Question about Kenwood Food Mixers
My tools don't fit into the tool socket, the stick of the tool is too long for the hub. This happened suddenly as I've been using them together for a while!
I have a Kenwood mixer KM630 for a while. Last time i used it, the dough hook didn't attach itself properly and got stuck. I managed to release it eventually. Now as I try to put tools into the tool socket, they won't fit, the hub seems too shallow. I can't imagine why as it looks perfectly normal..
SOURCE: mixer attachment
I had the same problem and I put veg oil on the top of beater and wrap the beater with a hot towel. I then lightly tapped the bottom of the beater until it moved up enough, then I tapped the side. Finally I tapped the top and it came off.
Posted on Mar 24, 2008
marked
  • 6487 Answers
SOURCE: Dough hook & beaters slipping
You can take it to Bosch service center for repair , check this link for the nearest service center in your location http://www.boschtools.com/Service/ServiceCenterLocator/Pages/default.aspx
Hope that helps........
Posted on Sep 03, 2008
ricardok45
  • 135 Answers
SOURCE: KitchenAid 600, Stand Mixer -
Hi. Stop using your mixer. If your mixer is still covered by warranty, call Kitchenaid Customer Service, they are very good with warranty repairs.
If your mixer is out of warranty, remove the silver band that surrounds the top of mixer. Remove the top cover. At the front of the mixer, locate the transmission housing which is now exposed. Examine this housing carefully for cracks. If you find cracks anywhere in this housing, you have found the under-engineered plastic transmission housing. Kitchenaid's replacement housing is made of metal. Your plastic housing has no business being in a mixer that is marketed as being able to mix bread dough. It cannot!
If you're confident that you can make the repairs yourself, go to the Kitchenaid website and download the parts drawings. Remove the Trans. housing, remove the worm gear shaft assembly which is driven by the motor.. Remove and save as much grease as necessary to thoroughly inspect the worm gear. Inspect the worm shaft bearings. Look for cracks, or missing pieces on the bearings. Look for crunched cogs on all gears. Be prepared to wait at least a month for your parts to arrive after you order them. The replacement grease should be Shell Darina 2, or Chevron FM ALC EP 2.
If you're not confident about repairing this yourself, call Kitchenaid and determine the nearest "approved" repair shop.
You may be able to pressure Kitchenaid to pay for the damaged parts in your mixer. They are still installing these plastic Trans. housing on new mixers. Insist on a metal cover when replacing. Apparently, Kitchenaid feels no shame in their manufacturing process, and will not issue a recall notice for these housings. They are substandard at best.
If you found this solution helpful, please rate it. Good luck! ricardok45.
Posted on Feb 13, 2009
SOURCE: dough hook
if you r using it for dough use the roller and scraper it works much better. But if u want to use the dough hook the holes in the middle is where the knob and stick in the arm go into to hold the hook inplace and it also goes in the hole on the side near the scraper hope this helps
Posted on Apr 17, 2009
  • 19 Answers
SOURCE: MY kitchenaid mixer has always oozed oil but
The oil that is "oozing" is actually grease. If it is laying on its side the grease will leak out but isn't really an issue. If it is leaking while the machine is right side up, it usually means you have a problem with the seal. When it comes to the spring not bending allowing the attachments to lock onto the shaft, that is a bizarre problem as the spring is just tension and isn't internally attached to anything inside the machine. If you want you can replace the planetary gear but that seems a bit drastic just for the spring. We usually recommend 1800Parts for parts and accessories because they carry EVERYTHING! So the seal they might have but I would bring the machine to someone to look at the planetary gear to make sure everything is in working order. If you are in New York you can bring it to us.
Posted on Sep 15, 2010
A scre to fix bgh stsnd mixer
If there is another screw on the mixer that fits were you are missing a screw, take it out, put it in an a reclosable plastic bag so it doesn't get lost, and take it to the hardware store to get a matching screw. Get a stainless steel screw if possible. Avoid cadmium-plated hardware; it should not be used around food (cadmium plating has a yellowish color).
