Question about Epson Office Equipment & Supplies
Have two identical epson stylus photo 2200 printers. One is working. The other now is not connecting with the computer. Tried switching cables with the working one and using same computer.
    Top Expert:
  • Epson Master
  • 50,503 Answers
Being identical does not mean that the two use the same driver or usb port setting
each has to be installed separately into the computer and given a printer identification tag
Posted on Apr 30, 2017
eclark317
  • 159 Answers
SOURCE: TRYING TO CONNECT MY PRINTER TO MY COMPUTER
Ok try this dissconect the printer
Go to the epson website download the drivers for your O.S
Install them.
If that dont work right click on your computer icon. go to properties.
hardware device manger. Sii if you have IEEE bus host controllers.
update that bye clicking on it and have it update driver.
If still no go go to setting controll panel printer and faxes. You can manually add the printer there.
Posted on Jan 16, 2009
  • 700 Answers
SOURCE: my r230 photo printer epson stylus was sevice required unable to print and see your printer documents
Reset your printer. Look for printer resetter , its a utility third party program. Or in search of web browser just key in " epson reset software"
Posted on Apr 17, 2009
SOURCE: All lights flashing on the Epson Stylus photo 870
Unfortunately, the Russian software does not work on a Mac, and it crashes at launch when installed in WZ98 under Virtual PC. However, I found this on another site, and it worked immediately:
The sequence to reset the waste ink counter is as follows:
WASTE INK ROM RESET ONLY 870, 1270
1. Turn the printer off using the power button on the panel of the printer.
2. Disconnect the interface cable at the back of the printer.
3. Hold down the "LOAD/EJECT" and "CLEANING" buttons simultaneously.
4. Turn the printer on. Release all buttons as soon as paper out light flashes.
5. Quickly press (within 3 seconds while PAPER OUT light is flashing) the "CLEANING" button for 10 seconds.
6. Release the button and the printer will initialize.
7. Once initialization is complete, turn the printer off.
8. Reconnect the interface cable.
9. Turn the printer on
Works great, no muss...no fuss!
Posted on Apr 29, 2009
efs_perpends
  • 1996 Answers
SOURCE: epson stylus photo 2200 print head removal
Replace the cartridges.
Otherwise, it's unorthodox, but some users have found that this works in your situation. Remove the cartridge, cover the nozzle with a paper towel and use the pointed attachment of a vacuum to clean the dry ink from the cartridge. Be careful not to get ink all over. Then reseat the cartridge and print...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on May 26, 2009
SOURCE: No Windows 7 driver for Epson Stylus Photo 785EPX printer
There is a driver--it's provided by the Microsoft website. While your computer is connected to the Internet, connect your 785EPX to your computer via USB and then turn the printer on. The driver will auto download and install. I just did this on an HP DV7 laptop and the printer works fine, showing ink levels, too, though you have to access the printer properties to see this.
Posted on Jun 12, 2010
My Epson stylus 2200 will not even power up now. I don;t get any lights. I've check that the cord is plug in the whole way, exchanged cords, and tried different outlets.
hi ldbartz,
i/m sure you already check all cabling issue.
if none if its working mean you got power problem.
on every printer these days, all system powered from an adapter,
if nothing happen to your power or adapter, printer will go power on and the power led will go on also.
the adapter itself (for all epson) is located inside, you cannnot replace it without open your printer like canon printer.
that is my opinion.
Mar 16, 2011 | Epson Stylus 2200 InkJet Photo Printer
Tip
Manual Counter Reset Method
To manually reset the Ink Jet Counter that compels you to clean your waste pads. For the tip on how to clean your ink waste pads go here.
Please Note: In some cases, your printer may be leaking ink so much and so often that not only does your ink pads need cleaning, but you may need to replace the ink reservoir on your printer or you will have a leaking mess on your hands. This is a decision and judgment only you can make. If your printer is leaking quite of lot of ink, you may have to take it to an authorized Epson Repair Shop or Person. Find an authorized location by starting at Epson.com
The solution below is valid for most of the following printer models listed below this solution, some listed may not work, some not listed may also work it varies as this method is listed below is illegal for an authorized Epson Tech to release.
