Question about John Deere Garden
NEED PART NUMBER FOR LEFT DOOR HINGE FOR JOHN DEERE 5420 LOWER HINGE.
    New Friend:
  • 48 Answers
Go to johndeere.com you can look your parts up
Posted on May 15, 2017
  • John Deere Master
  • 7,515 Answers
Don't worry I'm sure you will get the solution of your problem, just check the link I attach.
Best Manuals
DOOR HINGE 5420 J.D. LEFT
this is fixya either john deere dealer or online search
Apr 30, 2017 | John Deere Garden
How to adjust clutch on John Deere tractor model 5420
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Feb 21, 2017 | John Deere Garden
5420 john Deere cab tractor. The wire # 012 coming to the switch is not hot. Where does it come from. Is it fused?
Best Manuals
Feb 20, 2017 | John Deere Garden
Where is the serial number located on a john deere 510d backhoe..so i can find out the year of the backhoe
Diane, JD 510D VIN# Location: On older models plate is attached on outside of frame behind either left or right front wheel. On newer models VIN plate is attached just above left (Highway) side cylinder arm. Same location as Caterpillar. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://cppsocal.org/wp-content/uploads/2014/04/Heavy_Equipment_Catalog_Vol_5.pdf
https://www.oswca.org/uploads/combatting-heavy-equipment-theft-2015.pdf
Thread where is Serial number for 1977 John Deere 510 hoe
Serial number plate location for john deere 510d backhoe Google Search
Jun 20, 2016 | John Deere Garden
John deere 3140
cat converter plugged
Aug 06, 2014 | John Deere 5420 Tractor
John deere 5420
What the problem?
Jun 07, 2013 | Garden
Can u tell me what size of hydrolic pump is fitted to 1850 john deere tractor
There are 3 pumps that were used on this model.
Part number is:
AR103035
alternate / sub PN: AL70641
This 8 piston 11.3 CM3 pump is rebuildable at a fraction of the cost of a new or re-manufactured pump.
http://cheaptractorparts.com/store/product5697.html
There are 6 kits for this pump depending on what has failed on the pump.
Kits
AL71015
AL71016
AL71017
AL71018
AL71019
AL71020
The John Deere Parts catalog can be found here using you model number:
http://jdpc.deere.com
Pump PN: AR103036 23CM3=1.4 CU.IN
and
Pump PN: AR97872 40CM3=2.4 CU.IN
All of these pumps can be repaired. It just takes a talented and patient person to do the repairs with kit parts in hand.
Thanks for choosing Fixya,
Kelly
May 01, 2011 | John Deere 5420 Tractor
Will not hold RPM. changed air and fuel filters, whit no change.Engine RPMS go up and down even sitting still.
hook up a vacuum gauge to the engine intake vacuum port then: while the engine is running look for a vacuum leak.
Aug 01, 2010 | John Deere 5420 Tractor
Right door is lower than the left how do i level doors
if the door is slightly off u need a shim that will fit or a couple of small washers over the lower door pin remove food from door and with help from someone -to help in removing door and replacing it - at the top of the door u will c the upper hinge pin remove cover if one remove the 3 hold down screws while supporting the door remove hinge lift door off lower pin place shims or washers on lower pin till desired height not more than 3/8 is advisable place door on if still to low remove door and remove lower hinge and slightly give it a bend or leave on and slightly bend up hinge when desired height reached replace door and reattach top hinge
Sep 24, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Garden Logo
19 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
