Question about Briggs Garden
Got a 1972 snapper tiller for free but my question is there is to wires that are cut but coil don't now what they are for or what any help will be great thank It a 1972 Briggs and Stratton 3hp motor
    Loyalty:
    Visited the website for 30 consecutive days.
  • Briggs Master
  • 873 Answers
The wire may be the ground for the coil it runs to the motor brake and grounds the motor out when you apply brake.
Posted on Sep 22, 2017
SOURCE: I need a manual for my MTD Huskee 5hp rear tine tiller
I went to MTD web site and they had all the manuals for all there products. You will need a model and serial number to get them. Thank you for responding back to me.
I got the manual for the tiller and the engine.
Posted on Apr 13, 2009
extroitive
  • 35 Answers
SOURCE: briggs & stratton 3 hp engine will not start
likely needs a carb kit
Posted on Apr 19, 2009
  • 246 Answers
SOURCE: Manual or parts list for Moto-Mower Front Tine Tiller Model 500
Hello:
>>You can Use the Site Addys at this Site Addy; http://www.yetmans.mb.ca/antiques.html to Search and Locate New/Used Parts or for Manuals for this Unit.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
John
Posted on May 10, 2009
SOURCE: wiring on an old 5hp Briggs and Stratton engine
The "heavy wire" connects to the spark plug. It should have a plug connector attached. There are 2 small wires. One of them grounds to the engine block (probably through one of the screws that holds the magneto in place). The other wire goes to the condensor/capacitor.
Posted on Dec 30, 2009
  • 12 Answers
SOURCE: Briggs & Stratton 3hp engine Flymo won't spark/start
Sounds like u are leaking spark before the plug. Sand paper off the fly wheel and magnet, and also the bottom of the coil legs. I like the ol folding match book thickness when setting the gap back between the two. If this engine still has the points and condenser u also need to remove the flywheel and check those out. Clean the pint contacts with the sand paper and make sure with your flaslight that the small wire out of the point box is not grounding out from a bad spot somewhere also. If so, use some liquid tape to repair. U can do this, don't give up to the repair buzzards. U already know about he fresh gas but also check the exhaust for any bug nests.
Good luck
wigs
Posted on Jul 21, 2010
Snapper tiller belt Model RT8015, been look for this belt for months, local dealer is a joke...
Best replacement parts site on the web. They might not have your particular model but they usually do.
Snapper Tiller Parts
Dec 04, 2017 | Snapper Garden
I have a snapper lawn mower that keeps blowing fuse when I try to start it.
Check all your wiring, I believe you have a shorted wire. GOOD LUCK FRIEND.
Apr 03, 2014 | Snapper Garden
Need wiring diagram for snapper mower model 260612t without electric star
don't have a diagram but i find the safety switch relay goes bad just disconnect it go right from the key switch to the engine just to test it of course also check the switch on the shifter handle
Apr 22, 2012 | Snapper Garden
I have a Snapper RT8 tiller that needs a new belt. What type and size of belt does it take and is there a schematic for routing the belt.
you need the model number on the tiller should be a tag on it somewhere and sometimes the serial number as well to get the right size
Oct 16, 2011 | Omega Rear Drive Wheel Snapper Mowers
I nee to wire my 1972 kawasaki 100 2-stroke motorcycle so it run
From the dynamo the current generated to induction coil armed with the appropriate capacitor, for relaying the current it via the distributor,(for timing of spark) high voltage/current, and distributed to each plug/Cylinder & called CDI ( Capacitor Discharge Ignition)..........seems the most practical solution I could come up with .
Hope this 1 sparks, fire's &/or a( no pun intended) thread.....................sodeep
Oct 26, 2009 | 1972 kawasaki Mach III H 1C
Tines stop under load
you have to get someone with a big tractor to "break" the ground up first. A tiller is just that...Not a plow
Jul 26, 2009 | Ryobi ZRRY46501 Factory-Reconditioned 12...
Item: Mantis Tiller Problem: wire to kill switch came loose from where it attaches under the cowling covering the engine. Question: where does it attach, I need to reconnect it
Hello:
The Shut Off Wire is Attached to the Ign Coil.
There is a Spade Lug on the Coil that the Wire Attaches to.
Hope this Helps.
Good Luck
Respectfully
John
May 10, 2009 | Mantis 2-Cycle Tiller
Ignition
I hope this diagram helps, it did me!
Mar 21, 2009 | 1972 Yamaha DT 360
Garden Logo
50 people viewed this question
Top Briggs Garden Experts
Mike
Renee Knafel-Bullock
Are you a Briggs Garden Expert? Answer questions, earn points and help others
