SOURCE: singer sewing machine will not zig zag
Over time, and especially when not used, there is a likelihood of dust and old oil forming a sort of glue, or clag....
Remove the needle for safety, then, when you have the setting on Zig zag, gently push the needle arm to the opposite side of the zig stitch.......release the needle arm, and if it springs back quickly, it is fine, if it moves slowly, or almost not at all, then the clag needs removing with application of few drops of methylated spirit to start, at the sort of piston affair that shifts needle arm L & R .....move the needle arm back & forth until it frees up, a drop of oil to finish.........if almost seized, may require leaving overnight after using a penetrating lubricant if it is really resistant....I have had them on the bench for 3 days with manual manipulation a few times each day before they finally come good.
Denatured alcohol is fine, surgical spirit too, different countries have different names or products, essentially alcohol with few impurities that will evaporate quickly with little residue.
Hope this does work for you, tho' as I said, it may take a little time to penetrate depending on severity........the same applies to the reverse mechanism of many machines when they seize.
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
SOURCE: Brother vx790, my stitches are reversed ( top is on botom & bottom is on top )
It sounds like your tensions are out of adjustment. Your upper tension should be between 3-5 and make sure the tension in your bobbin case is not too tight as well. Pull the thread through the bobbin case and make sure it comes out with a small amount of resistance. If no resistance, tighten the tension just a bit, if too much resistance, loosen it just a small bit at a time.
SOURCE: can't tighten clutch on Kenmore zig zag sewing machine.
The clutch has fallen off the shaft. Remove the very small screw in the clutch release screw to remove the clutch release. Place the clutch(round thing with ears on it) back on the shaft with the center ears pointing towards the outside. Put the clutch release screw back on. Tighten it to make sure it works
properly. Put the small screw back in the clutch release screw and test it again. If it will not tighten or release properly, remove the clutch ,rotate it180 degrees and try it again.This should solve your problem.
sewman7
SOURCE: Skipping stitches while zig-zagging
If you have put a new needle in then the chances are the machine has gone out of time, you can either take it in to the repair shop or you can contact me and I will attach timing instructions [email protected]
