Question about The Audio Players & Recorders
No radio reception from one turn on to the next. what kind of antenna does it use?
  • 70 Answers
SOURCE: better fm reception
Is it just a single wire?
If so, purchase a cheap FM antena. It looks like a "T" when spread out (4' to 5'). That should help.
You can purchase an "amplified" antenna, but if your area reception is really bad (such as in a valley) the antenna would just amplify the noise as well. Look for web based radio in this case or if you have cable there are stations on it.
Posted on Jan 11, 2008
  • 1118 Answers
SOURCE: Very poor FM radio reception
I would try a CB radio shop at a truck stop, they will have what you are looking for.
Posted on Jan 31, 2009
  • 297 Answers
SOURCE: poor radio reception
could be or the station you have between towers you will get static.
Posted on Jul 15, 2009
  • 509 Answers
SOURCE: antenna on radio broke
Radio Shack can get you an antenna, or a long wire (or wire coat hanger actually works too)
Posted on Aug 21, 2009
SOURCE: 2003 towncar radio reception and trunk release
where is the antenna wire located on the 2003 Lincon Town Car?
Posted on Dec 22, 2009
Poor reception
There are many causes for poor reception on a cb radio one cause may be poor or poorly assembled antenna, a good antenna should be of highest gain and put up as high as possible ,An omnidirectional antenna or Ground plane will hear moderately well
in all directions but a directional antenna or Yagi will hear great only in the direction it is turned you will certainly have to decide what you or your homeowners association will allow.
Also and finally The sun is a major factor in communications Propagation sometimes no mater what your setup the reception is terrible.
Feb 24, 2014 | Uniden Bearcat Pro PC68XL 40-Channels Base...
Am fm reception bad
FM reception is weak
What to do
• Extend the power cord as much as possible. The FM antenna is in the power cord.
• Move the power cord to adjust the FM antenna
• If you still have problems with FM reception, you may need an external antenna.
* Call Bose®Customer Service to request one.
The external antenna on your radio is a coax (round) design It needs an adaptor and an antenna which are cheap.
Easy to make, radio shack "F" connector 90 degrees or straight, to 300 ohm wire connections. Attatch a 300 ohm flat ribbon antenna cable to those two screws and plug into radio and see how your reception is. You will need to position the antenna wires to get best reception. I have hid them in back of paintings and so on.
Cheapest solution next to putting an extension cord on radio power cord.
Jan 03, 2011 | Bose Wave Radio
FM reception for Sony ICF-CD513?
The electrical cord acts as an antennae for this radio. Uncoiling the cord will give the best reception for FM. Rotating the radio (and built in ferrite bar antennae) will give the best reception for AM listening.
Jan 31, 2010 | Sony ICF-CD513 Clock Radio
Improve reception
HI there,
Well Yes you can improve the reception, please follow the below steps -
Improve FM Radio Reception -
1. If you don't have an antenna connected to your FM receiver, purchase a simple dipole antenna--a simple T-shape flexible wire-- and connect it to the FM antenna inputs on the receiver. Because FM signals are directional, you'll want to experiment with the positioning of the wire to find the best reception of the station you're trying to receive.
2. If you're still not getting a good signal, try an indoor amplified antenna, which you'll find at an electronics store. Don't buy one unless you get a guarantee that you can return it for full credit if it doesn't solve your reception problems.
3. If your signal is weak because you live a long way from the transmitter, install an outside antenna and mount it as high as is practical. If you're primarily interested in getting signals from one station or from a group of stations in one direction, get a directional antenna and point it toward the transmitters.
4. If you're using a portable FM radio where the only antenna is the power cord, stretch the cord as straight as possible and experiment with positioning again.
5. Temporarily switch to monaural mode to improve a weak signal on an FM receiver.
Improve AM Reception -
1. Gradually rotate the radio 360 degrees. Leave it in the position where it sounds best.
2. Reverse the AC plug if it isn't polarized. (If you can flip the plug over, then it's non-polarized.)
3. Plug the radio into a different AC outlet.
4. Move the radio closer to a window.
5. Experiment to learn if appliances and powered products in your home are causing interference: computer monitor, television, electric blanket, light dimmer, fluorescent light, hair dryer, air conditioner, smoke detector. If possible, turn off the offending item. Otherwise, move the radio to another room.
