Question about Refrigerators
Freezer keeps freezing over in back panel and air cannot flow to refrigerator side
  • 1314 Answers
SOURCE: Frigadaire freezer cold but fridge compartment is warm
i need the complete model number to narrow it down they still make the frs20zrg to this day the last two numbers like frs20zrgwo or frs20zrgw9 is what will tell me what kind of defrost system it has the serial plate is in the fridge side up by the light bulb or on the left hand side or right hand side of the fridge compartment up near the top sorry to be a bother but its necessary
Posted on Mar 30, 2008
  • 1122 Answers
SOURCE: Refrigerator freezes up
PLEASE DISREGUARD GUEST FIXYA SOLUTION,FREEZER PROBLEM PROCEDURE IF NOT DEGITAL,FIRST CHECK IF ICE ON BACK FREEZER WALL. STEPS-FIND DEFROST TIMER,BOTTOM FRONT ,BOTTOM BACK, INSIDE FRIG.ON CONSOLE,LISTEN TO SEE IF FAN IS RUNNING IF SO TURN THE DEFROST TIMER CLOCKWISE TILL YOU HEAR A CLICK SEE IF FAN TURNED OFF IF SO YOUR FREEZER IS IN DEFROST,FREEZER WILL COME OUT OF DEFROST IN 20-30 MINUTES IF IT DOES AND THE FAN COMES ON YOU HAVE ELIMINATED DEFROST TIMER&FAN,NEXT REMOVE BACK PANEL TO FREEZER IF THERE IS ICE FORMING REMOVE BOTH LEADS TO HEAT AND CHECK WITH VOLT METER ON OMES,IF YOU GET ANY READING THE HEATER IS GOOD,IF NO READING REPLACE HEATER AND CLIPON TEMINATOR,IF HEATER IS GOOD DEFROST COILS WITH HAIR DRYER TOP TO BOTTOM AND THIS WILL ALSO CLEAR THE DRAIN,IF EVERYTHING CHECK OUT GOOD DEFROST TIMER ,FAN ,HEATER, DRAIN, YOU NEED ONLY TO REPLACE THE LITTLE ROUND CLIP ON TERMANATOR,LET ME KNOW-MIKE
Posted on Jun 17, 2008
  • 105 Answers
SOURCE: Hollow ice cubes and refrigerator freezer drip pan is freezing
The drain at the bottom of the evaporator on the freezer rear wall is blocked up. Ice may have gotten so far up the side of the evaporator that it is blocking a return air duct which is located there. You need to completely deice the freezer and then **** out and purge the drain hole on the bottom of the evapotrator with hot water and a turkey baster.
Posted on Apr 09, 2009
jumptrout51
  • 3361 Answers
SOURCE: Refrigerator side temp keeps dropping below freezing.
Set the freezer temp control to MAX cold and see if it improves.
If not replace the off/on thermostat.(cold control)
Posted on May 24, 2009
Controlfrk
  • 304 Answers
SOURCE: 1999 Frigidaire Refrigerator
Check rear wall of freezer by feel for frost. Heavy, even frost indicates likely problem in the defrost system. Unplug unit. Defrost heater (in freezer behind rear wall panel), defrost thermostat (same area-must be checked at freezer temperature) or Defrost timer-located lower back outside of unit. Near compressor. Do continuity test on heater and defrost thermostat and if they show continuity (good), replace defrost timer. If not, replace the one that tests bad.
Defrost coils fully. Reassemble.
Please let me know if I have helped with comments and rating.
Refrigerator will work about 7-10 days after being defrosted until thick frost builds up again cutting off air flow to both compartments
Posted on Sep 08, 2009
Fridge Freezes Everything
there is a motor with a flapper that opens and closes to keep your temp correct in the refrigerator side most likely the motor is bad and stuck open so your air from the freezer has constant flow to the refr side. the flapper is in the back of the refr behind a cover where the air flows in.
Apr 16, 2014 | Emerson Cr180 1. Cu. Ft Compact...
