Question about Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Sony Bravia KDL-52W4100 one day horseplay lead to
one day of horseplay lead to a ball striking the upper left hand side of the crystal screen, and cracked it. the TV still turns on and displays a picture okay except when red comes on the screen. Help?
KDL-52w4100 won't turn on and LED blinks 6 times
Bus clock and/or data lines low at power on. 6 blinks of standby light denotes this. Actually, it should be a motherboard problem. Your TV need a thorough checkup before confirmation. If you wish to get more details about the blinking codes to Sony TVs, check this link.
Feb 19, 2013 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
I have a KDL-52w4100 sony flat screen and there are vertical and horizontal boxes on the screen
That is usually an indication of an issue in the left and right inverter boards or a beginning of main panel failure. In either case I would replace the inverter boards first. not too expensive. If that fails than you are looking at a panel replacement, that is minimum 600,00 dollars for the part.
Good Luck Ed Pinero
Feb 03, 2013 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
I have a Bravia KDL-52W4100 and the screen is starting to flicker when watching TV or DVD's, but not when I am in one of the Menu's.
I have seen about a dozen questions here in the last ten days with several models with the same type of problem, Sony of course says they are not aware of this issue---typical for them to deny until smoke turns to fire.....
Oct 31, 2012 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Sony bravia KDL 40s4100 vertical lines on left
LOD (lines of death) are a known service issue with the Sony bravia line of TV's contact Sony and cross your fingers. Wish I had better news for you. I had a 52w4100 and Sony arranged me with a service center to get it taken care of.
Aug 18, 2012 | Sony Bravia KDL-40S4100 40 in. LCD TV
I cant find remote for 52" Bravia tv. Can I turn
Yes, you can turn it On-Off by pressing power button on side of tv.
Required tv remote for KDL-52W4100 is available at Remotes.com
Hope these info will help you.
Thanks.
Nov 05, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
We need our Sony 52W4100 Bravia screen replaced. What is the cost?
Sony BRAVIA KDL-52W4100 52 in. HDTV LCD TV
Part # 1-802-791-12, cost approx $2,251.54 + core
Parts reference: Andrews electronics, 800 289 0300.
May 01, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Good day, I am all of the sudden getting double vision and a white line across the screen, it eventually goes away, not sure if it may be my directtv reciver?
This is a common problem for Sony BRAVIA KDL-52W4100. You can reconnect the LVDS cable to the Main board, the location # is CN4701.
Apr 19, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
How do I reset a Somy bravia KDL-52W4100 back to factory default settings?
While holding down the UP arrow key, press the power button. The TV will turn off and back on and reset to factory default settings. Hope this helps
Jul 05, 2009 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Sony BRAVIA KDL-52W4100 52 in. LCD HDTV Logo
345 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
