Question about Sony KDS-R60XBR1 60" Projection HDTV
No picture or sound
50" SXRD green power light flashes for a while then red light comes on . I cleaned the fan, still no luck.
  • larryohrberg Jul 25, 2009
    Nothing happens that I can see. The green light comes on and blinks for a while then the red light comes on and stays on.
  • 668 Answers
Does anything start to work? Any of the three fans start to turn, Lamp ignite, etc., when you press the power button or does nothing happen before the Red LED starts blinking. How many times does the RED LED blink?
Posted on Jul 25, 2009
  • Steve Yocum Jul 25, 2009
    It has a Thermal Fuse that is either mounted to the side of the Lamp Housing or underneath it and it is probably bad. The Replacement Thermal fuse will mount to the side of the Lamp Housing. Because the Optical Block must be removed to replace it, I recommend that a Sony Professional repair it. If you need help in finding one, call Sony at 1800-222-SONY and they could help you find one local to you.
    I hope this helps,
    Skyassoc
Sony sxrd picture sound on off
In this case, it will be best to contact any service technician. These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Apr 03, 2014 | Televison & Video
On my 50" sony sxrd
The service manual lists 3 blinks as the light cover not being secure. it has a micro switch behind the cover so if you hold down the switch you can see if this is the problem.
Apr 16, 2011 | Sony KDS-R50XBR1 50" HDTV
Sony SXRD KDS-50A2000 Will not power on. Green
I have the same problem with my unit. I've been removing the bulb and just replace it back and unit will work again. I probably need to vacuum or check the fan out too.
Mar 09, 2010 | Sony KDS-50A2000 50" HDTV
Sxrd 50 won't turn on - Cooling system or dlp lamp?
4 blinks is a fan error, check and see if the fans are clogged with dirt. Unplug the set then take the back off and get some canned air and blow the fans out.
Oct 08, 2009 | Sony KDSR50XBR1 50" Projection HDTV
Sony SXRD (KDS-R50XBR1) fan question
Try to access the self-diagnosis screen. With the TV off, push in sucession, the "mute, then the number "5" button, and then the volume down button, and finally the pwer button. When the picture comes on, there will be a list of different circuits and to the right are numbers which represent how many times that particular circuit had a malfunction. Sometimes the red blinking LED code is itself in error, so this may help to clarify the root cause of your problem. Now, if the TV will not stay on long enough to perform the previous operation, you should consider replacing the large exhaust fan that is in front of the lamp assy. This has been the problem fan in these sets.
michtech
Feb 14, 2009 | Sony KDS-R50XBR1 50" HDTV
I have a Sony KDS-R60XBR2 60" SXRD and the power/standby light has recently starting flashing and the picture and sound blank out. it does it for about 30 seconds and then picture comes back on...
I have a Sony KDS-R60XBR2 60" SXRD and the power/standby light flashes green 96 times than it switches to a RED lamp light that flashes steady. Do you know what it means?
Apr 27, 2008 | Televison & Video
Flashing red light
I think this sounds like my problem (need to replace the projector lamp). However, when I hit the "on" button, my SXRD 50" blinks green for about a minute then starts blinking red. Can you confirm the bulb solution? I was very pleased with this sight when my fan malfunctioned. I got the fan in a matter of day's from Sony and it fixed that problem.
Oct 29, 2007 | Sony KDS-R60XBR1 60" Projection HDTV
Sony sxrd kds-r69xbr1
4 red blinks indicates a fan error. usually blowing duster inside the fan blades will cure this. there are 4 fans inside this tv. looking from the back of the tv, the large fan on the left side is usually the culprit...good luck to ya
Oct 16, 2007 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Sony KDS-R60XBR1 60" Projection HDTV Logo
645 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
