Question about Sewing Machines
How do I get a continuous hem on slacks with my blindstitch hemmer? It skips stitches after going over serged seams.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 6 Answers
See if your pressure foot is touching the machine tightly to move the hemmer more steadily. There is a release button on top of the machine push it down if it is up. Hope this helps.
Posted on May 01, 2017
Testimonial: "I do not see a release button. The only thing on top of the machine is the thread tension guide. Could you be more specific as to where the button is?"
  • Clarice Bornschein Oct 08, 2017
    What is the make of your machine?
How to do blindstitch hem with a pfaff 1035. I have the blind stitch foot
You need to also have a blindstitch stitch on your machine. It looks something like this:
-------V--------V--------V-------
The straight stitch segment is stitched on the hem fabric, but the V portion zags over and catches a couple threads in the fold on the wrong side of the garment fabric.
Blind Hem Stitch with sewing machine Make It and Love It
Feb 22, 2017 | PfaFF Sewing Machines
DOES THE TACSEW T1718 MACHINE SEW IN A ZIG ZAG
Does it have a Stitch Width control? If not, it is probably a limited stitch only. Most Tacsew machines are made for high speed industrial sewing and frequently are made to perform a limited number of stitches. It appears this is a blindstitch for hemming.
Tacsew T1718 4 Full Size BlindStitch Hemmer Machine 1718 TAIWAN 8mmLift 3...
TACSEW T1718 YouTube
Oct 26, 2016 | Tacsew Sewing Machines
How to adjust timing for Rex blindstitch hemmer
As long as your machine is not skipping stitches the timing should be fine. Three things to check: take your thread tension assembly apart so you can remove the discs and clean. Debris often gets between them and causes irregular tension. Next check the point of the looper to see if has a burr. If so take 600 sandpaper or crocus cloth and remove. Last-Check the upright pin that the looper passes--it too may have a burr.
Mar 24, 2015 | Rex RX-518
How do I do the skinny narrow hem stitch
Blind hem or straight stitch with 1/8" or 1/4" hemmer foot. Fabric inserted into right-hand "tunnel". Always do a regular backstitch, forward stitch before inserting your fabric in. Makes it easier! Happy sewing. Suggestion: make miniature copy of your manual and you can always have it handy for reference. Jimmy
Apr 03, 2012 | Sewing Machines
I am doing some sashes for a wedding and i want to know on my serger 14SH654 ultralock how to do a rolled hem
A rolled hem on any overlocker is formed by using the right hand needle only, and the two loopers to form a narrow three thread seam. You also need to retract the seam width finger as Trial2962 said. This is a little finger that sits on the stitching plate and the loopers form the stitching over it. By retracting it, the looper threads can form a narrow seam and in fact, roll the fabric inside the seam. You need to move the cutting blade as far right as it will go so you are trimming as wide as possible from the needle, turn the tension on the top looper rigth down to 2 so it is very loose and this thread wraps around to the underside. And tighten the lower looper tension to about 7 so it hardly shows and sits right up against the needle thread. Adjust and test until you get the seam looking like this, then turn the stitch length dial (on the right side by flywheel) down to 0.5 to close the seam right up tight. Lastly, if you can source it in the right colour, buy woolly overlock thread and run this through the upper looper only, this thread is fluffy and when not under tension, relaxes and "fills" out so the seam appears like a continuous coverage over the fabric.
You will need to practice a few runs and go slowly on corners, a curve is obviously much easier to serge than a right hand cover so if you can, cut the fabric with curved ends, much easier to get a great finish. When you chain off at the end, you need to unravel the tail threads and pull them inside the seam for a few mm with a needle to get a smooth finish, then trim the tail and seal with a drop of Fray Stop.9_26_2011_11_26_51_pm.jpg
Sep 04, 2011 | Singer 14SH654
Need a downloadable instruction manual for Rex RX-518 blindstitch hemmer sewing machine please!!
No luck findong your but Go to www.reliablecorporation.com. Under products check out the MSK555 blindhem machine. It is the same as the Rex 518. To the right of the page is a category to download the manual. It is very helpful.
Good luck
Thanks
Apr 11, 2011 | Rex RX-518
Skipping stitches on coverstitch machine
To avoid skipped stitches on a coverstitch machine you need to use ELs (extra long) or SUK (stretch) needles and good quality thread. Poor quality thread is too fluffy and varies in thickness which can cause stitch problems. Try Maxilock thread from a cone or use maxilock on looper and regular sewing machine thread through needles and see if this improves the stitches. Also loosen off the lower looper tension to zero and see if this helps. If you are hemming around a garment and sewing across an overlocked seam then you need to minimise bulk too. lightly press the seams into the diretion you want them to sit when garment is finished, press the hem up, then force the seam allowance in the hem turnup area to the opposite direction. This spreads the seam bulk in both directions.
There is a knack to coverstitch machines but a good cover finish is quicker than twin needle on SM.
Apr 04, 2009 | Janome 900CP
Coverstitching on White Speedylock serger
Your machine cannot do a cover stitch. Check the Brother website, they make a cover stitch only machine, it works much better than any of the serger/cover stitch combination machines, and it is a lot less money.
Nov 19, 2007 | White Sewing Speedylock 1600 Mechanical...
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
