I want correct answer but no answer right what are you doing
How do I program Amazing Amanda doll
Just turn her on and she will ask all sorts of things, she will say things like mommy, squeeze my right hand until i say the correct hour, then you will squeeze HER right hand till she says it, or the question shes asking, then let go when she says the correct answer.
Jul 19, 2014 | Playmates Toys
Wrong trigonometric answers
The sine of 0.5 radians is about 0.4794, so your calculator seems to be giving you the correct answer in that case.
The sine of 0.5 degrees is about 0.00872, which your calculator may be displaying as something line 8.72 times ten to the negative 3. Look to the far right end of the number: do you see "x10-3" with the "-3" superscripted? In that case, again your calculator is giving you the correct answer.
Sep 10, 2012 | Casio FX-115ES Scientific Calculator
I have just taken delivery. how do i open the door
You don't say what Model you have, so I have to guess that is is a counter - top one. Just push the button in the lower right. On some model it doesn't look like a button, but just a section of plastic in the lower right corner. See the photo below.
If this the answer, please post your model number with comment.
If this is the correct answer, please also post and rate this answer.
May 14, 2011 | Hoover Microwave Ovens
How do I set the date and time and my hp passed all the fax tests but I do not receive faxes.
Follow the instructions below to set date and time on printer
Setting the date and time on an HP All-in-One Follow these steps to set the date and time from the control panel.
  1. Press Setup .
  2. Use the right arrow button (c00377082.gif ) to highlight Tools , and then press the OK button.
  3. Select Date and Time from the Tools menu and then press the OK button.
  4. Enter the month, day, and year by pressing the appropriate numbers on the keypad. After the date is entered, the Enter Time screen displays.
  5. Enter the hours and minutes by pressing the appropriate numbers on the keypad. After the time is entered, the Tools menu displays.
  6. Press the Back button to return to the main menu.
Follow the steps to solve "Unable to Recieve Fax" Issue
Basic requirement are..
1. Rings to answer should be 2 rings greater than your Answering machine rings or Voice mail ( set it to 6 instead )
2. Auto Answer should be on
3. Turn off ECM ( Error Correction Mode )
Use these steps to change the Rings to Answer setting.
  1. On the product control panel, press the setup button (c01661990.gif ).
  2. Use the right arrow key (c01661991.jpg ) to select Basic Fax Setup and then press the OK button (c01335940.jpg ).
  3. Use the right arrow key (c01661991.jpg ) to select Rings to Answer and then press the OK button (c01335940.jpg ).
  4. Use the right arrow key (c01661991.jpg ) to select the desired number of rings and then press the OK button (c01335940.jpg ).
Make sure that the Auto Answer feature is turned on When the Auto Answer feature is on, the HP fax product automatically answers incoming fax calls. When off, the HP fax product does not answer any incoming fax calls. To turn on the Auto Answer feature, follow these steps.
  1. Press Auto Answer on the product control panel. When the Auto Answer button is lit, the feature is turned on.
  2. Try to receive a fax.
Make sure that ECM is Turned Off ( Error Correction Mode )
  2. Use the right arrow key (c01661991.jpg ) to select Advanced Fax Setup , and then press the OK button (c01335940.jpg ).
  3. Use the right arrow key (c01661991.jpg ) to select ECM , and then press the OK button (c01335940.jpg ).
  4. Use the right arrow key (c01661991.jpg ) to select Off , and then press the OK button (c01335940.jpg ).
Try to Receive Fax Now.
These steps should resolve the issue and you should be able to receive fax
Thank you for contacting FixYa Team
* Please rate this solution with Thumbs up and comment to help us improve providing support
Nov 13, 2010 | HEWLETT-PACKARD HP 6500 All In One Printer...
I was changing the ignition wires on a 93 probe gt 2.5L, I went to do something else and forgot the order they need to go. standing at the nose of the car what is the order starting on the firewall side...
Hello difelice5: My name is Roger and I will help with your answer. The correct fire order is 1-2-3-4-5-and 6. I also attached a picture of cylinder reference and the correct fire order in the cap. Should you need further help please just ask. Please rate the answer as this way I know it was helpful. Thank You for using Fix Ya. Rogerc18087e.jpg
Jun 29, 2010 | 1993 Ford Probe
Firing order
Hello bailsdenied: THe fireing order for a Acura NSX 3.2L DOHC (vtec) engine is 1-4-2-5-3-6. If this is the correct model of car then it is right. If this is not the right car then ask and I will send the correct one. Please rate the answer you recieve as this lets us nkow you were provided the correct answer to your question. Thank you for using FixYa. Roger55224f4.jpg
Apr 25, 2009 | Acura TL Cars & Trucks
Can not get right answer
Unfortunately, you kind of have to do this backwards or you get "error".
Enter .07, X, 5, =, display shows .35, then 2nd LN to get exponential, display shows 1.419067...., then X, 4000, =, answer is 5676.27
Nov 17, 2008 | Texas Instruments TI-30XA Calculator
Time Change
push menu middle top button . scroll down to world time on middle 4 way button press OK top right hand button set time with middle 4way button press OK
Jul 29, 2008 | Uniden 5.8GHz Expandable Cordless Phone...
