Electronic control panel is locked wont do anything!!!
2 Suggested Answers
SOURCE: control panel is locked
HOLD DOWN "clear/off"
Posted on Apr 24, 2009
The kenmore elite smart wash quiet pak 9 I opened the door and threw something else in and now a light is on thar says controls locked and it wont do anything
There should be a button on the control panel that says "open door" you need to push that button and wait for the washer to shut off before you open the door. Try pushing that button to see if that resets. My guess is that you broke the safety latch when you opened the door and it will need repair.
Mar 10, 2014 | Kenmore Washing Machines
The panel says control locked and the machine will not do anything
Press and hold the End of Cycle button for 3 seconds or until the Control Locked indicator turns off. Unplug the machine for at least 30 minutes to forcibly reset the control and to eliminate the possibility of an electronic glitch if pressing and holding the End of Cycle button does not work. Replace the control if unplugging and the pressing the End of Cycle button fails to unlock it.
Jan 13, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Control lock light on and wont start. basement is humid and not sure if that has anything to do with it
Are the controls locked ?? if so push and hold for three to four seconds the end of cycle signal volume button on right side of control panel.that will unlock the controls..If it still wont run you may have a blown thermal fuse...... Good luck hope this helps
Aug 22, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Washer lock
The Control Lock is a safety feature that allows the consumer to lock the control panel to prevent children from manipulating the controls and accidentally starting the appliance. This can usually be reset and usually is not an indication of an actual problem with the appliance.
With the lock on, the control panel is disabled and you cannot use any of the controls, except the button to unlock it. It can inadvertently be set following a power outage, leaning against the control panel, or pressing and holding the wrong button. This is usually not an indication of a malfunction.
If this is a Whirlpool manufactured appliance (such as Kenmore Elite, Maytag Epic or Whirlpool Duet), the following link explains how to lock/unlock this feature:
http://www.fixya.com/support/r3608801-control_panel_lock
These instructions are also printed on the front panel of the appliance and in the owner's manual.
If this does not correct your problem, then you may have a more serious problem than a simple operator control button issue (such as an operator console problem or main control board issue). Please post back and let me know if you need further assistance.
Jun 07, 2010 | Maytag EPIC MFW9700S Front Load Washer
"control locked" light is on washer
The Control Lock is a safety feature that allows the consumer to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance. This can usually be reset and does not require a technician.
If this is a Whirlpool manufactured appliance (such as Kenmore Elite or Whirlpool Duet), the following link explains how to lock/unlock this feature:
May 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet GHW9150P Front Load Washer: control locked light stays on ,wont let you do any...
Press and hold "end of cycle" button for 3 seconds, on the right side of panel. This is the child lock feature, do it again & it locks.
If helped, pl rate me good!!
May 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The control locked signal is on. and it won't let us do anything.
The Control Lock is a safety feature that allows the consumer to lock the control panel to prevent small children from manipulating the controls. It can inadvertently be set following a power outage, or by leaning against the control panel.
If this is a Maytag Epic, Whirlpool Duet, or Kenmore Elite, the following link explains how to lock/unlock this feature:
These instructions are also printed on the front panel of the appliance and in the owner's manual. If this does not correct your problem, then you may have a more serious problem than a simple operator control issue. If you need further assistance, please let me know. I hope this corrects the problem for you.
NOTE: If you cannot locate your owner's manual, you can download or print a FREE copy at managemylife.com. Just type in your model number under the "Manuals" link and you will find your manual listed in a .pdf (Adobe) format.
Jan 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Electric panel on stove is locked after a power outage everything else works fine, light and stove top, but panel to oven is not working at all it will not let you press anything
have you tried resetting the power to the complete stove by cutting the power to the complete stove and reconnect5ing after a few minutes, it might bring the normal operation to the clock and control circuit, I do not see any other component that would cause a lock up mode on the control panel other than the electronic circuit itself< AT ABOUT A HUNDRED DOLLARS IT MAY BE A GOOD IDEA TO HAVE A REPAIRMAN TAKE A LOOK>
Jan 14, 2010 | GE Spectra JBP78 Electric Kitchen Range
LOCKED UP AND WONT SPIN
POSSIBLE PUMP PROBLEM, REMOVE 3 SCREWS 7MM FRONT BOTTOM PANEL CLEAN OUT PUMP WHITE PLASTIC ,, THATS IT CLOSE IT BACK UP ...
Dec 31, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