We have had sears tech's here 3 seperate ocassions. They replaced a circut board, thermostat, and heater on 3 seperate occasions. Today I noticed the refigerator getting warm, looked and the freezer side...
you have an airflow problem in the freezer. Is something blocking the vent in the freezer compartment? cold air is produced in the freezer section and flows to refrigerated side through air vents. If they are blocked, the air cannot flow from the freezer and it will freeze over. Not a major problem, just move your stuff around.
Nov 24, 2010 | GE GSH25JSTSS Stainless Steel Side by Side...
FREEZER KEEPS FREEZING UP THE DEFROST HOLE AND KEEPS LEAKING WATER IN THE REFRIGERATOR EVEN WHEN THE FREEZE IS EMPTY NOT BLOCKING AIR FLOW
Good day,
Common problem on Whirpools.
The drain hole is only the beginning. From there it goes to a cup in the fresh food compartment, where it travels thru a boot to the outside of the machine,then down to the drain pan.
That all has to be taken apart and cleaned completely. Just getting it open is not god enough.
As well, even though you can't see it, that hole in the freezer, is part of a large aluminum panel that runs up the back of the freezer coil. Ice will form on the back side of that panel, and cannot be seen.
The only solution is a 24 hour shutdown, unplugged with both doors open. Better with a floor fan, positioned to blow air into the freezer compartment.
Long and ugly, but it works.
Thank you for using FixYa
Jan 23, 2010 | Kenmore Refrigerators
Freezer and icemaker freezes, jams.
I have run into this before and found it very helpful to re-level the refrigerator. By leaning the fridge back toward the wall about an inch helped keep the water and ice in the tray. Remember to remove items that block air flow in the freezer. Remove the ice bin and clean it then start over with the fridge leaning back a little. Hope this helps.
May 01, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Apr 09, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freeze will not freeze.
I had a similar problem. The frost in the back is an indication that your coils are frozen. This could be from food packages falling out of the freezer drawers in the back and blocking the air circulation vents or maybe the freezer door was not closed completely and letting moist/humid air in and freezing the coils.
For me it was the first problem listed.I had to completely empty the freezer and Frig. and take the back panel off in the freezer. There you will see the coils and lots of ice!
1. Remove all items from the frig. and freezer and unplug frig.
2. Pull all the freezer drawers out.
3. On my GE side by side I took the light cover off and removed the bulb. There you will see two panel screws. Remove the screws.
4. Now pull out the mouldings on each side and you should be able to remove the panel.
5. Take a hair drier and completely defrost all the ice from the coils.
Be sure to keep plenty of towels handy for all the water mess. Remember to keep an eye on the drain tray in the back of the frig. and use a sponge to collect the water that will build up.
Hope this helps!.....
Woody
Mar 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Samsung fridge RS2545SH every 7 days freezes fridge coil.
Hey how yo doing? on most refriderator there are two important parts to keeping freezer from freezing over, they are the bimetal thermostat and ice pipe heater. The bimetal therostat is a preset thermostat that ranges from 54degrees farenheit to about 60, when the coils (inside the freezer compartment behind the back panel) reach the preset temp. it closes a circuit and send electricity to the ice pipe heater, to warm the freezer coils preventing from freezing over. if any one of those components fail, your freezer will continue to freeze solid until there is no more space for ice to build on coils decreasing air flow from the evaporator fan blowing air into your fridge.To test you will minor knowledge on using a multimeter.(REMEBER TO UNPLUG REFRIDGERATOR BEFORE SERVICING, IF YOU UNCOMFORTABLE WORKING ON APPLIANCE PLEASE CONTACT A PROFFESIONAL REPAIR SERVICE..) If you'd like to continue please respond.
GOOD LUCK, WORK SAFELY..
Aug 12, 2008 | Samsung RS2630SH Side by Side Refrigerator
Kitchenaid refrigerator w/bottom freezer french doors
please check the air flow to the refrigerator side. it could be a stuck damper motor or damper thermostat. if the fan inside the freezer is running, you should be able to feel cold air coming out off the vents in the refrigerator side. you might have to press the button light switch on the panels to run the fan.
Feb 19, 2008 | KitchenAid Architect KBFA25ERSS Stainless...
Refrigerators Logo
29 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
