Question about Boating
My jensen ms2a marine radio will not stay paired with iphone
5 Suggested Answers
Ajkill
  • 2035 Answers
SOURCE: Jensen MSR4050G Sirius Ready marine radio
Sirius Mode Selection
While in Sirius satellite radio mode, press S-MOD (22a) (also the SHIFT/SCAN button) to select
from four available modes: Normal, Category, Direct Tune and Set Skip Channel. When the
Category or Set Skip Channel modes are selected, the corresponding icon appears in the display.
When the DIrect Tune mode is activated, the alphanumeric display appears.
Click on this link to get the user manual:
http://www.asaelectronics.com/techpdf/MSR4050G%20Owners%20Manual%207-11-05.pdf
good luck...
Posted on May 19, 2008
I had the same problem and there are a couple of reason why you may not be able to get into Sirius Mode.
  1. You have the wrong type of antenna (it must be a Sirius approved antenna)
  2. You may not have installed the tuner (most Sirius ready units need require that you have a tuner hooked up to your unit to get satellite reception. The tuners are specific to your unit, so make sure you but the correct one. This is quite sneaky on Sirius’ part…but good luck).
Posted on Jun 25, 2008
SOURCE: Can I buy the face only to the jensen marine mcd 5110
Do you still need the face plate for a 5110? I have one with case. if so e-mail me @ r.ruditz@att.net
Posted on Jan 01, 2009
  • 910 Answers
SOURCE: i am replacing an old
I presume from this that you've only got 2 speakers installed (4 wires) and the other 2 wires are the supply?
What are the Model Nos of the old Sea Worthy & new Jensen Radios?
Posted on Jul 23, 2011
My Jensen MCD 5110 Marine radio acts like the antenna is unplugged. I can't figure out how to remove the radio from it's sleeve to re-plug the antenna jack (if that is the problem)
I don't know much about marine radios. I am a ham radio operator, but they are much the same, if you do not hear any static (with squelch control turned down), then I suspect you are correct about the antenna. It could be the antenna itself, or the coax line to it, or the connection point at the radio or at the antenna. You're stuck without being able to remove it. If you do and find nothing at the radio, you'll need to check the connection at the antenna etc. Good luck.
Nov 21, 2014 | Jensen Mcd5110 Marine Radio /am/ Fm/ Cd...
I can't pair my iPhone 5 with jensen vm9725 I need help
On the jensen go into the setup menu and turn on blue tooth
Dec 20, 2013 | Cameras
Can't get my iPhone to Pair with new Jensen SMPS-650
Hold botton down until it flashes blue AND then red it will continue To flash now pair ur headset
Dec 09, 2012 | Jensen Bluetooth Wireless Stereo Speaker...
Why wont my iphone play video through my jensen vm9114
you need av input adapter its 3.5mm male to rca etc ... then iphone to video rca etc.... and viola
Aug 03, 2012 | Jensen Brand New Vm9114 7" Touchscreen...
The volume wont go higher than 12 on my Jensen Mcd5110 Marine Radio/am/fm/Cd receiver W/Detachable face, how can I fix it to go all the way up to 26 plus?
take off the bottom cover ,find the volume switch on the outside then find it on the inside.Now get some WD-40 and spray the control on the inside with a very,very light squirt of WD - 40. Let it set for a while then try it.It should work.
Jul 09, 2012 | Jensen Mcd5110 Marine Radio /am/ Fm/ Cd...
HOW DO I FIND REPLACEMENT FACE PLATE & REMOTE FOR JENSON MODEL #DV2007
Here is where to get a replacement waterproof remote - http://www.jensenmarinedirect.com/jensen-waterproof-wired-remote-control.html With these marine radios the faceplate is usually the first thing to fail from water damage. Not that your is water damaged but because of this finding a used one is impossible on the net. You will have to contact Jensen for to see if they have the faceplate available separately. http://audiovox.com/jensen/ Good luck.
Regards, Tony
Apr 14, 2011 | Jensen Car Audio & Video
Just bought a used 2004 with handsfreelink. tried pairing my iphone 4 to it by following directions with voice commands and 4 digit passcode. system wouldn't pair and can't get radio on in any mode(cd,...
When you try to pair your iPhone 4, what message does the iPhone prompt you after you enter in the passcode?
Have you tried making sure your iPhone was disconnected from any other headset around you?
Mar 07, 2011 | 2004 Acura TL
Pair iphone to auto
first try pairing from the iPhone, after setting the radio to 'listen'.
if that fails, do the oposite, set the radio to search for devices, then try connecting with the iPhone.
if both fail, upgrade your iPhone software, it helped me. also, your car radio may have a firmware update (many do). Older one throug a CD, rest SD card or similar...
Jan 25, 2010 | Apple iPhone 3G
Wiring for the radio wires
most head units are: black=ground red=battery + switched orange=illumination yellow= battery constant + (for clock) blue=remote turn on for amps/eq/power ant...etc. then the green pair, purple pair, grey pair, and white pair are the speaker outputs. I am not sure if this is the color scheme Jensen uses, but I think it's mostly universal.
Jun 13, 2009 | Jensen Car Audio & Video
Looking for a store in pei canada
TRY A MARINE SUPPLY STORE...THEY USUALLY CARRY JENSEN MARINE RADIOS AND CAN ORDER EVERYTHING ELSE....OTHERWISE BUY ONLINE.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_aad3edb7dfa380b9
Mar 28, 2009 | Car Audio & Video
Boating Logo
108 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
