Question about Sewing Machines
I have knit my first sock on 4 needles and it says to finish off the toe with the Kitchener stitch. No explanations on how to do it.
  • 27 Answers
This should have a thorough explanation and a video on how to do what you need.
Posted on Apr 30, 2017
Please show the knitting term ssk with illustrations?
can't give you illustrations but. SSK means slip stitch knit. Which means slip the next stitch onto the needle as though you will knit it then knit the next stitch instead keeping the slipped stitch on the needle and go ahead and finish the row.
Aug 29, 2017 | Sewing Machines
How do I do a Kitchener stitch
A thorough explanation and a video are here. Hope it helps!
Apr 30, 2017 | Sewing Machines
How to knit this, K2. K2tog, yfwdtwice. Sl1.K1.PSSO. K19
knit 2 stiches., knit 2 stitches together, bring yarn forward then over the needle and stitch like this twice, slip 1 stitch, knit 1 stitch, then pass the slipped stitch over the knitted stitch. Knit 19 stitches
Apr 27, 2017 | Sewing Machines
What size needles for bulky/12py wool?
It depends on your project. You need the size needle that will give you the stitch width and stitch length called for in the pattern. The pattern calls for a specific gauge, so you'll need to try out different needles, knitting a swatch on each needle size, and counting the number of stitches across and down to match the pattern specification. Does the pattern not give you a needle size? Needles come in either straight or circular in all various sizes as long as you stay within the same brand needle. (Needle brands differ from one to another, so try to stay within only one brand.) So a straight needle size 6 should be the same size as a circular needle size 6 (of the same brand).
However, although it may call for a specific size needle, you will still need to knit some test swatches because knitters usually knit looser or tighter, so one needs to adjust the needle size to accommodate those differences, ie someone who knits tightly may get 8 stitches to an inch, but a loose knitter may get only 6 stitches. But if the pattern says to cast on 48 stitches in for row 1, that means the 8 stitch gauge will yield a project that measures 6 inches wide (48/8=6). But a 6 stitch gauge will yield a project of 8 inches wide (48/6=8). The result would be one project will be 2 inches wider than the other.
But that is only half of the problem as you would still need to measure the number of rows per inch to get the length of the project. If there are more rows to the inch than specified, a garment with say an armhole that may be too small. If there are fewer rows to an inch, the result may be an armhole that is way to big.
Be very careful with your pattern and yarn selection. You will be much more successful if you stick to the number ply and yarn weight specified in the pattern, ie if the pattern calls for 2-ply 2 oz yarn, there may be some particularly difficult issues with substituting a 4-ply 4 oz. yarn. You may end up with a project that will not fit. For instance, you wouldn't want to use a heavier yarn to knit a baby garment. Baby garments usually call for baby yarn which is a specific ply and weight.
How to Measure Your Gauge in Knitting
earthguild com
3 Things You Might Not Know About Knitting Gauge Adjustment
Oct 30, 2016 | Sewing Machines
What do yon and yfrn mean in a knitting pattern?
yon is usually Yarn On (or over) Needle. This is a yarn over between a purl and a knit stitch. (After the purl stitch, keep the working yarn in front of the needle. Then place the right needle into the next stitch so that the right needle is behind the left needle in the stitch. Wind the yarn around the needle and pull the loop through.)
yfrn is a Yarn foward and round the needle. This is a similar yarn over to the yon but is a little larger. The difference is that the yarn over is done after a knit stitch and before a purl stitch. After the knit stitch, bring the yarn in front of the needle. Wrap the yarn anti-clockwise around the right needle so that the yarn is again at the front of the work. Place the right needle in the front of the next stitch on the left needle. Then do a normal purl stitch.
You can see some videos and still photos here: .
I hope this helps.
Oct 22, 2016 | Sewing Machines
What does C4 mean in knitting
I believe it means a 4 stitch cable or a stitch made with 4 threads. I found this on a knitting website and it might help:
"A 4-stitch cable will be made with 4 stitches, a 6-stitch cable with 6 stitches and so on. Most of the time these sets of stitches are divided equally.
For the 4-stitch cable the first 2 stitches are slipped purlwise onto a cable needle or double pointed needle whichever you prefer. You will knit the next two stitches on your left needle, and then knit the two stitches from the cable needle. The knitting stitches are crossed over each other and you have created a nice little cable stitch."
Here is a YouTube video for the stitch: How to Knit The 4 Stitch Cable
Mar 05, 2015 | Sewing Machines
How do I cast off in knitting?
Take a needle several sizes larger than the ones you have used for the knitting - so the loops will be larger and the edge looser, knit the first two stitches onto the larger needle then use the tip of the other needle to lift the first stitch over the second one and right off the needle, so it is looped over the second stitch, but is no longer on the needle.
Knit another stitch and repeat the lifting over. I f you are casting off all the stitches continue to the end of the row and then cut the yarn, pass the end of the yarn through the last stitch and draw it up.
If you are only casting off part of the row then move the last stitch onto the right size needle and continue knitting on the stitches left in the row.
Dec 03, 2014 | Sewing Machines
What does C6F in knitting mean
A six-stitch left-twisting cable (abbreviated C6F). Check this knitting for dummies sight:
How to Knit Six Stitch Cable
Sep 02, 2014 | Sewing Machines
How t change knitting instructions 5ply to 8ply
First of all try a guage/tension swatch. Cast on 25 stitches, use 5,5 mm needles and knit stocking stitch for 4 ins. This should tell you if the pattern will work with these needles and yarn.
Count your stitches over the 4 ins and see wht you have to the inch. This is your guage oe=r tension then check with your pattern to see what the guage/tension is.
To change a pattern this drastically needs an experienced knitter
If it is the pattern only that you want. then find a pattern for 8 ply and use the stitch count on the original pattern and modify for the new pattern.I wish you luck.
May 13, 2014 | Sewing Machines
Hemming knit fabric with ball point needle but have skipped stitches.
you may need a new ball point needle, the tip to the needle could have some damage to it. How to Choose Sewing Machine Needle for Knits eHow
Feb 21, 2014 | Janome Sewing Machines
Sewing Machines Logo
23 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
