Question about Garden
String trimmer hard to pull start
Removed plug and pulls freely. Checked exhaust, not stopped up.
    Top Expert:
  • Garden Master
  • 12,962 Answers
High compression and need to eat your wheaties.
Some of those units can be a bear to start - might have to get one with a compression release for easier starting.
Posted on Apr 30, 2017
String trimmer Won't start. Hard to pull starter cord with spark plug installed.
Remove spark plug turn trimmer so that spark hole is down and pull starter rope until all old fuel is evacuated from cylinder, place spark plug back in and try. If this is not problem and especially if it is still hard to pull you may have a ring that has broken and partially hung in cyl.
Aug 07, 2017 | Garden
Trimmer pull cord stuck in pulled position. How do I go about finding and fixing problem? Not sure exactly which screws/bolts to remove to get at the assembly.
How to Fix a Weedeater's Stuck Rope ' Home Guides ' SF ... > ... > Mortgage & Loan Payment Basics
A gasoline-powered string trimmer has cords on both sides. Most people ... In order to troubleshoot and fix a stuck cord, you have to remove the starter housing. ... Swivel each plate until it locks into position and then tighten the screw to hold it.
WeedEater string pull repair STRING WON'T RECOIL ...
? 6:35
Aug 8, 2013 - Uploaded by AdamDIY
WeedEater string pull repair STRING WON'T RECOIL - FeatherLite XT260 ... How To Properly Replace Fuel Lines On a Weed Eater Trimmer
Nov 26, 2015 | Garden
I have a Ryobi 430 4 stroke weed wacker frozen up can not pull the string take spark plug out very easy to pull full rotation easy to pull when you pull the string put the spark plug back in you can pull...
When you remove the spark plug is it very wet?
after the plug is removed when you pull the cord sharply does liquid come out from the hole?
Nov 28, 2014 | Garden
With the plug removed the starter should pull very easily. When trying start did the cutter head try to spin? If yes clutch springs may need replacement
Jul 24, 2013 | Garden
G-force 3030 can't pull string to start? Engine
bad carburetor. replace it and that should solve the problem
Feb 04, 2013 | Garden
Craftsman 32cc gas trimmer ran a couple times this season, then will not start. Changed plug, new gas mix, cleaned filter and spark arrestor. No luck. Pull cord is hard to pull in the first foot or so,...
Pull the spark plug and hold the side against the engine while pulling the string. check to see if there is a spark you may need another person to help. Was the air filter oily when you cleaned it? If so you might need to remove and clean the carburetor.
Jun 07, 2011 | Craftsman Garden
Seized engine
Take the spark plug out and fill the cylinder with oil. Place a piece of electrical tape over the spark plug wire opening. Let it set for an hour or so, leave the plug out and try to pull the cord to see if the piston will move freely. If it does, remove the electrical tape, install the plug, connect the plug wire, fill with the correct mixture of fuel, and attempt to start. Note: cover the spark plug hole with a cloth or shop rag to catch any excess oil that will be expelled when you pull the cord through. If it is still frozen.... may be time for a new one.
Jun 15, 2010 | Husqvarna 28cc Gas Line Trimmer
3 year old ryobi gas trimmer won't start...didn't winterize. I follow the start-up directions and it won't turn-over.
This could be caused by tons of problems. I'm going to assume you've checked the spark at the plug first. If not then you'll want to pull the plug out, leave connected to the wire and check to see if there's a blue spark when you pull the starter string. When my trimmer finally wouldn't start (or keep running) I found there were small cracks in the fuel lines. It was causing problems with the prime (for starting) and then with the running. My engine wasn't leaking fuel so it was hard to find.
May 02, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
