Question about JVC Televison & Video
I have a jvc rm-rk50 remote and I need to know how to program it to a jvc stereo
  • 579 Answers
SOURCE: Opening the case of a JVC Remote Control
Not having seen that particular one, remote cases usually have a couple screws under the battery to lock the case together and then a number of plastic tabs around the perimiter that hold the joint closed. find the screws (sometimes they hide them under labels) - I don't know what it is about screws that manufacturers don't like to show. Either think they are not cosmetic or don't want us take-it-apart maniacs to get in. Anyway, get the screws loose then (this is the hard part) carefully pry open the case joint, feeling where and how the tabs snap out and then be careful not to have everything inside go flying when the last one lets loose. Almost impossible to not leave little gouge marks in the joint.
Hope Ya Fis It!
Posted on Jan 08, 2008
chrisbowden
SOURCE: Need instructions on programming
JVC offers the manual through their website:
See this link:
http://books.jvcservice.com/booklist.asp?Model=XV-N50BKJ
That's for the DVD player XV-N50BK. Check your model number before going with that manual. If that's not your model number, look on the left side of the page where the link is at and you will see a link for getting user manuals. Just enter in your model number and it will give you a PDF that you can download, save, print... whatever.
Posted on Dec 21, 2008
  • 54 Answers
SOURCE: Problem to program my remote control
Try using the guide to help you with this problemm if you dont have one, try going to a local store that sells this product.
Posted on Jan 12, 2009
  • 105 Answers
SOURCE: REmote control RM-C1257G not working even after trying new batteries
Try this
1. Get camera phone
2. set camera phone to to take picture
3. point remote at camera and look at the camera display
4. press buttons on the remote, you should a light from the Remotes IR.
5a. If NO light is seen, your remote is broken. you can try replacing the batteries to double check
5b. if Yes, light is seen. Your remote is working and you may have a problem with the TV.
As a double check, get a remote you know is working and try the same thing to verify that you are checking the remotes correctly.
Posted on May 27, 2009
SOURCE: rs2100 bookshelf stereo
The Audio System does not respond to the remote control.
1. To reset their connection, turn on the remote control and switch the Audio System to Standby mode.
2. In Standby mode, press and hold both INFO and SOURCE on the front panel of the Audio System. It is reset to default when"RF ID clear" displays.
3. Press and hold both PROGRAM and SELECT on the remote control. When “ID claer” displays on the LCD of the remote control, the connection is reset.
4. By now the remote control and the Audio System should be connected to each other. Press and hold PROGRAM and SELECT on the remote control again. When
“ID Locked” displays on the LCD of the remote control, the connection between the remote control and the Audio System is locked.
Posted on Jun 11, 2009
What was the price when the jvc rx-9000v was new and where do i find a remote for this stereo
RM-SRX9000J is the remote for this receiver/amp.
MSRP : $700.00 in 2001
The manual for this unit is available on line PDF from JVC (see link)
http://resources.jvc.com/Resources/00/00/96/LVT0428-001A.pdf
26371502-cr0ssa2uu22r1zzifxwmndgk-1-0.jpg Remote available on e-bay
Hope this helps?
NEW ORIGINAL JVC RM SRX9000J AV REMOTE CONTROL eBay
Nov 25, 2016 | JVC Audio Players & Recorders
Codes for JVC rm-sr558u universal remote control
Codes are stored in the remote. If you are using a JVC remote, no "programming" should be necessary.
Oct 17, 2015 | JVC HX-D7 DVD Compact Stereo Audio / Video...
Jvc hd-56fn97 tv but need codes for universal remote jvc rm-svd701u
try but this may not work and if programs at all be missing key features.
Nov 29, 2012 | JVC HD-56FN97 56" Television
I need a set of instructions for programming a JVC remote control, RM-SRX7010J so that I can select several FM radio stations using the remote control. My stereo receiver is JVC RX-7010V. Thanks in...
Hi Will,
If you want to store preset station so that you can easily select your favorite FM station, instructions on how to do this are listed on the JVC RX-7010 User Guide (page 20-22). Remote control operation is also listed there. It is to long to write here.
Please download and save the Pdf file format of the user guide HERE.
Enter your email add and the confirmation number and then click "Download Now" to automatically begin the download. It is a safe website, I used it personally.
Kind Regards,
Mjsazon
Nov 24, 2011 | JVC RM-SRX7010J Remote Control
Is it posible to bay stearing wheel holder
No. The Rm-RK50 is an infra-red remote so has to be pointed at the head unit in order to work.
If you want a steering wheel mounted control you'll need to look for another solution; I can't suggest any as you haven't stated which vehicle you want it for but you may find what you want here.
Please take a moment to rate my answer, it's the only way I know if I've been of assistance.
Nov 10, 2009 | JVC RM-RK50 Remote Control
I can't set the clock on my jvc rm-rk50 radio in my car any suggetions thanks
The model number is incorrect.
Try this
Press and hold the SEL button to enter the menu
Using the scan buttons (FWD/REV), select Clock H
Using the volume knob, set the value
Using the scan buttons (FWD/REV), select Clock M
Press SEL to finish
Nov 04, 2009 | JVC AM FM CD DET FACE CAR STEREO
Aug 24, 2008 | JVC RM-C18G-1H Remote Control
Televison & Video Logo
55 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
