Question about The Audio Players & Recorders
Can the Korg PA900 record real guitar tracks into its sequencer via the vocal input?
SOURCE: Can not record vocal and guitar at the same time
The monitoring switch should not affect the recording at all. Maybe you have a defective mic?
Does it record from the line input if you set it to Line In mode?
Posted on Mar 28, 2008
SOURCE: using the effects on the 2488 mk 11 for vocals
Use a single effect vice a multi effect and assign it to the channel vice the input and that should get you going. I'm sure you could just set the effect to the input and not the channel but this works for me. If your tracking your instruments/tracks to different channels, and you should be, then assigining the effect to the channel wont hurt you.
Posted on May 19, 2008
SOURCE: Cannot record both mic and electric guitar in daw
Disagree with previous post. The GTrack is designed to record vocals and a mono insrtument at the same time. That's its main selling point. It should also allow monitoring of both the vocals and guitar alongside the playback from the computer. In your computer's Control Panel, go to sound preferences, select the usb microphone and click on advanced tab. It is likely yours is set up to record 1 channel at CD quality - this is how many ship for some reason. Set it to 2 Channels CD quality.
In Sonar, set your track input as USB Left for the vocals, and USB Right for your guitar.
Posted on Apr 14, 2009
  • 909 Answers
SOURCE: Recording vocals while the music tack is playing simultaniously
it's not supported on that or any earlier sony software that I know of. have you tried running the program twice (simultaniously) and playing on one while recording on the other then mixing the tracks together after??
Posted on Apr 26, 2009
SOURCE: Boss 900 digital recorder
from reading instructions when you record channel 1 and 2 you are recordind channel 1 in stereo so you only recorded channel 1 try rcording on chanel 3 for vocal hope this helps
Posted on Jan 20, 2010
While using korg m50 editor using usb data cable there is no sound from my lap.the sound is only from my head phone connected to my keyboard directly?
Are you connecting to the laptop and using it as a midi controller? You can record midi notes from the keyboard and send them to your laptop via USB using any midi sequencer program (reason, logic, etc). Create a midi track, select the input of that track as your keyboard, then hit record to play some midi notes. To hear what you record, you have to set the output of the midi track to whatever midi sounds or instrunents you have installed on your laptop.
If you are trying to record the actual audio sound the keyboard makes, use an audio program such as cubase, sonar, audacity, pro-tools, and either mic the keyboard, or connect one of the other audio outputs (1/4" TRS) to an audio input on your DAW, and record an audio track that way (as opposed to a midi track).
Apr 13, 2012 | Korg M50 61-Key Music Workstation Keyboard...
I'm a solo performer using mp3 backing tracks, a korg mutli effects for rock soloing and 1 mic for vocals all going through a mixer then outputed to Bose L1 Model 1. i. whats the best guitar effects...
You have several questions here and I'll do my best to help. While I'm not familiar with the "Bose" system I am performer that uses effects, mixers and etc. so....
1. Best effects to use. I would choose a small amount of guitar chorus and maybe a short digital echo, this is totally a matter of your choice, but in my experiecne, use as little as possible, you don't want to muddy up your sound
2. If your getting clipping, you have to much gain coming in, if you can you might try changing the settings on the "compressor" if you have such adjustments., or just turn down the output from your effects box a bit.
3. You didn't say what kind of mixer you are using, but typically your best off running your mic through the mixer, run the output of the mixer into a channel on the bose that has the graphic eq set to 0 or "flat", use the mixer to control treble, middle and bass rather than the bose amp.
4. Variation in volume of your backing tracks is an issue that you need to take care of before you play out. When you record your tracks, you need to either use equipmennt that will make the levels all the same, or sit with the system while it records and control the volume (with a mixer) as they are recorded, nothing ruins a performance more than profound changes in volume that override or dimish your main performant, (e.g. your vocals or lead riffs)
Let me know if you have further questions. good luck and Keep on Rockin
Mar 14, 2011 | Bose T1 ToneMatch Speaker PA System
I am trying to record in multi track mode-want to know how to record for example vocals on track one then without erasing the vocals add for example harmony or guitar so i get two things on one track. At...
How multitrack recording works is assigning each recording to a different track. A way around this is to record the vocals to track one, then your harmony to track two. Save that as a single recording, or mixdown, then open that saved mixdown to track one. You may need to be connected to a computer to do this.
I use the same technique when using Cool Edit Pro (outdated, yes, but I've been using it for 4 years, and I know most of the ins and outs), especially on the guitar tracks, where for studio sound, you've gotta use 4 total tracks. Putting two tracks together frees up your processor, and uses less in the way of effects, as well.
Hope that helps!
Feb 07, 2011 | Samson Technology Zoom H4n Handy Recorder
Mar 31, 2009 | Samson G-TRACK USB RECORDING MICROPHONE...
Still dont get it
Hi Mark.
Siorry, but because of a fault with the system I am not able to reach you on the other thread.
Normalizing tracks means leveling volume settings for a group of tracks or samples to mix or combine them together without troubles like the ones you got.
to normalise tracks you can use the function built in on the Korg studio, see normalize in the software help.
When operating on MIDIs also remember that MIDIs are recorded on different channel (example drums, guitar bass guitar).eg:bTd Aerosmith MIDI archive
When you use them on a sequencer, and you operate on the volume, ensure
Mar 29, 2009 | Korg Legacy Collection
Oct 18, 2008 | Boss Micro BR Digital Recorder
Tascam DP-02cf
You've got two inputs on the DP-02 so you can record two sources at once.
Depending on how you want the electric guitar recorded (mic the amp, or direct line in) you can in the first case plug your guitar mic into one of the mic inputs on DP02 and plug your vocal mic into the other mic input. You also have the option of plugging the guitar directly into the DP02 (using the hi-z input - I believe it is labelled 'guitar' or something on the DP02. I any event I believe it's the one on the left). This way you only need one mic for use recording the vocal part.
To avoid any 'bleed' between channels you can use the headphones while recording this way and you'll avoid having the unamplified guitar sound coming through over the vocal mic.
Once you have the mics or guitar and mic plugged into two inputs, you need to assign the inputs to a channel (track) to record on. You do this by pressing the select button for the input and then pressing the select button for the track where you want to record the input. Do this for both inputs so that they are recording on different tracks. Then arm the tracks for recording by pressing the record button for each track and the lighted buttons will flash above each armed track. Then just press play and record and you'll be recording. You can go back and redo it as many times as you like and record over what is there, or preserve a take and assign a new track (or tracks) for another take. You've got 8 to play with.
Hope this helps.
bd.
Sep 01, 2008 | Tascam 2488 Portastudio Multitrack...
Using the effects on the 2488 mk 11 for vocals
Apr 05, 2008 | Tascam 2488 Portastudio Multitrack...
Mar 27, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
Lexicon lambda
push the monitor button to go mono instead of stereo.
Oct 11, 2007 | Lexicon Lambda Usb Desktop Recording...
26 people viewed this question
Top The Audio Players & Recorders Experts
Jose Ma DM.
Jose Ma DM.
kbrowndo4u
Level 1 Expert
chrisheman
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
