Question about Garden
How to hook up fuel lines on a still ts420? - Garden
2 Suggested Answers
  • 3828 Answers
SOURCE: Still ts420 concrete saw fuel line placement?
its a stihl chainsaw motor adapted into a concrete saw
Stihl Ts420 Parts
shoudnt have to take too much apart
take off air filter cover to see the carby
Posted on Apr 30, 2017
Stihl Ts420 Parts
Apr 30, 2017 | Garden
Ts420 chop saw fuel in crankcase and exhaust E
Hole in the piston or a badly scoured cylinder wall or broken rings
Apr 19, 2017 | Garden
Why Do I Not Have Any Spark From The Ignition Module When Spark Plug is in The Cylinder
Search Results
    Stihl TS400 / TS420 Ignition Module Repair - YouTube
    ? 7:06
    https://www.youtube.com/watch?v=AvPv88SELXs
    May 1, 2011 - Uploaded by donyboy73
    Learn HOW TO REPLACE The Ignition Module in your StihlTS400 / TS420 ... I have a homelite 33cc Ranger it has no sparkat the plug but if I put a ... a good spark and there is fuel getting into the cylinder head also what are ...
    All comments on Stihl TS400 / TS420 Ignition Module Repair
    https://www.youtube.com/all_comments?v=AvPv88SELXs&lc...
    Donyboy73, I hava a Stihl TS 420 and just replaced the pull rope (not sure what's ... a good spark and there is fuel getting into the cylinder head also what are your ..... Hi mate, i have no spark to my plug?? i have tried a brand new plug and still ...
    Small Engine Ignition: Ignition Wires, Chainsaw Spark Plugs ...
    www.hlsproparts.com/small-engine-ignition-parts-s/149.htm
    66 results - HL Supply has the small engine ignition parts that will get your ... parts right here: ignition wires, chainsaw spark plugs, ignition coil sets, ... Please don't hesitate to contact us if you have any questions. ... Stihl TS400 (3-bolt old style), TS460 ignition coil with wire and cap ... Fits: Stihl TS410 and TS420 cut off saws
Feb 08, 2016 | Stihl TS420
My stihl ts420 muffler screws won't tighten
possible over tightened and cross threaded
Feb 26, 2015 | Stihl TS420
Ts420 when you try to prime it gets tight with no fuel going into carby. primer is pumping fuel
check the primer base isnt blocked, check carb diaphragms, replace if necessary and clean carb.
Apr 02, 2014 | Stihl Garden
Stihl saw cuts out when machine is tilted forward on ts410 anybody else have this problem
Fuel pick up will be your problem. Buy new fuel filter and fuel line from in tank to carby. Most likely a split in the fuel line in-tank
Feb 13, 2014 | Stihl Ts410 Ts420 Cut Off Saw Piston Kit...
Craftsman chainsaw fuel line and fuel filter
go to sears and purchase the fuel filter and fuel line kit for the chainsaw. in that kit will have a hook that you fish through the outside of the tank to the inside, you attach the new fuel line after attaching the fuel line to the fuel filter, to the hook, then pull it through the hole. disconnect the hook from the fuel line, cut the small piece off where the hook made the hole and attach to the carburetor. finish by pushing in the fuel filter inside the fuel tank. the kit will also have more detailed instructions and possibly with illustrations. if sears doesnt have the kit, check with a lawnmower repair shop.
Sep 19, 2012 | Craftsman Garden
Stihl madel ts420 how to change air filter
There are 4 torx screws on the black back cover. Here is the owners manual. It is explained on page 33.
Stihl TS420 owners manual
Jun 22, 2012 | Saws
Replaceing fuel line in polan 3300 chain saw
Hi owjbhend...
Use a piece of wire and insert it into the fuel line, then bend a hook in the end and hook it over the end of the fuel line...lubricate the fuel line with some vaseoline very lightly...about the first one inch of the fuel line and then use your fingers to start the fuel line into the tank, once you have the fuel line in the tank give enough to hook the fuel filter to and so it can be dropped back into the tank.
Below is a drawing of how to route the fuel lines.
Please take time to rate me thumbs up
Sep 16, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Fuel lines
usually there where 3 lines from the gas tank one is the breather,main line,and the reserve line..just try to trace the line
Sep 01, 2008 | 1996 Oldsmobile Achieva
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
