call a dealer for assistance
Feb 10, 2017 | Boating
Finding year from a ssrial number on a mercury out bord
go google and type in--- mercury outboard serial numbers -- there are sites that listhp against serial numbers against year of manufacture
while you serial number may not be listed they state that the beginning of the number to the next changing number is the year of make
for example ---4261012 to 4302999 ( next number 48103665,year 2002) may be year 1999 so your number would be a 1999 model
The information provided will take a bit of understanding as it appears that the manufacturer changed the method a number of times
talk with a mercury / mariner service shop as they will have the information on hand
Sep 26, 2016 | Sierra Tilt/trim Motors, Outboard...
Find the manufacture year mercury verado motor
According to i-Boats, "Nothing in the Mercury Mariner Outboard engine model numbers or serial numbers provides year information directly.
The first serial number sold in a year becomes the beginning serial number. Serial numbers between that year's beginning serial number and the next fall into the same year. Search for your engine horsepower on the Mercury Mariner serial number year chart located here to find the beginning serial number for the range that includes your engine." Your other option is to take the serial number to an authorized Merc marine eager and they can look it up for you.
Sep 27, 2014 | Boating
Wat is the spark plug gap fo 50hp mercury two stoke 2009
The plug gap is most likely .040, however can you please confirm your serial number?
Sep 10, 2014 | Mercury Force Tilt Trim Motor, 25-50 HP...
Mercury motor serial number
That serial number is also not found in the Mercury Marine Directory. Are there more numbers or characters?
Sep 08, 2014 | Boating
Mercury outboard s/n 9445826, what year was this motor built ?
call mercury outboard they can tell you the answer to your question
Aug 29, 2013 | Raymarine St6002 Smartpilot Hydraulic...
Boating Logo
Top Mercury Boating Experts
Colin Stickland
Colin Stickland
Mike
Steve
Steve
Are you a Mercury Boating Expert? Answer questions, earn points and help others
