SOURCE: minolta dimage 7i fix
I just found a solution to my camera problem. It turned out to be the batteries. We purchases some Rechargable Duracel with a 2650mAh rating. After charging the batteries I put them in the camera and it started right up and was taking photos like when we first bought it. I have not been able to use the camera in almost 2 years and it turns out the problem was weak batteries.
So anyone that has a Minolta Dimage 7i and cant get it to turn on make sure you have at least 2650mAh rated rechargable batteries. The higher the mAh rating the better.
Hope this helps someone else. We are ecstatic that we can use our camera again. No more using my camera phone!!!
SOURCE: Loud Pop, blown Breaker
Pull the unit away from the wall and inspect from rear. However, if all is fine, perhaps you simply overloaded the circuit that once. Were you running any other appliances (overhead microwave) at the same time?
Your defrost system is bad. Replace the defrost thermostat and defrost heater in the freezer.
SOURCE: Heard a loud pop and picture went out. Still have sound
Ur tv have burns capacitors,look for pop ups caps.
