Question about Hummingbird Boating
I bought a boat with a Hummingbird 170 on it, and it won't turn on. I have checked the power cord with a voltage meter and it's getting power just won't turn on.
4 Suggested Answers
  • 55 Answers
SOURCE: My Dell Dimension 2350 no longer powers on.
Dell has this great tool where you can troubleshoot an issue in a methodical way, step-by-step.
Here is the link to troubleshoot No Power, No POST, No Video [Dell Dimension 2350 Desktops] Just follow the steps and choose the option and continue. Remember not to skip any step since each of them has a purpose.
Below is also a link to the Dimension 2350’s user manual.
Hope this helps. Please rate your feedback!
Posted on Mar 04, 2009
  • 667 Answers
SOURCE: I have one 'pin' not getting voltage for my trailor hook up
my advice, wire around the plug, had the same problem with my 99 F150, color match and wire around everything should work fine, a replacement harness should be availiable from Ford, but I have not replaced mine yet because it still works, hope this helps, let me know
Posted on May 26, 2009
  • 75 Answers
SOURCE: i have a hummingbird wide eye that i got with the
this should be it
Posted on Sep 03, 2009
Our 797 Hummingbird fish finder will not turn on any ideas why
Battery too low
Fuse blown
Corroded connections at battery, fuse, connector
Dead fish finder
Jul 09, 2017 | Hummingbird Boating
My 170 hummingbird beeps and wont stop even when i go through the menu and turn the alarm off on everything is this another piece of junk ????
Doesn't it show the cause of the alarm on screen? It might be the low voltage alarm which on some units can't be turned off, but can be adjusted to a lower voltage if it's alerting unnecessarily.
Jun 15, 2015 | Cars & Trucks
Hummingbird manuals
Hummingbirds web site offer downloads for their manuals.
Aug 26, 2014 | Boating
I have the RJTECH 4200 Karaoke Machine. Worked fine for over a year and recentlt loaded a CD and the power shut off. Tried everything, can't get it to turn on. Need help on getting repaired. p.
A repair if total dead is possible. Follow the money or the voltage in this case from cord to switch and from there to power supply--should be AC or wall voltage up to the power supply and then get rectified (changed) from AC to DC.
If no AC voltage past the switch--test it with a ohm meter--off no reading, on a reading etc.
May 27, 2012 | RJ Tech RJ-4200
Where is the reset button. Our washer won't go on. It has no power at all.Tried the circuit breaker..Machine was here when we bought the house
Thanks for choosing FixYa Karen and welcome. You can unplug the washer for 30 minutes and plug it back up to reset the washer. Make sure the outlet works. Next, check your power cord. Wigglle it while plugged in to see if the power comes on. Inspect the cord first for damage before you do that. If the outlet, breaker, and cord is good, you need to check the fuse to the washer. If it still has no power, you may have a bad control board. Due to the fact there is no power, it is probably electrical. Inspect all wires in the washer for damage. You may need a voltage meter to test for power in the cicuits.
Aug 28, 2011 | Washing Machines
My washing machine won't star
Thanks for choosing FixYa and welcome. If you have a washer that won't start, here are some probable causes to your problem. First, make sure to check your breaker box for a tripped breaker. If nothing is tripped, you will want to make sure the washer is getting power first. You need to check the wall outlet and the power cord. You can properly test both of them with a voltage meter to make sure they are getting correct power. Wiggle the cord and see if you can get it started. You could have a break or loose wire in the cord causing your washer to not start. If it starts, you still need to change out the power cord. If the outlet is not getting power, you will need to conduct a test on that to determine the cause. You may have a bad wire or a loose wire. If you have power to the outlet and cord, make sure your fuse has not blown. You need to check your timer switch next. It may be bad or not working properly. Refer to your manual for the correct procedure. Try the washer on different cycles to see if it will start. It is possible that you have a bad lid switch. It can cause the washer to not start if it is bad. You could have a defective motor as well. If the motor has not been working correctly or making noises and other sounds, there is a good chance it has finally died out. Always make sure that the part is getting power before you change it. A voltage meter is an ideal tool to keep around the house. If a part is not getting power, even with a new part, it will not work. Make sure you test everything before making a decision. Always determine the cause by testing and not guessing.
Jul 10, 2011 | Kenmore 24032\24036 Top Load Washer
Depth finder comes on then goes off
It sounds like some power saver feature on the battery or in the unit. Check with hummingbird, they should have an 800#.
May 12, 2009 | Boating
Volvo-penta aq271c, trim will go down, but not pwr at relay
First check the switch-- does it have power, then check the solenoid to see if it works-- there are two. One is for down, One is for up. If you get power from the solenoid-- outgoing-- check connections going to pump motor.
Mar 28, 2009 | Boating
Boating Logo
Top Hummingbird Boating Experts
Fabrice Wolters
Are you a Hummingbird Boating Expert? Answer questions, earn points and help others
