Question about Bosch Dishwashers
How do I reset Bosch dishwasher SHE46C06UC - Bosch Dishwashers
    New Friend:
  • 13 Answers
Try flipping the circuit off wait 30 seconds, then back on
Posted on Apr 30, 2017
Bosch SHU9915UC won't start. all lights come on but unit doesnt start. is there a reset button somewhere in this unit?
Reset the dishwasher by pressing and holding the "Start" button for at least three seconds. Depending upon the Bosch dishwasher model you have, you also can push the "Cancel-Reset" button to reset the dishwasher. Select a new cycle and press "Start."
Jan 03, 2018 | Bosch Dishwashers
How can I reset our dishwasher
Open the dishwasher door sufficiently to see the control buttons, then hold the two buttons with labels "Cancel Drain" and press for 3 seconds.
Close the door. Wait nearly 1 minute for the dishwasher to complete the cycle.
Open the door and hold the "ON/OFF" toggle.
Reset Bosch Ascenta Dishwashers
Shut off the child lock if needed by pressing and holding "Open the door far enough to see the keys, then hold the "START RESET" toggle until the "ACTIVE" LED become extinguished. On the SHE5AM model of Bosch Dishwashers, hold the "START RESET" key until the display clock shows "0:01".
Close the door and rest about 60 seconds. On the SHE5AM, wait until the display clock displays "0:00".
Apr 06, 2016 | Bosch SHE4AP06UC Dishwasher
Bosch dishwasher SHE46C06UC won't fill with water
Check water inlet. Check for kinks in hose. Check the inline strainer in the fill solenoid. You say it makes an attempt to fill, is this because you can hear water trickling? If so I would suggest get to g the fill solenoid replaced as it may be blocked or not opening fully
Oct 27, 2017 | Dishwashers
Bosh washer won't stop? model SGS45C02
major recall of bosch dishwashers. recommend you check the list. https://www.consumerreports.org/dishwashers/maker-bosch-expands-dishwasher-recall/
Jan 01, 2018 | Bosch SGS45C02 Dishwasher
Bosch dishwasher leaving food stains
You may be experiencing this problem due to the soap you use or too much soap. Run a cycle without soap but put a cup of white vinegar in the machine. Then just use Cascade dishwashing packets. If your filters are clean and the pump is working that should take care of your problem. Do NOT use the inexpensive soaps on the market and especially don't use more than what is recommended. This leaves a film on your dishes and will cause it not to clean or rinse well. (I don't have any connection to Cascade - I just know it works very well. Costco brand packets also work well.)
May 19, 2017 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Should I buy a Bosch?
In my opinion, these do not live up to the Bosch name. They seem to come up on our radar here with "unusual" problems, and a lot of the questions posted go unanswered.
I replaced a beautiful stainless steel Kitchen Aid, after replacing the motor/impeller assembly because it was noisy, and the new one failed also. I bought a Samsung, and I like it. There a re several schools of thought about dishwashers, neither of them are very good, but here goes: One friend buys the brand name cheaper models. One buys only the higher end "best" types.
My best advice is to buy a brand with a high degree of reliability, and stay in the mid price range. The reason I say this is that the middle price range units generally have the better components of their "flagship" models, but don't have as many cycle choices, rack choices, etc.
GE, Whirlpool, (Samsung) are good brands. Frigidare is in there, too. I will never have another Kitchen Aid or a Maytag. I found them to be overpriced and unreliable, but this is just my opinion.
Best regards, --W/D--
Aug 11, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Bosch dishwasher stuck on '1'/restarts & sanitize not lighting
it possibly could be a bad soldier joint on the heater relay of the circuit board. but if it is then let an authorized bsh tech replace the board since that is a 5 year warrenty part usually. it also could be problem with the NTC-HEAT ASSY- OR FLOW CONTROL. which are all part of the heat assemby.
but the first thing i would check since the time is jumping around on that model would be to make sure that the polarity on the power cord isnt reversed where its hooked up to the d/w
May 27, 2009 | Bosch Dishwashers
Loud humming noise when dishwasher is filling up with water
your model is pretty new. just so you know your warrenty is 1 year parts and labor. 2 years on parts. it should not cost that much money.
there are two components that start before the circulation pump.(wash noise you hear)
first sounds you hear will be the drain pump. usually rattling noises if something is in it but it can make a hum noise if something is jamming the drain propeller up. which is accessible with a T20 torx driver. take the filters out and the mesh filter. and unscrew the screw in the base towards the left. pull out whatever is lodged.
the other humming sound can come from the next component that activates is the watervalve. make sure you dont have a kinked water intake line. otherwise its a bad valve. i have had to change a few of those water valves out already but not for a hum noise on your model. you have a new style water valve. when brands make new parts we get problems fast sometimes..
Feb 14, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Dishwashers Logo
365 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
