Question about Sharp Televison & Video
I have a sharp LC-26DV24U. (tv-dvd combo)The remote is fine for tv but i can't seem to get it to operate the dvd, or find codes for that part of the set. Auto search can't find it
I have a GE Universal remote.
    New Friend:
    Problem Solver:
  • 13 Answers
Try looking it up on line.most codes for just about anything can be found.
Posted on Apr 30, 2017
Testimonial: "not helpful..Please don't waste my time. Asking AFTER looking for a couple of hours."
  • Paul Carmichael
    Paul Carmichael May 01, 2017
    your time isn't worth any more than mine.look some more it's there but since i wasted your time i won't post where thanks.
How do I Fix my tv? My TV plays for awhile and then the screen turns white. Sound is good even when screen is white.
sounds like maybe something is begining to go. I usually recommend that it is reset to factory default through the menus available from a remote control. If, after resetting, the fault persists it must be something to do with the electronic hardware and the fault shoud be diadnosed by a qualified technician.
Jun 02, 2015 | Sharp LC-26DV24U 26 in. LCD HDTV/DVD Combo
How do I tune my Sharp tv to channel 3 so the cable will work?
Go to the Tuner setup screen and select cable instead of air. Then put the TV on Channel 3 and connect the cable box to the antenna connector on the TV.
Jul 04, 2014 | Sharp LC-26DV24U 26 in. LCD HDTV/DVD Combo
The remote won't work
Is its a Sharp Remote? or a Generic
A) Check Batteries
B) If a sharp aquos remote there is a function button on the right top side - insure that TV is selected. TV led will light
C) On left side there is a red TV power button press and insure the red led on the remote lights.
D) IF Tv does not turn on then you may have a problem with
the sensor inside the tv.
Only real way of verifying it is not The Remote sensor is by trying another remote. If you have a Cable or Universal follow the instructions for a Sharp TV and try that. If it works problem is with the Sharp Remote if it doesnt its your remote sensor inside the tv.
Hope this helps.
Aug 02, 2013 | Sharp LC-26DV24U 26 in. LCD HDTV/DVD Combo
Sharp LC-26DV24U has Black screen only
The Video/ luminance. or the power voltage supply line is not
working. needs repair.
Nov 01, 2012 | Sharp LC-26DV24U 26 in. LCD HDTV/DVD Combo
My sharp LC-26DV24U is displaying a white screen only.
I have the same model Sharp TV with the same symptoms. The TV would sometimes work perfectly, then go to white screen (audio OK) and sometimes back to working perfectly again.
I saw Posts saying to check F404 and Q413 - My fuse F404 was not blown, and replacing the Q413 transistor did not fix it.
On Q413 I had about 12.4 VDC on the Emitter, 12.3 VDC on the Base and about 1.5 VDC on the Collector. My service manual called for 11.6 VDC on the Base lead. As a Test, I used a 150 Ohm resistor from Q413 Base to metal chassis ground, and that made the TV work OK.
I replaced the Q419 NPN silicon driver transistor, and now the TV has been restored to 100% proper operation.
I hope that helps someone else down the line.
Mar 27, 2012 | Sharp LC-26DV24U 26 in. LCD HDTV/DVD Combo
We have a 42" sharp lcd tv we have satellite with
Hi to get the full potential of your Flat Panel, you need to subscribe to a digital HD feed. most likely they will give you a digital box for HD.
Mar 27, 2011 | Sharp LC-26DV24U 26 in. LCD HDTV/DVD Combo
How do I switch my TV from analog to digital? And how do I find what digital frequency my cable box operates on?
If you have a cable box then you don't do the switch in the tv, you do it in the box. If the box isn't a digital model then you must replace it.
BTW the digital channels operate on the same frequencies as the normal ones, to find them just do a channel scan.
Aug 20, 2010 | Sharp LC-26DV24U 26 in. LCD HDTV/DVD Combo
LC-26DV24U displaying a white screen.
good day the defect is in the main board ,or loose connection in the main board
Jun 20, 2010 | Sharp LC-26DV24U 26 in. LCD HDTV/DVD Combo
Televison & Video Logo
32 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