If the missing screw has a knob on it for use without tools, you may have to substitute a wing screw. It may be necessary to take the mixer to the hardware store to be sure of a good match.
Nov 11, 2017 | Food Mixers
Artisan mixer quit rotating. I took it apart and the hub bevel gear was frozen in the case. I beat it out but the bearing surface is pretty deeply scarred. I am wondering if I can sand the shaft enough...
You can certainly continue to use it without the accessory drive gear. Repair without replacing the gear and housing (the proper way) will leave you with a less than optimal accessory drive but if you don't overwork it it could last. Clean it out and polish the bearing surface on the gear up a but then get some good grease into the grooves on bush & bearing and bang it back together. You don't have a lot to lose.
Jan 01, 2015 | KitchenAid Food Mixers
My dough hook is stuck in my K mix kmx50.
yes the dough hook is a firm fit on those
Instruction Book KMX50, KMX59 English - Kenwood
www.kenwoodworld.com/.../Instruction-Manuals/kMix.../kMix.../18362iss2%20KMX..
Apr 29, 2017 | Kenwood Kmix Kmx50 Stand Mixer, White
Dough hook
Hi, the new style tools do not fit old style mixers, yours probably had the small circlip on the shaft, the new ones dont have this, and it's this what held your tool in place
Jan 05, 2014 | Kenwood KM400 / KM410 Chef Classic Stand...
Kitchen aid mixer has a scream when using dough hook.
A little pin or setscrew or key has failed. Maybe a gear has slipped out of place. Anyway, the thing needs to come apart to find out what happened. When taking things apart, line up each item off in a tidy row, put screws in little containers near the part they fit.
Repairclinic.com may have instructions, and probably have the parts.
Nov 26, 2013 | KitchenAid Food Mixers
I have a new kitchenaid mixer and both times i've used it the cake did'nt come out right, it was bland and it fell apart and that never happened before. what did I do wrong?
It could be that your over mixing the batter. It is very easy with a KitchenAid to push a batter too far, and you get too much air, or cream the butter too much into the flour, or press all the oil out of peanut butter. Try using the mixer for only as much to get the matter mixed.
Jul 03, 2012 | KitchenAid Food Mixers
Cannot insert grater attachment into front of KitchenAid all the way.
Since I do not have your mixer in front of me, here are my best guesses:
a. It can't happen, but since it does --
b. There is something inside the hub preventing the sttachment's shaft from going in all the way.
c. The square of the hub and shaft are not lined up with each other.
d. There is some sort of damage to the hub interior or to the attachment shaft.
e. The attachment shaft is no longer straight.
f. The thumb screw is now going in at an angle (other than 90 degrees).
I've now run out of ideas.
Aug 11, 2017 | KitchenAid Classic Stand Mixer
Bevel gear and worm follower gear no longer stay together
they should be a tight fit as the clip is just to help retain position
if they are ment to be loose replace the clip and inspect the groove for the clip as the edges may be worn to a taper rather than a sharp edge which will allow it to be moved out under load
May 18, 2017 | KitchenAid KP2671 Professional 6 Series...
Hello, I have a commercial dough mixer,
it's a standard drive system found on most hobart mixers like the a200 style and you may find only hobart parts will fit it
Oct 10, 2009 | Hobart D300-6036 Mixer
Difference Kenwood Chef A701 and Kenwood A901
Hello.
the difference between A701A and A901 is :
high speed outlet
slow speed outlet
planetary hub is similar . A701A, A901 and KM series
A701 Different planetary hub and fit different tools.
is not same A720 and A920 A7 = A701/A
A9 = A901 and KM
In our web site Kenwood Chef Restore in Downloads section.
you can download the compatibility of the models A700, A701 , A900 and KM series .
Regards
Oct 02, 2008 | Kenwood KM400 / KM410 Chef Classic Stand...
Food Mixers Logo
71 people viewed this question
Top Kenwood Food Mixers Experts
ashburton
jason
Are you a Kenwood Food Mixer Expert? Answer questions, earn points and help others