Thanks to the many user boards on the Internet for this solution that I know has worked for people I've helped here on FixYa.
Don't be discouraged if it doesn't work the first time. The key is in pressing the buttons exactly at the same time. So if this doesn't work the first time, try again and try again. Most people state they get it eventually.
[thanks to fixyourownprinter.com for the crux of this particular solution]
"Printer Onboard Control Panel Key Sequence"
"Press and hold the paper feed, paper switch and the power switch.
Once the power light and paper light flashes twice and the other lights are flashing release the paper feed and paper switch "and then press the paper feed switch".
The power, paper and ink lights will flash twice. At this point the protection counter has been reset."
Don't give up, if it does not reset the first time. The timing is tricky for some people.
Supported Epson Models that I am aware of, others not listed may work and some listed also may not work, it varies but don't be discouraged to try and try again.
You can also try the software download solution listed in this tip I posted.
Epson Stylus Сolor 400
Epson Stylus Сolor 440
Epson Stylus Color 480 LPT
Epson Stylus Color 480SXU / 580
Epson Stylus Сolor 600
Epson Stylus Сolor 640
Epson Stylus Сolor 660
Epson Stylus Сolor 670
Epson Stylus Color 680 / 777
Epson Stylus Сolor 740
Epson Stylus Сolor 760
Epson Stylus Сolor 800 / 850
Epson Stylus Сolor 860
Epson Stylus Color 880
Epson Stylus Color 900 / EM-900C
Epson Stylus Color 980
Epson Stylus Сolor 1160
Epson Stylus Color 1520
Epson Stylus Color 3000
Epson Stylus C20 / C40 / CL-750
Epson Stylus C41 / C42 / C43 / C44 / C45 / C46 / C47 / C48 **
Epson Stylus C50
Epson Stylus C60
Epson Stylus C61 / C62 **
Epson Stylus C63 / C64 **
Epson Stylus C65 / C66 and PE **
Epson Stylus C67 / C68 / D68 and PE **
Epson Stylus C70 **
Epson Stylus C80 **
Epson Stylus C82 **
Epson Stylus C83 / C84 **
Epson Stylus C85 / C86 and PE **
Epson Stylus C87 / C88 / D88 and PE **
Epson Stylus Photo RX420 / RX425 / RX430 **
Epson Stylus Photo RX500 / RX510**
Epson Stylus Photo RX520 **
Epson Stylus Photo RX600 / RX610 **
Epson Stylus Photo RX620 **
Epson Stylus Photo RX700 **
Epson Stylus CX3100 / CX3200 **
Epson Stylus CX3500 / CX3600 / CX3650 **
Epson Stylus CX3700 **
Epson Stylus CX3800 / CX3810 / DX3800 **
Epson Stylus CX4500 **
Epson Stylus CX4600 **
Epson Stylus CX4100 / CX4200 **
Epson Stylus CX4700 / CX4800 **
Epson Stylus DX4200 / DX4800 **
Epson Stylus CX5100 / CX5200 **
Epson Stylus CX5300 / CX5400 **
Epson Stylus CX6400 / CX6600 **
Epson Stylus CX6300 / CX6500 **
Epson Stylus CX7800 **
Epson PictureMate
Epson Stylus Photo
Epson Stylus Photo EX
Epson Stylus Photo 700 / IP-100
Epson Stylus Photo 750 / PM-770C
Epson Stylus Photo 780 / 790 / PM-780C
Epson Stylus Photo 810 / 820
Epson Stylus Photo 820 **
Epson Stylus Photo 825 / 915
Epson Stylus Photo 830 / 830U **
Epson Stylus Photo 870 / PM-875DC
Epson Stylus Photo R200 / R210 **
Epson Stylus Photo R220 / R230 **
Epson Stylus Photo R300 / R310 **
Epson Stylus Photo R320 **
Epson Stylus Photo R800 / PX-G900 **
Epson Stylus Photo R1800 **
Epson Stylus Photo R2400 **
Epson Stylus Photo 890
Epson Stylus Photo PM-890C
Epson Stylus Photo PM-A700 **
Epson Stylus Photo PM-G720 **
Epson Stylus Photo PM-970C **
Epson Stylus Photo 895/ 785EPX
Epson Stylus Photo 900 **
Epson Stylus Photo 925 / 935 **
Epson Stylus Photo 950 / 960 / PM-950C **
Epson Stylus Photo 1200 / PM-3000C
Epson Stylus Photo 1270 / PM-3300C
Epson Stylus Photo 1280 / PM-3500C
Epson Stylus Photo 1290
Epson Stylus Photo 2000P
Epson Stylus Photo 2100 **
Epson Stylus Photo 2200 / PM-4000EPX **
Epson Stylus Pro 5000 / PM-5000C
on Sep 17, 2008 | Epson RX620 All-In-One InkJet Photo...
