Question about Vacuums
Tool error PU3650, vacuum shuts off after say 2 minutes and wrench symbol shows on display. Plenty of suction, 4 bars on display. Central Quiet Clean. Under year old.
5 Suggested Answers
  • 45 Answers
SOURCE: How to for Belt replacement and solution to suction loss
You say it lost its suction, then you also say this is plenty of suction power, seems you cant figure out the prob. Try cleaning the fan on the suction blower. The blades can get chocked with dust which will give you a reduced suction.
Posted on Jan 06, 2008
SOURCE: Roomba shuts down after a few minutes
The brushes are clean on the outside, but probably not inside of the little yellow contact on the end. Also the junk that collects on the brushes finds its way into the gear box. Mine kept shutting down w/ the "Please remove and clean Roomba's brushes" message. I finally gave up and took it apart. There was a surprising amount of junk in the gear box. After I got it apart, I cleaned it out and I even used a straight pin and a pair of tweezers to get all of the gunk out. Now it runs like new. I'm no mechanic, but I used to help my daddy fix things around the house. I posted my solution to the problem and it has worked for a couple of other people too.
Posted on Dec 30, 2008
SOURCE: Suction loss when handle is tipped back to clean carpet
Ours did the same thing. I cleaned the filter and canister thoroughly. It needed to be cleaned, but that didn't fix the problem. I removed the plate under the carpet brush bar (three quarter-turn screws) and removed all hair, lint and threads from the rollers and brush. THEN my husband found the real problem: a piece of flexible hose running from the head into the hose (on the left side when behind the vacuum) was completely clogged. The hose will detach from the head, and you can remove debris. Once that clog was removed, the hose easily re-attaches, and we had great suction once again.
Posted on Feb 14, 2009
  • 83 Answers
SOURCE: lack of suction in hose
That popping sound is the bleed valve activating - it indicates that there is a blockage in the machine somewhere, probably in the wand if you're saying that there is no suction in the wand.
- Take the wand off the back of the machine - press the two gray buttons to separate it from the hose - hold the wand in the air and look through it - if you can't see the light coming through the other side there's a blockage in the wand - taka a long object like a meytal hanger and remove the blockage.
If that's not the problem, call the Dyson helpline for further troubleshooting, they know what they're doing.
Posted on Jul 30, 2009
There are 4 Symbols, next to the suction dial, on the Electrolux Epic 6000 SR vacuum cleaner . . . what does each symbol refer to ? J P Mac D
the dials refer to types of dirt.The higher the dial the heavier the dirt.This is for the auto shut off when the bag is full.The best setting is in the middle.If you are vacuuming up fine dust suck in some Kleenex before this will coat the bag and prevent premature shu toff.
Apr 29, 2015 | Electrolux Vacuums
Why does the suction stop after 10 minutes of use on my Dyson DC43?
Your vacuum may be overheating and shutting off the suction motor. Clean the cyclone assembly and the filters to see if they could be restricting the airflow.
Jun 18, 2014 | Dyson DC43 Purple Animal Bagless Upright...
Vaccum afuera 550 start few minutes and stop few secondes, after 10 min its stop 30 sec and start 3 sec, after 20 min start ok
Your vacuum may be clogged, overheating and shutting off. Check for obstructions in the hose by laying it as straight as possible and shining a flashlight in one end while looking thru the other end. If you have a curved hose end, try holding the suction hose from another vacuum while checking for airflow in the opposite end.
Nov 06, 2013 | Electrolux Central Vacuum
What do I do when there is no suction. My central vac just stopped picking up and though I emptied the machine and replaced the filter there continues to be no suction.
1. If it's an older model, the hose is likely well worn and probably has leaks at each end where it attaches to the handle and connector at the other end. If this is the case, a new hose is needed.
2. A blockage in the hose. To check the hose for blockages, detach both ends and drop a coin down one end. Lift the hose a little at a time so coin drops out the other end. If it doesn't, there's a clog. Please don't try to take it apart to remove the clog. If you can't get it out, take it to a reputable vacuum repair shop and let them.
best way to clear an obstruction is to blow it out by attaching the wall end to the exhaust of a shop vacuum, or using an air compressor.
You can try holding the wand end of the hose directly to the CV in port and turning the machine on. This provides essentially the same action as the previous method.
If neither of these work, try a combination of the two. Or using a shop vac, hold the wall end to the exhaust of the vacuum and the wand end to the in port of the shop vac. Turn shop vac on and the obstruction should come out.
Borrow a good strong shop vacuum if you need to.
If these methods fail, take it to an authorized Aerus Electrolux store and have the service tech try to clear it. Care must always be taken when trying to clear an obstuction with a long object, especially if it's pointed. I've seen many hoses that have shorted out and even caught fire due to the wiring accidentally being "nicked
3. Is there suction at the end of the hose, or is it just at the power nozzle there's none. If the hose has good suction, check the power nozzle airway. If it's blocked it can easily be cleared by pushing the clog back toward the brush with the handle of a wooden spoon, or other similar object.
Jan 15, 2011 | Electrolux Pu3650 Central System Vacuum
Seems to be a short in the power nozzle (light and beater bar sporadically work) while suction is just fine. How to fix the short?
I am having the same problem...great suction but unit on the floor won't vaccuum. I hit the reset button and the rollar still won't work!
Feb 21, 2010 | Electrolux Central Vacuum
DC07 plenty of suction but not picking up
You have either stretched or broken the belt that drives the beater bar. Replace the belt.
Jim
Dec 03, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Central vacuum with new motor shuts off and throws switch
Your mini breaker is probably bad if its a new motor. Its found on the relay board and they can weaken over time, especially if you had a bad motor before that tripped it a lot.
Oct 31, 2009 | Vacuums
When I turn on mt dyson is sounds normal. once I
With the DC14 in its upright position, and looking from the back, there is an access hatch just to the right and bottom of the dust canister. Remove this and check for any obstruction. With the hatch still removed, tilt the handle back (as if vacuuming a floor), and you should spot that the mechanism in to which the access hatch fits changes over from one hole to another. This is how suction is transfreered from the telescopic arm to the brush bar when the unit is taken out of the upright position.
With the handle tilted back, the hole you can see is one end of a flexible pipe that leads to the brush bar. Check for any blockage and/or foriegn objects. If there is no obvious problem, you'll need to check the other end of the pipe. You can do this by removing the toe plate on the bottom of the brush bar area. The plate is held by 3 or 4 half turn fasterners - a 5 pence piece is ideal for undoing these.
If still no joy, the only other thing it might be is that the brush bar isnt spinning - this isnt actually lack of suction, but without brush rotation any upright hoover is far less effieicnt at picking up bits from the floor. Brushes not spinning on a DC14 is quiet a difficult thing to fix on a DC14 as there are two separate rubber belts, one of which is hidden under a plastic cover. There is also a clutch mechanism between the belts that can cause problems some times.
Oct 09, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
