Question about The Health & Beauty
Gwtting E1 error when the monitor tries tom give the reading. this is blood pressure monitor wgnbpw-520.
  • 2712 Answers
SOURCE: blood pressure monitor problem
The two numbers that measure your blood pressure are written like a fraction: one number on top and one on the bottom. The top number in a blood pressure reading refers to the systolic pressure. It measures the pressure inside your blood vessels at the moment your heart beats. The bottom number represents your diastolic pressure. It measures the pressure in your blood vessels when your heart is resting between heartbeats. A good blood pressure for most people will be under 120/80, as most people with blood pressure problems have high blood pressure. However, extreme low blood pressure can also be a serious health concern.
Posted on Aug 27, 2008
Max J
  • 22 Answers
SOURCE: WITH AUTOMATIC CUFF BLOOD PRESSURE MONITOR GETTING ERROR
E might represents insufficient inflation for your mom. For automatic inflation monitors usually there is a mechanism to keep inflating the cuff to higher pressures for people with higher BP. Check how is done. In some auto monitors,while cuff is inflated you keep pressing on START button until pressure reaches to some 15 to 20 mmHg higher than the pressure that auto usually stops and displays E.
Posted on Sep 08, 2009
  • 4736 Answers
SOURCE: My blood pressure monitor is
Contact the HoMedic's Consumer Relations Dept @ 800-466-3342 Mon - Fri, 8:30am - 5:00pm ET, they can help you.
Keep in mind, that improper placement of the wrist cuff can cause higher or lower readings, than what they truly are. Also, not keeping your arm at heart level can cause an inaccurate reading.
Posted on Mar 01, 2011
  • 4736 Answers
SOURCE: When the blood pressure monitor reads E- error.
It depends on which E-error you're getting.
EE - indicates several things:
  • Cuff has been placed incorrectly. Always place cuff on wrist 1" above heal of hand.
  • Did you talk or move during measurement?
  • Shaking of the wrist with the cuff ON.
E1 - Air circuit abnormality. Measure again.
E2 - Inflation pressure exceeding 300 mmHg. Switch the unit OFF.Wait 1 minute, then measure again.
E3 - Error determining measurement data. Measure again.
Hope this helped you to determine which Error you're receiving. Please let me know.
Posted on Apr 30, 2011
Testimonial: "This helped. Thank you."
  • 4736 Answers
SOURCE: what does E1 on the screen mean? t happens when
The E1 Error symbol indicates an air circuit abnormality. Try measuring again.
If it continues contact HoMedics Customer Support 1-800-466-3342.
Hope this helped you and thanks for choosing FixYa.
Posted on Aug 19, 2011
My Blood Pressure comes up with E1 - what does this mean?
An E1 error can mean a number of things depending on the brand of your monitor and the way that you are trying to take your blood pressure. The general reason for E1 errors is to announce for whatever reason that the machine could not get a blood pressure reading.
Some common causes:
You did not let all of the air out of the blood pressure cuff before trying to take your blood pressure. Make sure that there is no air in the cuff by squeezing it or rolling it, prior to use to let out excess air.
Your blood pressure cannot be taken at this time. Sometimes this occurs if you are very nervous, overly excited, or have a fast heart rate. You can try sitting down and relaxing prior to taking your blood pressure.
You are using the wrong size cuff. If you are taking blood pressure on a small child, someone with a tiny arm, or someone with a large arm, the blood pressure cuff might not get an accurate reading. Many blood pressure monitor manufacturer's offer blood pressure cuffs ranging in size from small to extra large, and you should use the cuff that is most appropriate for the size of your arm.
You didn't line up the blood pressure cuff correctly on your arm. You can't just slap the cuff on your arm and expect it to work, it has to be lined up properly. Many companies put an arrow on the cuff to give you an idea with positioning.
You need to try a different spot on your arm. Occasionally some people cannot give a blood pressure reading on their upper arm for a variety of reasons, and you should try getting a reading on your lower arm.
If you are still having trouble with your blood pressure cuff, take your monitor with you to your next doctors appointment so that your doctor can show you how to use the monitor correctly.
Mar 27, 2017 | Health & Beauty
What does E1 error message mean on a Walgreen machine?
IT happens when trying to check blood pressure. The E1 error symbol indicates an air circuit abnormality.
Try Measuring again.
Oct 16, 2015 | Health & Beauty
Reset Walgreens BP cuff model wgnbpw-520
Press user select to choose 1 or 2. Press the M button to pull up memory and then press both top buttons at the same time to clear. Display reads CLA if done properly.
Jan 18, 2012 | Walgreens By HoMedics Automatic Wrist...
Ei eror message
If you have a wrist monitor the E1 error code indicates an "Air circuit abnormality". Solution: Measure again. If this continues to occur, contact HoMedics Customer Support 1-800-466-3342.
Sep 04, 2011 | Walgreens By Homedics Automatic Blood...
E1 error
E1 indicates an air circuit abnormality. Wait one minute and try inflating the cuff again. If the problem continues, contact HoMedics' Customer Support 1-800-466-3342.
Hope this helped and thanks for choosing FixYa.
Aug 25, 2011 | Walgreens By Homedics Automatic Blood...
What does E1 on the screen mean? t happens when trying to check blood pressure.
Aug 19, 2011 | Homedics Automatic Arm Blood Pressure...
When the blood pressure monitor reads E- error. What is the reason? Not keeping the wrist still?
Apr 30, 2011 | Walgreens By HoMedics Automatic Wrist...
We have WGNBPW-510 Automatic Blood Pressure Monitor Wrist and can't find the instructions. We need to erase the values that are on them and start fresh. How do I erase the monitor values?
To delete the history first, press the User-Select Button. Then press and hold what looks like a tiny button clock and the + button to the right of it at the same time, while in memory recall mode and the data for that selected user will automatically be erased.
Hope this helps you.
Apr 25, 2011 | Walgreens By HoMedics Automatic Wrist...
Get directions on life source 767 monitor
Would suggest you try looking in the manual section of www.retrevo.com
Feb 25, 2011 | Life Science Life Source Blood Pressure...
Health & Beauty Logo
24 people viewed this question
Top The Health & Beauty Experts
Dave Jacobs
Dave Jacobs
Level 1 Expert
Ajika coates
Ajika coates
Are you a The Health and Beauty Expert? Answer questions, earn points and help others
