Question about Garden
Did some oiling service on my ride on mower and now some how the motor start with out the all safety devices
STIGA Garden about 8 years old
SOURCE: my stiga estate ride on mower is not starting
Sounds like you need a complete tuneup.This involves ignition ,carburetion, and fuel lines. Its called preventive maintenance.Good luck.
Posted on Mar 25, 2009
  • 109 Answers
SOURCE: engine stalls when clutch/brake pedal is released
Under the seat, there is a operator presence switch, if this switch fails, the mower will shut off when the brake is released, or put in any gear.
Posted on Apr 23, 2009
redbeard00
  • 957 Answers
SOURCE: Backfiring engine on start up
Could be anything. An air leak between carb and motor, wrong jet settings(air fuel mixture), choke adjustment, water in gas, and more.
Posted on May 06, 2009
  • 24 Answers
SOURCE: Craftsman riding mower starts rides a few minutes then stops
Make sure that when you check the oil that the mower has sat I say for at least 5mins. Your mower might have an oil sencer. If not I think it might be the coil gettin hot and shorting out.
Posted on Aug 23, 2009
mowerman1857
  • 389 Answers
SOURCE: Smoking Craftsman Riding Mower
1st thing, check your dipstick up inside the cap part of it and make sure the O'ring is there and in good condition.
2nd, make certain when you put it back on that you get it on straight and firmly seated. They will only seat one way properly the other way creates a leak into the crankcase and causes oil consumption and smoking. You should be able to tell if it has been improperly installed by an excessive amount of oily dirt accumulated around the threaded area of the cap
Posted on Sep 15, 2009
How do I fix my Murray riding lawn mower? The motor will not fire;
coil,safety switches,ignition switch,fuse,connected wrong,,,choose 1 to eliminate then go to the next,etc,,,etc,,
pull the black wire off of the coil,try to start,if it works,the safety switches(1 or 2 or 3 out of 3)are bad,seat,brake/clutch,deck switches,if not,then the coil is bad,pull the ign switch out,clean all contacts on back and plug back in
May 25, 2015 | Murray Garden
I need a stiga belt configuration
Matty, which Stiga mower have you got? also is it hydraulic or manual transmission?
Apr 20, 2014 | Garden
Finding replacement belt from UK for McCulloch hornet ride on mower
Just in case anyone else comes across this in searching for a Main Drive Belt or a Deck Belt :-
Marksman Industrial Ltd
Main Drive Belt 1134.9013-01 (see also 9585-0057-00)
External length 888 mm
"STIGA 1134-9013-01 Equivalent Belt" Kevlar reinforced
Deck Belt 1134.9032-01 (see also 9585-0075-00)
External Length 1219 mm, Pitch Length 1206 mm
4L480K - 1/2" x 48" Kevlar reinforced
Note:
Stiga Garden Combi is pretty much an identical mower
Hope this helps someone.
Aug 01, 2012 | Garden
Mower suddenly shut off and engine starting smoking. Now it won't do anything. seems to be locked up. Sears craftsman riding mower only 1 and a half years old. has oil and gas.
About the first thing I would do is to pull the plug lead(s), tilt the mower up (resting it on something solid) and see if the motor shaft could be turned at all. I suspect you initial thought that it is locked up is correct.
May 15, 2010 | Craftsman Replacement Belt for 42" Deck
My stiga estate ride on mower is not starting
Mar 25, 2009 | Garden
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
