Question about Honda Garden
I have a honda 190 gcv. It won't start after storage there isn't any pressure when you squeeze the tigger to start it either. What's wrong ?
My sister has the same thing hers is just like mine honda gcv 190 psi 3100 won't start after storage either
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,095 Answers
Did you totally drain the gas out of the tank and run the carburetor dry before storing? Did you at the very least put a lot of Fuel stabilizer in the tank and run the machine so it gets into the carburetor? The Carb Jets on these honda engines are very very tiny. They clog very easily if not stored correctly.
Posted on May 02, 2017
  • Brent Stiver May 02, 2017
    No I didn't Can I blow them out with air?
  • wadingriver
    wadingriver May 02, 2017
    The jet it up in the Carb. Air wont get there. If you can get the Carb Bowl off without taking the carb off the engine it would save you time. Get the Bowl off then with a thin screwdriver you need to unscrew the Jet from the center of the carb. The holes in the jet is smaller then one strand from a Wire brush. I have Welding Tip cleaners and the holes are smaller then my smallest tip cleaner. There are several holes in this Brass Jet that you will unscrew.
GCV 190 Manual
hondas website is the place to start.
Aug 18, 2017 | Garden
I have a ryobi pressure washer with the honda gcv 190 and it wont start i got fuel and spark and the switch is on it just dont want to start
Is this a brand new unit or one that you've had awhile? If one you've owned awhile, when is the last time you used it? Did you use a fuel stabilizer or drain the tank and let the engine run until it stalled?
One thing you might try would be to remove the spark plug and give a little spray of carb cleaner in to the plug hole, then reinstall the plug and try to start it. If there's just not enough vacuum to get fuel to the cylinder, getting the engine to fire off the cleaner may provide enough oomph to get the engine started and running.
Oct 08, 2016 | Garden
I need a Honda GCV 190 operation manual that is on a Ryobi 3100 psi power washer
Please click on the link for the operators manual for your engine a Honds GCV190
Hope this helps
Brad
http://cdn.powerequipment.honda.com/engines/pdf/manuals/00X31Z8B0240.pdf
Jul 29, 2014 | Garden
Honda gcv 190
If it begins to catch then you definitely have ignition. Try replacing the plug with same type. If same result, the main jet in carburetor is clogged or the needle valve is stuck and not allowing fuel to enter into motor.
Mar 29, 2014 | Garden
Garden Logo
46 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
