Question about LG Televison & Video
I'm having issue with my lg tv model number 32LN520B. It is stuck zoomed in to the top left of the show. I messed aeound in settings and it on 16:9 like usual but it does not look right.
  • 126 Answers
SOURCE: Getting top off
make sure the power is off. we will try another way. go to the back
there are 2 brackets left and right. take off.slide top forward.this should help. you will then see the clips at the front.
Posted on Dec 13, 2007
SOURCE: Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
Posted on May 30, 2008
  • 133 Answers
SOURCE: Panasonic PT-53WX42F-Stuck in Zoom mode
on the bottom left side of your dish remote, there should be a button that says format, that should help you
Posted on Jan 08, 2009
  • 184 Answers
SOURCE: Blue dots in KDF-60WF655
Yes, your optical block ( light engine) is bad. Heat generated by the lamp circuit with its poorly designed ventilation system, cause the LCD panels inside the light engine to fail. They are the size of a postage stamp. There are 3 LCDs, for red, blue, and green. The heat causes them to warp and de-laminate.
Sony has systematically downed played the scope of this issue. It appears however that virtually every LCD projector they make can develop damage in the light engine which is extremely expensive to fix.
I suggest contacting Sony and your state's attorney general's office of consumer complaints asking for action on this.
michtech
Posted on Feb 20, 2009
trickhunter0
  • 7 Answers
SOURCE: LG 47'' LCD HDTV 120Hz - Incorrect Picture Width
Hi, Dude.
You have to try http://www.wikiebooks.in For the Perfect LG LCD you probebly find it.
Posted on Jun 01, 2012
Hi, I have a LG TV 60PG60F and the screen does not show picture and there is no sound. When turning on the switch, the green lights flashes 16 times. what the issue could be? Thanks for your he
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Oct 29, 2016 | LG Televison & Video
Why does my lg tv seem to be stuck on a zoom setting?
Find the Aspect ratio button on the TV remote. Press it a number of times to cycle through the options. Stop when the picture is the shape you want.
Have a read of your TV manual. Stuff like this is detailed in there.
Check the picture aspect settings in the Uverse set up menus. Make sure the option selected matches the shape of your TV.
Sep 07, 2014 | LG 42SL9000 42 in. HD-Ready LED TV
Jvc lt-47em59 picture too large in all aspect modes
Larger as in -- the screen looks fatter. 4:3 stretched to 16:9 or as in Larger as in, screen is longer but thinner? 16:9 / 10 fitting onto ratio 4:3?
Asuming... its the second one -- that ur screen is box 4:3 and the picture is huge 16:9 which is why u need to "zoom out" to get the full picture -- are u sure some idiot didnt mess with the settings and make the tv "zoom in" if it isnt a aspect ratio issue?
... if it is a aspect ratio issue, and ur using 4:3 (small old box televisions) there should be a ratio setting either on ur television OR on ur set top box, that would by defualt with digital tv have wide screen 16:9 -- id suggest finding the settings either on the tv or the set top box or...
just get a bigger tv that supports 16:9 cheap for 50 bucks.
Mar 17, 2014 | JVC Televison & Video
SHARP AQUOS 46INCH CANT GET A FULL PICTURE ONLY IF I USE ZOOM WILL THE SCREENBE FULL
Hi Anthony,
You're describing what is called letterbox and pillerbox. Letterboxing is when there are two horizontal bars - one at the top and one at the bottom of the screen with a wide picture between. Pillerbox is when there are two vertical bars - one on the left edge and one on the right edge of the screen with a tall picture between.
The settings on your TV (and on your cable box, satellite box, DVD player, etc.) tell the TV how to display a picture that will not fill the screen completely. If the program source (an older video-taped TV show, non-widescreen version DVD, etc) was not originally "shot" or saved in widescreen format, the TV offers you a choice on how to display the image. They ask if they should stretch or zoom to fill the screen (and you have to deal with the skinny / tall images or lost portions of the picture); or maintain the aspect ratio (not stretching or zooming) by leaving a part of the screen blank (grey or black) by inserting bars left and right or top and bottom of the screen.
Start out by telling the devices that send pictures in a format that matches you TV's screen ratio. I am assuming you've got a wide screen HDTV which would mean it should be set to "16 x 9" (a.k.a. 16:9) ratio display. If you have it set for 4 x 3 (a.k.a. 4:3) you should change it. Look for a setting on your TV that asks about stretching, zooming, etc. as this will be an issue when receiving picture from an off air antenna on your house when a TV station is airing an older, non-wide screen format TV show or movie.
