TV will not scan search channels, keep saying end or stop
  • 8 Answers
SOURCE: Auto Channel Search
sounds like the tuner section of the main pcb isn't working properly.
Posted on Aug 21, 2008
  • 4 Answers
SOURCE: rca F32649 32"
I had the same problem and eventually found the solution. the tact switches behind the front panel buttons will leak when they get old causing them to activate on their own. your channel up or down button is stuck on. take off the back cover and you will see a small clip in circuit board behind the front panel. take out the board and remove the channel up or down switch and your set should work fine again. the remote will still work fine for changing the channels.
Posted on Oct 04, 2008
dvdcdlaser
  • 1285 Answers
SOURCE: Olevia is not picking up my cable channels
pick up the remote turn on tv....press menu...setup....tv....then channel scan....(note your tv should also be on cable broadcast not air)...hope this is helpful
Posted on Jul 04, 2009
tvtek
  • 1284 Answers
SOURCE: wifes ge tv won't stop changing channels just
I suspect one of the buttons on the front of the TV is stuck. Best thing to do is try playing around with them while the set is in operation and see what happens. If that doesn't seem to be the case then you have a diode or capacitor on one of the control lines that is shorted or leaky causing this to happen. This would require a technician to troubleshoot that issue. Please take a few moments to rate my answer. Thank you...
Posted on Nov 18, 2009
  • 302 Answers
SOURCE: My Sony KDL-52xbr4 was working fine until I did a
Hi check to make sure the antenna is connected correctly. try tunning the channels manually and if they come up you can save them one at a time. Also try moving the antenna to a different location. make sure the TV is set to scan on the same input that you are connecting the antenna. If all that fails ou might have a defective tuner board.
You can get parts for this tv at www.interliquidparts.com
Posted on Dec 19, 2011
I have a flat screen TV and i got the digital channels but I did something and now i can't get any digital. Please help me.Thanks
Well im not an expert on this but by wife keeps deleting channels... you can just go to setting and anything the reads channel search or digital search just run it or scan... your tv will scan all channels... make sure that your antenna is connected or digital receiver... when you tv searches it needs something connected to the input of the tv antenna... you can try goggling it too
Apr 27, 2016 | Televison & Video
19" Element HD Digital LED TV Model ELEFW195 Does not scan Digital Channels just Analog Channels.
Auto-channel search can't find digital channels - Community ...
community.insigniaproducts.com/...channel...can...digital-channels/.../13...
Aug 6, 2010 - When I ran the auto-channel search it could only find 4 analog ... Notgetting Digital Channels on NS-26L450A11 ... I've plugged the cable from the wall into the TV, and preformed the auto channel scan, with "cable" selected.
Troubleshooting Guide for Digital-to-Analog Converter Boxes
https://www.fcc.gov/.../troubleshoo...
Federal Communications CommissionIf you aren't receiving digital signals on your analog TV, you can purchase a ...antennas are designed only for reception of either VHF or UHF signals (but not both). ...The channel scan will automatically search for digital broadcast channels ...
Antennas and Digital Television ' Federal Communication
Jan 13, 2016 | Televison & Video
How do I stop it from running the auto scan
Once the unit finds the channels it will stop scanning.
Jan 13, 2015 | Apex Digital Apex LD4088 40 Class LCD HDTV...
My Dynex tv keep saying scan channel
Main system control memory IC fault. Contact any service technician.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 16, 2014 | Dynex 32 in. LCD Flat-Panel HDTV
Element tv keeps saying please run auto scan
May be there are some out of frequency channels. Go to searching menu option and use manual tuning for personally. Auto scan for all channels.
May 11, 2014 | Element Televison & Video
Display says please run auto channel scan
It sounds like it is not seeing any signal. Do you have the input set for the proper type? Air or Cable
Check your RF connection to ensure you have a signal coming into your television.
Nov 16, 2013 | AOC L22W898 22 in. LCD TV
TV is showing no signal. So I did a channel search and it stops and says unable to continue channel search due to error. I even unplugged - left for an hour and still does the same thing. I then hooked...
this could be a fault with the tv actual connector for the cable check the connection on the tv and try again or try a manual search to pick up one channel and then do a full scan also are you doing a scan to add channels to the current list as I would personally try and do a complete scan for all new channels list and see what happens
Sep 21, 2013 | Televison & Video
I have a 19 inch lcd isymphony tv and it keeps saying run auto channel scan. But I have no channels to scan for I'm in a barracks in camp Lejeune and we don't have cable here. I just want to use...
Tries unplug replug the tv like an hour later see if the tv reset it self back to factory mode setting it should stop this.Make sure tv is not on Cable,try Antenna setup just don't push for the scan function or yes answer.Tries used it with a HDMI cable for setup for the PS3 and used input like 1,2,3 so on this dosen't link to any airing tv stations functions.
Aug 09, 2013 | Televison & Video
How do you program a Regency Programmable Scanner R1070?
Regency R1070 Frequencies for people with no manual
These are the ranges it supports.
30-50 Mhz
144-174 Mhz
440-512 Mhz
To make it scan, first set the range by pressing Manual and then Search. It will ask for the LOwer end and the UPper end of the range. Enter them, press Scan and then Search, and it will start scanning. When it locks and you want to keep going, hit Search again. You can press Delay to stop at a channel temporarily. To save a frequency in memory, hit Manual and pick a number, then type it out and hit Enter. When you have a few channels saved and you want to check up on each of them, Scan scans through memory. The Lock button is to skip a particular channel while scanning.
That's pretty much the whole manual right there.
Jan 30, 2012 | Radio Communications
Auto search through
Tested and verified solution:
  1. Set Tuner Mode to "antenna".
  2. Run a channel scan. Should get zero channels found.
  3. Set Tuner Mode to "cable".
  4. Run another channel scan.
  5. Celebrate!
Aug 16, 2009 | Vizio VX37L Television
Televison & Video Logo
Top Televison & Video Experts
