I have in front of me a BOSTITCH ANTIMICROBIAL EXTRA HEAVY DUTY STAPLER. It is out of staples. I have found some staples that look like they may fit. How the hell do I refill staples in this model?
Yes, I feel (insert profanity here).
  • 492 Answers
  • 40 Answers
SOURCE: Swingline Stapler Staples Only After You Open It Up....
When you lift up the top of the stapler (as though you are going to put staples in), does the pusher slide freely back and forth? It might be getting stuck at some point and not pushing the staples (either due to a worn pusher spring, or friction). First (after removing the staples) try spraying some light oil on the mechanism and lifting the top part of the stapler up and down a few times and observe how easily it moves back and forth. Also, with the top open try GENTLY sliding back and forth a little - if it slides fine with no sticking, try loading staples and using stapler. If it slides ok, but doesn't quickly return to it's "normal position" when pulled so as to put tension on the spring, rhen the spring may be worn and need replacing.
Posted on Mar 14, 2009
Hugh fulton
  • 62 Answers
SOURCE: Where can I get staples swingline stapler
Asssuming that you are in Australia , you could go to Bunnings and ask them or they might point you in the right direction.
Good Luck
Posted on Sep 13, 2009
  • 131 Answers
SOURCE: My Bostitch MIIIFS Floor Stapler wonk work
Sounds like you have a broken driver blade.
Posted on Oct 10, 2009
  • 454 Answers
SOURCE: can't load staples in high capacity stapler
Try breaking off about 15 staples from the strip.
Posted on Dec 24, 2009
  • 662 Answers
SOURCE: I have a Stanley Heavy
Most staplers load from the rear, but not the TR250 Sharpshooter.
With the stapler upside down and the sliding rail out drop a whole strip of staples in the channel upside down (points up) and then push the slider back in making sure it locks.
Posted on Aug 03, 2011
How do I unclog staples caught in magazine?
take it back to the store,it is anti jam,it is not working right
May 19, 2015 | Stanley Bostitch 00540: 00540 AntiJam ?...
How do i load the Stanley Bostitch 00540
Hi Diane,
If you look at the back of the stapler, there's a bright red button. Push this in and slightly lift up at the same time, then magazine is withdrawn. Feed a strip of staples in and replace the pusher unit.
Bostitchtools co uk Bostitch Nailers Staplers Fasteners Coil Nails Staples
Jan 29, 2015 | Stanley Bostitch 00540: 00540 AntiJam ?...
How do I replace the staples in Stanley Bostitch B310HDS? I cannot seem to figure out how to open it.
"The staples load from the rear of the stapler. At the back end of the is a piece of black plastic that extends beyond the end of the stapler. This device holds the staples inside the stapler. To open the area where the staples are placed, push this extended button and lift up on it. The spring device that holds the staples inside the stapler will then slide out. Place a new strip of staples inside the stapler on top of the two metal guide rails. Then insert the spring device to lock the staples in place. The stapler is now loaded and ready to work. " hope this helps you out
Jan 06, 2011 | Stanley Bostitch 00540: 00540 AntiJam ?...
I have a model B310HDS heavy duty stapler and the spring mechanism broke on the end. Where can I find the replacement part? Thanks
what you are looking for what they call a pusher assembly.
Bostitch company uses Amex(SP?) for their replacement parts.
The phone number is 800-343-9329
Jul 21, 2010 | Stanley Bostitch 00540: 00540 AntiJam ?...
Bostitch 02210 stables once, then jams
Biggest olptrit on our office is people putting the wrong staples in it... Check to make sure the ones that are in it are on the approved list.
Mar 03, 2010 | Stanley Bostitch 00540: 00540 AntiJam ?...
Will not staple
!) Staples are jammed...clear out.
2) No staples... fill with staples
3) push down on handle to fire staple
Jul 16, 2009 | Stanley Bostitch 00540: 00540 AntiJam ?...
