Question about Refrigerators
The motor on my ice maker is making a terrible noise wh n I get ice cubes. How do I get the top tray out to see if it's the ice that is causing it?
SOURCE: no water for ice maker
make sure wire is in down position this is like the on and wire up is off
Posted on Jul 14, 2007
  • 3 Answers
SOURCE: ice maker not working
make sure the wire rod on the ice maker is in the down position in order for it to make and release the ice
Posted on Dec 19, 2008
  • 1524 Answers
SOURCE: Roper Ice maker wont kick ice cubes out of tray.
Remove white plastic cover on ice maker. On bottom you will notice the heater connections, check for voltage. If good, heater is most likely bad.
Posted on Apr 27, 2009
SOURCE: Ice Maker Freezing Up and Ice not dispensing
Check your ice cube tray to see if it is warped. Mine was. I took the tray off and dipped it into boiling water and remoulded it to the original shape and re-installed it. So far no problems. The tray gets warped because of the ice cube release mechanism. The tray is rotated around until it meets a block on one corner which creates the twisting motion we used to do on manual trays. Over time it tends to warp the tray. Good luck
Posted on Apr 28, 2009
  • 19396 Answers
SOURCE: Ice Maker will not release the frozen ice cubes from tray
The icemaker use an avaporator system with an heatinc coil and a fan to release cubes.
In your case either the heating coil or the fan in the icemaker must be replaced.
parts can be purchased from
Posted on May 31, 2009
Kitchen aid superba
Are they staying on top of the ice maker or are they going all over? The ice bucket might be the wrong size.
Oct 29, 2013 | Roper RT21SKXLQ Top Freezer Refrigerator
I have FBW600S omega fridge/freezer side by side. Ice maker still makes ice but when ice cube tray motor turns to empty cubes ice still stuck in tray
there's a heater on the ice maker,if the ice isn't coming out i'd have to say you have a bad ice maker
Nov 08, 2011 | Refrigerators
I set the ice maker feature to make cubes with my samsung refrigerator rs2555sw. But the ice maker makes a ice chunk. All the cubes are frozen together with a flat and thick layer of ice on top..
Hi and welcome to Fixya.
Remove the front cover after the ice tray has dumped cubes and remove all of the water from your ice maker tray.
Then depress the test button on the bottom of the icemaker (in front on bottom) located about 1 inch from the lower rh corner.
The icemaker fill cycle should add just enough water to cover barely cover the tray. (see page 32 of the 25 Sept 2005 user's manual)
If it is overfilling the icemaker fill time / water level needs to be reduced on the ice maker module. A normal fill cycle is about 7.5 seconds.
Another thing that will cause larger cubes is high water supply (utility co) pressure.
A temporary fix would be to slowly close the refridgerator water supply line's shut off vavle so that the water flow restricts.
The real solution is to investigate ice maker fill time, and the function of the icemaker water supply solenoid vavle for possible Delayed closing of the internal diaphram.
Feb 06, 2010 | Refrigerators
Doesn't make ice cubes. Water doesn't come in.
Hello it sounds like the timer on the ice maker may be the cause. If you open the freezer when the fan is off raise and lower the arm on the ice full shut off. listen for a faint clicking noise you wont hear if fan is going. If it does not click the problem is going to be in the actual switch. I have repaired several with this same problem with the switch but you would probably rather invest in a new ice maker or either buy some trays. As the ice makers can cost up to 200 dollars in some models. The only other thing to check is if the water line is bent or crimped off.
Jan 27, 2010 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
I am not sure this is the right refrig. I have a model 253.78259800 top freezer with a model JD-21 ice maker. The ice bucket keeps filling up with a solid piece of ice. It makes and drops cubes, then water...
there s a adjustment but it only controls /like 1 to 2 oz of water . its prbably the ice mker unit or the water valve . .. ice mker tell water how long to let water in and if valve is bak it might not shop off causing water fill . change water valve first . then ice maker if needed .. icemker might have a bad tray and some cubes do not drop / if so next fill will over fill causing problem . mm
Dec 07, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Whirlpool freezer on top ice maker is making a grinding noise and is not making ice Apiece of ice is sticking out of the icemaker's tray. we left it in the off position a couple of days. when we returned...
You should have three screws on the side of the ice make. Two right above the tray and one below. Remove the screws and unplug a four wire connector.
When you reinstall it check for proper water fill. A low water pressure to unit or ice maker valve getting plugged up can cause a small cube to get stuck.
Jul 28, 2009 | Refrigerators
Ice cubes stick to tray and motor can not push them out!
what it is the heater that goes on the ice maker tray is not working properly. Possibly the contact are not making a good cotact or not coming on correctly.
Dec 23, 2008 | Kenmore 74172 / 74174 / 74179 Top Freezer...
Ice maker not working
Depending on the ice maker style, they typically work off a motor timer. The timer motor rotates to set up the ice making process... starting with letting water into an empty ice mold tray, allowing ample time for that water to freeze and then to rotate that mold so that the cubes fall out into the bin. In conjunction with that process, a small heater is turned on to release the frozen cubes from the tray. The 'ice tray full' lever signals the system to stop making ice so you may want to verify that the lever is down and not causing the ice maker to stop, If that's down then I suggest you monitor the position of the motor gearset underneath an access cover. With power applied, the gears should rotate and cycle thru an ice making process. If it does and ice fails to fall out, your heater may be defective. Hope that helps...
Jun 22, 2008 | Roper RT21AKXKQ Top Freezer Refrigerator
Ice Maker Making Noise
I was able to solve this problem by doing the following:
1) Carefully (because there may be sharp metal blades in this area) reached into the upper left compartment of the icemaker and pressed down on ice cubes that seemed to be lodged there and were protruding slightly above the slots they should have been passing through.
2) Press down on the cubes, forcing them through the slots and into the cube container below
3) Lift the metal arm, remove and completely empty the ice cube container
4) Return the ice cube container to the freezer, making sure it is seated properly
Close the freezer and wait until the ice cube maker begins to make new ice cubes. The sound should stop in around 10-15minutes.
Nov 06, 2007 | Jenn-Air JCD2389G Side by Side...
No water for ice maker
Jul 14, 2007 | GALAXY Microsystems 25.4 cu. ft....
Refrigerators Logo
22 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
