Question about Vornado Dryers
Vornado fan dosent do anything. Blade is free spinning and rotates fine.. switch bad?? Fuse????
  • 491 Answers
SOURCE: The fan blade of new Broan range hood is woobling
check bolt holding fan is tight
Posted on Oct 10, 2009
Testimonial: "His quick and very helpful answers decided me do not return the unit to the store and to begin the installation. Thanks again!"
  • 10865 Answers
SOURCE: Switch is broken on my Vornado floor fan, circulating
Hello. Here is the link to Vornado Support. See what a new switch will cost plus shipping before you decide whether to repair or not. http://www.vornado.com/Default.aspx?ISC_PageName=Support
Posted on Apr 09, 2010
Testimonial: "Thanks very much for your help in finding me help for repairing the switch on my Vornado fan. I hope that the store will be helpful. Thank you. "
RyanFanMan
  • 342 Answers
SOURCE: Old Vornado fan model FAI 0013 has a broken
try some black duck tape that might help until you can find a replacement parts
Posted on Jan 01, 2011
  • 670 Answers
SOURCE: i have a vornado 733 floor fan that has suddenly
I would check the line fuse to see if it is blown. It is located in the plug under the sliding access cover. Slide it towards the cord to open. If the fuse is good and you have it less than 5 years, you might be able to get the company to fix it for free since it has a 5 year warranty. 1800 234 0604. Hope this helps you.
Posted on Apr 13, 2011
Testimonial: "slamfix sent great info including 800 number I hadn't seen yet. customer service emailed prepaid shipping label and repair is free. Thanx, slamfix!"
SOURCE: Opening Vornado fan (model EH1) for cleaning
How do I open vornado fan (model eh1)so I could clean fan blades?
Posted on Jul 08, 2011
Soleus Air FSH-40G fan would not start. The bad seems harder to rotate. what could have gone wrong? How to fix?
First unplug the fan for safety. Next add a couple drops of motor oil on the shaft that turns with the fan blade. Tip the fan blade at about a 45 degree angle when adding the motor oil. Spin the blade by hand at that same angle to allow the motor oil to flow down the shaft, inside where you cannot see the shaft. It should start turning by hand a lot easier now.
Sep 06, 2015 | Soleus Dryers
Tip
VORNADO FAN BROKEN BLADE DONT REPLACE!!!!!
My dog knocked off my vornado which then broke a blade off my favorite fan. I was going to use epoxy to try to get the blade to stick back on. This would not work. The fan spins to fast to use glue. I sat and thought about it for awhile and came up with a solution rather then spending 39.99. I used epoxy to get the blade where it should be and let it dry..... then took a hot nail and poked a hole through each blade close to the center of the shaft.... and then took a zip tie and connected each zip tie to each other forming a ring around the shaft. This works very good and if you need to balance out the fan just place a small zip tie on the center and clip off close to the lock. Now you can use the LOCK as a balance for the fan. GOOD LUCK
on Aug 28, 2008 | Vornado Circulating Fan
Vornado very slow
Copied this from someone else who fixed his fan. Tried it and it made a world of difference. Spins free and easy, no more noise.
"I have had the same model for almost ten years, and have had to lubricate it twice - both times when the fan stopped rotating. It's obvious that Vornado never intended the bearings to be serviced, but if you're patient, it can be done. You must remove the front louver section (press the three clips inward gently). Then firmly pull the fan toward the front, off the shaft. Then remove the four nuts on the front of the motor housing - you'll note that the bolts appear to be free-floating, but that allows re-assembly after the bearings are lubricated. When the nuts are removed, firmly pull the front of the motor housing toward you. This may require a firm pull or GENTLE prying, as the rear bearing sometimes doesn't want to let go. When you have the front portion of the housing and shaft out, hold the housing and pull the shaft out of the front bearing. Again, this may require a steady firm pull straight back. When the rotor & shaft are free, you'll need some very fine emery paper to remove the varnish that's built up on the shaft (it's unmistakable where to clean the shaft.) And I never attempt to do anything with the front and rear bearing themselves - too much work, and cleaning the shaft does the job for me. Then clean everything up carefully and lubricate the shaft where it enters the bearings (and maybe a drop in the rear bearing itself.) I use a very fine machine oil that I bought at Sears, but I think any good oil would work. Then, it's re-assembly time - shaft into front bearing, shaft into rear bearing as the motor housing is put back together (lining up the bolts), four nuts on the bolts & tighten (firmly, no gorilla), press fan back on shaft (don't force it too far on - it'll stop when it's in the right place), plug in and check, re-attach front louver (just press - the clips will snap easily into place.)"
Jul 14, 2012 | Vornado Dryers
Where can I purchase a Vornado fan replacement blade for a Type 530 Vornado fan?
Hi carim.
I think this one NuTone S99020165 Ventilation Fan Blade Fits. Anyway, contact the vendor before buying it.
I hope it was helpful.
Enjoy
Jun 03, 2011 | Vornado (CR1-0073-06) Fan
I have a vornado 733 floor fan that has suddenly stopped working after my 2-year old shoved some small, soft toys into it. fan blades spin freely when moved by hand, but the unit appears to be completely...
Apr 13, 2011 | Dryers
Fan won't run at all.
If you plug it in and turn it on, does it "humm".
If so, it is getting power. It could be the blades are stuck on something: do they turn by hand?
The motor could be dirty also, is the blade hard to turn?
It can be repaired by Vornado, or you can dis-assemble the motor and clean it.
Dec 24, 2010 | Vornado Circulating Fan
Vornado Circulating Fan - motor will run but blades will not turn.
Does the motor spin, but the blade is not turning?
The motor has a D shaped shaft. If the hole in the blade that the shaft goes in is rounded, then the blade will spin. In that case you need a new blade. Vornado can supply that.
Jun 27, 2010 | Vornado Circulating Fan
3 speed standing fan. #1 the blade barely rotates.#2 a little faster. #3 it starts slow then speeds up like it's going to take off. It also makes an annoying sound like it's rubbing on something or is...
It is the motor. Probably needs cleaning and lubrication.
You can send it to Vornado.
It is not hard to get apart, just draw a diagram of what color wire is what speed.
You "could" do it yourself.
Jun 10, 2010 | Vornado Circulating Fan
Turn switch on to fan or air and motor just humms but will not start
The fan motor uses a capacitor to turn the motor and if the capacitor is bad the fan won't rotate.If you are handy you could remove the electrical panel and change the capacitor and it will work fine again.I have tested these fans by simply turning the unit on and spinning the fan blade by hand!!! if the fan operates then the capacitor is bad!!
Sep 21, 2009 | Heating & Cooling
Fan stopped. Turned on and spun blade but nothing, on any of the three settings. Bad capacitor? how do I test switch or motor windings with voltmeter? Thank you, Torrey
you can check the switch or motor by using an ohmeter for continuity test. connect the probes on each switch starting from common to no 1, 2, and so on. if the motor is okay, the capacitor is defective.
Sep 08, 2009 | Vornado Air Circulator - Black
Dryers Logo
64 people viewed this question
Top Vornado Dryers Experts
Steve
Ian Summerfield
Ian Summerfield
Mack Baxter
Are you a Vornado Dryer Expert? Answer questions, earn points and help others
