Garden Logo
D
David Petersen Posted on Apr 30, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Still ts420 concrete saw fuel line placement?
magna buff
Level 3:
  • Garden Master 3,828 Answers
  • Posted on Apr 30, 2017
magna buff
Garden Master
Level 3:
Answers
3828
Questions
0
Helped
1114052
Points
21593
Its a stihl chainsaw motor adapted into a concrete saw
Stihl Ts420 Parts
shoudnt have to take too much apart
take off air filter cover to see the carby
Still ts420 concrete saw fuel line placement? - index-4jvxtsmkstm5vsnixyjxypta-5-0.jpg
I did not remove carb somebody else did what is the fuelline routing for stihl ts 420?
Primer bulb feed must be connected to fuel tank weighted filter in tank - other line goes back to top of fuel tank - check that the fuel line is not broken between primer bulb and fuel filter in tank - sometime line breaks off at top of fuel tank inside which drops filter to bottom of tank and thus disconnected from primer bulb - replace with new fuel line if broken.
May 19, 2019 • Stihl TS420
Ts420 chop saw fuel in crankcase and exhaust E
Hole in the piston or a badly scoured cylinder wall or broken rings
Apr 19, 2017 • Garden
Dollar pc-7430c concrete saw spits fuel when tryn to start it ..
check the fuel system, Possibly a damaged fuel line or primer bulb if it has one
Mar 18, 2016 • Saws
Why Do I Not Have Any Spark From The Ignition Module When Spark Plug is in The Cylinder
Search Results
    Stihl TS400 / TS420 Ignition Module Repair - YouTube
    ? 7:06
    https://www.youtube.com/watch?v=AvPv88SELXs
    May 1, 2011 - Uploaded by donyboy73
    Learn HOW TO REPLACE The Ignition Module in your StihlTS400 / TS420 ... I have a homelite 33cc Ranger it has no sparkat the plug but if I put a ... a good spark and there is fuel getting into the cylinder head also what are ...
    All comments on Stihl TS400 / TS420 Ignition Module Repair
    https://www.youtube.com/all_comments?v=AvPv88SELXs&lc...
    Donyboy73, I hava a Stihl TS 420 and just replaced the pull rope (not sure what's ... a good spark and there is fuel getting into the cylinder head also what are your ..... Hi mate, i have no spark to my plug?? i have tried a brand new plug and still ...
    Small Engine Ignition: Ignition Wires, Chainsaw Spark Plugs ...
    www.hlsproparts.com/small-engine-ignition-parts-s/149.htm
    66 results - HL Supply has the small engine ignition parts that will get your ... parts right here: ignition wires, chainsaw spark plugs, ignition coil sets, ... Please don't hesitate to contact us if you have any questions. ... Stihl TS400 (3-bolt old style), TS460 ignition coil with wire and cap ... Fits: Stihl TS410 and TS420 cut off saws
Feb 08, 2016 • Stihl TS420
How do I get inside the fuel tank of my poulan 1950 to replace the line in it?
To replace line you use tag wire or similar item to pull the fuel line through the tank fittings.
First you install tag wire through the tank fuel line open and out the fill hole. Then attach this tag wire to the fuel line and pull the line back through the fuel line opening. You do this for both the pickup and the return lines. Mark your return line about an inch from the end so you can install it at the proper placement. As pull this return line through the fuel line opening stop when you reach the mark. Now with both lines installed cut them to desired lengths to connect to the carburetor and the primer.
Here is a picture of how connect the tag wire to the fuel line.
PARTNER K950 CONCRETE SAW NO FUEL TO CYLINDER
If all parts are installed properly, then the problem has to be in the cylinder / compression. Have the saw checked for compression and have a pressure / vacuum test done to the saw.
Stihl saw cuts out when machine is tilted forward on ts410 anybody else have this problem
Fuel pick up will be your problem. Buy new fuel filter and fuel line from in tank to carby. Most likely a split in the fuel line in-tank
Stihl madel ts420 how to change air filter
There are 4 torx screws on the black back cover. Here is the owners manual. It is explained on page 33.
Stihl TS420 owners manual
Jun 22, 2012 • Saws
1helpful
My Brand new Stihl ts420 cut saw wont run full throtle, smokes white, and leaks fuel out of exhaust filter. it runs like the choke is half on.
This sounds like the carb is flooding, there is a rubber tipped needle under the metering side of the carb, this may be leaking, before replacing the needle make sure the air filter is not blocked, replace with a new filter and try again
Fuel line placement old ones disinagrated how to
Fuel System Illustration (Primer Bulb and fuel lines may not apply)
http://www.img4free.com/thumbs/Lou98321/smallfuelsystem.jpg
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, an output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Take lots of notes and a few digital photographs to help with reassembly.
Construct an IPL number as follows:
http://www.fixya.com/support/r3558917-mcculloch_chain_saw_ipl_illustrated_par
Fuel system routing is sketchy at best, fuel system components are illustrated but are on multiple pages. HTH
Lou
Top Garden Experts
Jay Finke
Jay Finke
john h