6. Upgrade to an external antenna if your receiver, tuner or radio has a place to connect one.
7. Buy a passive AM antenna that doesn't need to be connected to a radio or receiver.
Good Luck!!
Dec 29, 2009 | RCA RP5430 Clock Radio
Reception is very poor. Grounding issues? Please
Reception has little to do with grounding. The ground plan is for transmitting. As long as the coax is connected and is in good standing, it should receive fine regardless of grounding.
There are a few reasons you may have bad reception.
  1. Turn the RF GAIN all the way up. This is your receive sensitivity.
  2. Squelch is too high. It should only be turned up enough to cut out the background noise.
  3. Poor antenna. If the antenna is cheap, and not made well, this could be the problem.
  4. Not enough of the antenna above the vehicle. It needs to be at least 60% of the antenna above the vehicle.
Hope this helps!
Oct 21, 2009 | Cobra 29 LTD CB Radio
No AM reception for car get FM reception.
I was having the same problem with a jvc kd hdr 30. I Installed it myself over a year ago and never wanted to deal with the issue. Finally, I decided to take a look at it today.
On my head unit, all wires were connected except one blue one with a tag that says "do not connect to power, for remote device or power antenna only." This unit is in a '97' MBZ E320 with no visible antenna; I think it is part of the windshield. In any case, between the wiring diagram in the manual and the harness that is part of my car, I was left with 2 blue wires to choose from, one with a white stripe and one with a gray stripe. After testing both for power or ground, I determined neither had power with key on or off. Both had high resistance ground when compared to the chassis ground. In other words, I measured between chassis and these wires. First, I took a wire and connected it to the chassis ground and connected the other end to the blue wire coming from the unit while tuned to a local am station. This simply killed all reception am or fm but did not harm the unit. Next, I connected the blue wire with gray stripe of the car harness to the blue wire of the unit and again this killed all reception. Then I connected the blue wire with white stripe of car harness to the blue wire of unit and presto magic I had great am reception.
I am guessing that this blue wire with white stripe must be part of the antenna itself or perhaps is a connection that increases antenna power. Maybe 'power antenna' on tag refers to an actual powered antenna (like as in amplified?) and not as in an antenna that rises up out of fender, as I believed.
This may not help the first person with the question, but maybe it will help someone out there who searches for these kinds of answers like I do from time to time.
May 31, 2009 | JVC KD-PDR30 Car CD/ MP3 Player
Bad reception
Sounds like you have an antenna problem. Find where the antenna plugs into the radio. Unplug it and find a nail or something the same diameter as the center pin wrap about 3-5 turns of a four foot piece of wire around the nail and plug the nail into the antenna input on the radio. If it clears up reception you have a bad or grounded antenna. Follow the antenna wire back to the windshield or fender etc. mounted antenna, sometimes there are other plug in points that get knocked loose.
Jan 12, 2009 | JVC KD-G720 CD Player
AM Reception
what kind of car are you driving. on some cars the antenna need to be extended in order to recieve am reception.
May 27, 2008 | Kenwood KDC-222 CD Player
Excessive static on AM stations. Waves in and out. Not so on car radio. Is there an antenna to eliminate this?
Turn on the radio and turn the AM/SW BAND switch to the AM position. MW appears in the display. Use the outer ‘fast’ tuning knob to find stations, fine tuning with the inner ‘slow’ knob
when needed.
• If there is interference from adjacent stations, place the BAND WIDTH control in the NARROW position. If there is no interference, leave it in the WIDE position.
• If there is excess background noise, turn on
the SW LPF switch, which may minimize the noise.
• If a station is so strong that audio distortion occurs, reduce the gain level with the AM/SW RF GAIN control knob by turning it counterclockwise.
• The telescopic antenna does not have to be extended for AM reception. The radio has an internal, directional, ferrite-bar antenna for AM reception.
• To optimize AM reception, swivel the radio until maximum signal strength is achieved.
All of that being said: It's very tough nowadays to receive AM in this 2008 electronic world. If your able install a longwire SW antenna outside, and have access to a good earth ground, you can boost the AM signals and beat the noise being generated all around you.
Jan 08, 2008 | Grundig S350 AM/FM/SW Radio
22 people viewed this question
Top The Audio Players & Recorders Experts
Jose Ma DM.
Jose Ma DM.
Level 1 Expert
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