TV signals provided by Cable TV or Satellite provider must be HDTV type signals. If you have the standard TV service (non-HD) no picture sent by them will ever fill the screen. This is because Standard Definition TV (SDTV) is not capable of those types of signals. You will have to bump up your subscription to HDTV service to get full screen pictures.
I hope this helps!
Nov 10, 2011 | Sharp Televison & Video
How to zoom in on info
When TVs first appeared, they had an picture ratio of 4:3, which matched that of most movie screens at the time. Terrified of losing their business, movie studios struck back with "widescreen" films using 1.85:1 or 2.35:1 ratios. When widescreen TVs started appearing, they emulated those same ratios, but many TV shows (and some movies) were still in 4:3---and we were eventually left with a bit of a mess. Canny manufacturers, including LG, have solved the problem by allowing you to adjust the picture ratio on the TV to fit the program you're watching. If it's not set properly, however, your image will look distorted or cut off. A quick bit of troubleshooting can fix the problem easily.
  1. Press the "Menu" button on the remote and scroll down to the "Option" title (it should be second from the bottom ). Then select "Aspect Ratio." You should see a list of ratio options. You simply need to pick the one which fits the show you're watching.
  2. Choose the 4:3 ratio for older movies and TV programs. You should see a pair of bars on the left and right side of the screen. (That's okay: the bars keep the program in the same proportion in which it was filmed.)
  3. Select the 16:9 ratio for widescreen movies and for more recent shows to match their longer width. For some movies, you may see black bars and the top and bottom of the screen. Again, that allows the movie to be shown in the manner it was filmed.
  4. Pick "Set By Program" to automatically switch the LG TV between 4:3 and 16:9 to match whatever show is on at the time.
  5. Select "Horizon" to horizontally expand the image onscreen. It will fill the whole screen---eliminating the black bars to the left and the right---but it may look distorted.
  6. Use the "Zoom 1" option to zoom the image forward. That will eliminate the black bars at the top or the bottom of the screen, though you will cut off the edges of the image.
  7. Pick the "Zoom 2" button to select a midway point between "Horizon" and "Zoom 1." The picture is stretched, but not as much as with "Horizon," and fills the screen, but doesn't cut off as much as "Zoom 1."
  8. Use the "Cinema Zoom" button to enlarge the picture to fit the screen. This option allows you to adjust the proportion to your liking, rather than use the set proportions of the other aspect options.
  9. Exit the menu when you are done and watch your programming normally.
Feb 04, 2011 | LG Televison & Video
The left side of the LG 42" plasma TV has no
try to check the aspect ratio and input source to make sure they are correct. for the aspect ratio, make sure it is set either at 16:9 ratio or try the zoom options. if it is set at zoom, you can move the screen left to right or up or down through the zoom settings. make sure you are also using the correct cable. hope this helps
Nov 25, 2010 | LG 42PC3D 42 in. Plasma Television
I just had this problem and got it solved. The issue is that your cable box is likely set to the wrong aspect ratio, so your tv will not be able to display the picture properly without this setting changed. On my cable box(Pace), you need to turn the power off to the cable box using the remote. Then hit the menu button on the remote and a new menu will appear on the screen. Change the aspect ratio to 16:9 and you should be all set. Hope this works for you too.
Feb 22, 2010 | LG 47LC7DF 47 in. LCD HDTV
SCREEN DOES NOT SHOW ALL CONTENT? ESPECIALLY SCORES DURING SPORTING EVENTS.
All LCD televisions, including the Aquos have a ZOOM setting, allowing several different image representations.
They are done because some TV programs are in 4:3 format, some are in 16:9 format and on top of that there are some which are 16:9 pre-modified to fit 4:3 screen.
So the TV has an option to switch between several different modes and I guess you're stuck on one of them, which usually zooms in , cutting in result the outer parts of the screen.
Feb 14, 2010 | Sharp Aquos LC-45GX6U 45 in. HD-Ready LCD...
Toshiba tv model 57HC85
Go to settings and change to 16.9 widescreen
If you use 4:3 or zoom or fit or anything else, it will do that...use 16:9 or "regular".
Jan 31, 2018 | Toshiba Televison & Video
May 29, 2008 | Televison & Video
Televison & Video Logo
Computer Repairing
Computer Repairing
