Question about Honeywell Heating & Cooling
I have a honeywell focus pro 6000 temp in house doesnt change unit runs constatly. thermostat says 78 thermomiter on other end of house says 72. changed batteries
  • 1,658 Answers
It's possible you have a lot of dust build up inside the stat. If it has batteries remove face from wall and blow out. Take outside to see if temp will change. Plug the hole in the wall where the wire comes through. If all fails, replace. Turn power off, take wiring picture, replace, turn power on. Good Luck!!
Posted on May 01, 2017
Thermostat does not reach programmed temperature
Have you checked with a thermometer to see if the area is reaching the temp you have it set at? A thermostat has nothing to do with the temp in your house. If you have it set at a temp for Example ( 72 ) and it is not reaching that temp to shut off then you have a problem with your unit or insulation in house. If you set stat on cool at 72 and the house gets down lower than 72 then there is a problem with stat.
Dec 19, 2014 | Honeywell CT500 Digital Heat / Cool Manual...
Honeywell focus pro 6000 thermostat
Right below the w setting on the base plate is the o/b connection. Put the O wire in this slot. During the initial test for heat and cool, the bias for cool for function 2 is 0 and for heat it is 1. To reach the programming press fan and Up arrow. Press next to reach function 2. Be aware the the O wire is energized and operates the reversing valve. Some manufacturers energizes the reversing valve to go into cooling, and some leave it deenergized to be in cooling. Select either 0 or 1 to make the system perform in the correct mode.
Hope this helps.
Jul 25, 2014 | Honeywell Focus Pro 6000 Programmable...
AC Thermostat is set to 78 but wont cool past 79 or 80
If your unit is running 24/7 you are either low on charge or the unit is to small for your house.
A 20° temperature difference is about normal for the room air vs the air coming out of the ducts, but the room air and the leaving air should keep getting colder and colder.
An air conditioner should cycle approximately 3 maybe 4 times in an hour if it's properly sized.
As for the thermostat thermometer they are very cheap and are more for reference than actual temperature, so if 78° is not comfortable, then you should set it lower but not rely on thermostat being accurate or what the thermometer is saying as long as it is consistent.
The air conditioner and thermostat can also be set below 78°, there's a lot of people set them at 72° and below with no problems.
the only thing is if you have real low humidity you'll need to watch indoor coil or the suction line (the big line) on your outdoor unit and make sure it doesn't freeze up on you.
Sep 13, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
Indoor temp doesnt go to my punched in setting of 68 on therm
if it is around 93-97 degrees outside,thats all the cool your going to get
Jun 23, 2009 | Honeywell Programmable Thermostat Heater
Honeywell RTH230B a/c problem
if you set the thermostat on 70 and your house won't get ant cooler than 72, there is a problem with your system,not your stat. I'm thinking you are low on refrigerant if it is somewhat working. when the unit is running, if you can get your hand on the larger refrigerant line under the black insulation, it should be cold, about 55 degrees.
Jun 19, 2009 | Honeywell Programmable Thermostat Heater
Lost directions to program a thermostat
i have a pro 6000 t stat it shorts cycles any clues to change the off set
Nov 09, 2008 | Honeywell Programmable Thermostat Heater
We have a Honeywell A/C (we believe it's a focus pro 6000) that is not working properly. The A/C unit itself is running but the vents inside the house are not cooling. We think it's a problem with the...
the honeywell is just a guess is the capacitor went out in the condenser when you lost power.turn the temp down on the thermostat and hit the hold button.....if it does not cool,call a service tech.good luck!
Sep 24, 2008 | Honeywell Heating & Cooling
Heating & Cooling Logo
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
