Question about Cooktops
I have a brandt hob. 2 hotplates on one side work perfectly. The 2 on the left work intermittently and switch off frequently.
  • 1462 Answers
SOURCE: Only 2 hobs work
this is almost certainly a wiring issue at the mains connection block, there are links which have not been tightened down. there is usually a diagram adjacent to mains block telling you what to do. connection block is covered by a plate. take plate off and tighten all terminals making sure links have been inserted. switch of at mains of course
Posted on Jun 06, 2007
  • 222 Answers
SOURCE: hob turns off
hi im gerbee my suggestion is replace the pcv control wat brand u have,always also in philipines the electric hob is so very sensitive,the pcv cotrol is not repairable.or next time u by a new one gas cooktop more ok compare to electric ceramic hob, or use electric ceramic hob w/knob control compare to sensor type,i think the part of the sensor or pcv control is so very expensive,that why i buy an another one.dont try to repair more difficult to com.tnx
Posted on Dec 02, 2008
SOURCE: Replacing faulty regulator for hotplate
Remove hotplate and oven control knobs. Under the 2nd and 5th knobs is an extra screw which holds on the front cover. Unscrew these and free the cover then access is gained to the screws (2 on each edge) which removes the plate to which the regulators are fixed.Remove the faulty regulator by unscrewing it from the plate,(2 screws) It is an easy job then to install the new part taking care to put the correct wires on the correct terminals. Reassemble, job done!
Posted on Jan 13, 2009
SOURCE: have a baumatic ceramic hob displayin letter 'L'
Got the same problem, and remembered I've kept the manual book
L means locked. I dont know how Ive managed to do this as well
Anyway it says:
Cancelling the key lock
After switching ON the control the child safety feature can be deactivated. Here it is necessary to simultaneously operate the front right cooking-zone-select-key and the MINUS-key and then operate the MINUS-key alone. If all steps hae been carried out in the right order within 10seconds the key lock gets cancelled and the control is OFF. Otherwise the input will be considered incomplete, the control remains locked and switches-OFF after 20 seconds.
After a renewed switching-ON/OFF key all displays show 0", the display dots are blinking and the control is ready for ooking. If a cooking zone is "hot", "H" will be displayed instead of the static 0".
Followed their instructions & still not worked. ,I am still confused and baffled after these instructions........................
Posted on Sep 29, 2009
  • 3382 Answers
SOURCE: hob will light up as usual, then switch itself off after 3/4 mins even with pans on hotplates
That could happen if the pans are not compatable with the unit.
Posted on Dec 13, 2014
Had hob for 18months no problems, now two hotplates wont work & today the child lock light is on & nothing else will work, nothing.
remove the child lock setting and the remainder will work
those hot plates that were not working may need new switches, thermostats or replacement elements
call an accredited appliance electrician to get it all working again
Jun 13, 2015 | Cooktops
I have just moved into a new apartment in France, and we have a 2 ring touch screen hob. There are no instructions or booklets but it says "Schott ceran brandt" on it. It works, as I've worked out how to...
i presume that you have a induction cook top. if so not all pots and pans will work on them. i have never had one but i do know this could be your type of problem. do some research on what pans to use on a induction stove.
Jul 02, 2017 | Cooktops
I have a neff T1.D20 dual circuit hotplate but although the inner lights up and gets hot the outer part doesnt. Is the outer part supposed to?
I have a T172 model which also has a dual circuit hotplate.
In the control area you should find a dual circuit control pad - this has two concentric circles on it. With the hob switched on, pressing this button will chnage the mode of the dual circuit hot plate bewteen:
1. Just the inner part
2. Both the inner and outer together.
When the hob is switched off using the Standby control pad, it remembers which mode was selected and will therefore work the same next time it is switched on. However, it is worth noteing that when the mains power to the hob is interuppted, either by an isolator switch/breaker, or a power cut, the hob defaults back to just the inner ring mode.
Oct 03, 2009 | Neff T1323 Electric Cooktop
Neff induction hob safety lock
safety lock is on. How can I release safety lock?
Jun 18, 2009 | Cooktops
We have a neff induction hob which for some reason has no instructions and my little brother managed to lock it (so that a key symbol lights up above the on switch and all functions are disabled, i need to...
Try - set all hotplates to setting 2. Switch off jot plates one after another starting with front right in clockwise direction, touch main switch for at least 5 seconds & a signal will sound - this activates & de-activates the child lock - or so the instructions say...
To use the hob with the child lock on - it says to press the main switch for more than 4 seconds & that lets you use it.
Jun 15, 2009 | Cooktops
Jan 11, 2009 | Belling Cooktops
Safety lock on Neff hob
I have a Neff T4344N0/08. I cannot stop all four hobs flashing - ie: I press the 'on' button all four flash, I then choose which one I want to use plus the number but they all keep flashing instead of stopping after the usual three or four. Please help - have I pressed something I shouldn't, perhaps a child lock?
Sep 27, 2008 | Neff 23 in. T4343 Electric Cooktop
PROBLEM WITH HOTPLATES SWICTHING OFF
Sometimes this happens if the pan bottom is not completly flat or is highly polished. Darker, flat pans work best. It sounds as if the safety is cutting off the burner.
May 31, 2008 | Cooktops
Only 2 hobs work
Jun 06, 2007 | Zanussi 23 in. ZKT641H Electric Cooktop
Cooktops Logo
83 people viewed this question
Top Cooktops Experts
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