Epson 2200 printer error code 40. What is error code 40 and how do I fix it?
Computer and printer may be set to different baud rates.
2. Computer is powered off.
3. Unseated or defective MIO card.
4. Indicates an abnormal connection break occurred while Transferring data from the computer.
5. Turn printer off and reseat the network card.
6. Verify that the printer serial configuration is set the same as the computer.
7. Check that all cables are connected to the EIO ports and that the EIO board is seated properly
  1. CBR Tech Solutions or http://www.cbrtechsolutions.com
Feb 20, 2011 | Epson Stylus 2200 InkJet Photo Printer
Do you know which connecting cables work with the Epson Stylus Photo 2200 printer. I see a sczi firewire 400? and don't know what the 3rd is. I am trying to connect it to a Mac Book Pro with snow leopard...
You should be able to connect to your macbook with a standard USB A-B cable, for most printers it's almost square at one end standard flat at the other.
You can get them from ebay or any pc/printer shop, just ask for a standard USB printer cable. Here's one on ebay:- Item number:180514570583.
For mac drivers for the printer, the best place to look is the Epson website, follow links for support and downloads, entering the details of you operating system and printer model as you go. You should arrive at a page which offers free drivers for your PC.
Jul 07, 2010 | Epson Stylus 2200 InkJet Photo Printer
Printer heads clogged on an epson stylus photo 2200. anyone know a repair facility in the philadelphia area?
I tried looking for one in the 19146 zip code but got nothing. You can contact the EPSON Connection at (800) 463-7766, Monday through Friday, between 6:00am and 6:00pm, Pacific Time, and ask a representative to do a more thorough search for your area.
Dec 08, 2009 | Epson Stylus 2200 InkJet Photo Printer
Stylus 2200, "print test page" in menu, unclickable.
- System Preferences
- Print & Fax
- Select Epson Stylus Photo 2200
- Open Print Queue
- In the top right corner of the Queue window click the Utility button
- Epson Printer Utility will open where you can check the levels and run cleanings and nozzle checks, etc.
May 07, 2009 | Epson Stylus 2200 InkJet Photo Printer
Epson 2200 Printer cannot be found on my MacBook Pro with Leopard
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=14402&infoType=Downloads
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
Mar 23, 2009 | Epson Stylus 2200 InkJet Photo Printer
Light purple cast to black and white prints
Known issue. Use QTR to print bw prints. Works great on my Epson 2200.
http://www.quadtonerip.com/html/QTRoverview.html
Dec 06, 2008 | Epson Stylus 2200 InkJet Photo Printer
Work in Europe?
According to the rear panel of my 2200, it will accept 120VAC 50 ~ 60 HZ. Which means that outside of a proper plug adaptor, it should work fine. You need to adapt the epson power cable to whatever the French use. Be sure it is 110~120 VAC. Ran into some 220 in Italy
May 26, 2008 | Epson Stylus 2200 InkJet Photo Printer
Help with waste ink problem on Stylus Photo 2200 printer
Hi Beckedy;
i have a solution that may help you but I need more info. Email me at gamesreplys@yahoo.co.uk
Dec 07, 2007 | Epson Stylus 2200 InkJet Photo Printer
23 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
