Question about GE Refrigerators
Ge fridge icemaker not working
I just bought a nen side by side ge with icemaker and the water doesnt get cold and the ice maker is not working .do you have to wait more then 6 hours for it to work
  • GE Master
  • 4,654 Answers
Yes it could take ut to 12 hour or more for your refrigerator to stabilize. I takes 5 degrees in the freezer for ice production. Sea Breeze
Posted on Jul 25, 2009
GE Fridge water dispenser working but not the ice
Yes you most likely have a defective dual water control valve. Look around the inside of the refrigerator for a model number.
Click here=> For most locationsSide-By-Side
  • Top Freezer
  • Bottom Freezer
    Once you find the model number I will be able to tell you what part number the dual dual water control valve is or if your ice maker assist you in testing ice maker. If ice Maker is empty try filling with tap water to top edges of ice maker, allow water to freeze and if the ice drops into the ice bin but does not refill with water automatically I would say that the dual water control valve will need replaced. If your ice maker has old shrinking ice from a few days ago it will point to an ice maker problem.
    Thanks, Sea Breeze
  • Feb 10, 2012 | GE Refrigerators
    Bought house with frig in it not used for a while fridge works fine turned on water for ice maker water works does't make ice
    Is icemaker switch and light on? If so check for plugged fill tube. If not, the water valve or icemaker will need replacing.
    Sep 25, 2011 | Hotpoint HSS25GFT 25.0 Cu. Ft....
    I have a GE Profile fridge PSS25MGNAWW with an ice maker that is not working properly. The ice maker doesnt fill with water. If I turn the ice maker off then back on it will squirt water in for about...
    HI this is just a test the icemaker runs when you first turn it on, its not suppose to fill up the tray, it will fill it when the icemaker reaches the correct temperature, if its not cold enough in the freezer it wont kick on, if its been sitting for several hours and still wont fill or make ice, you need a new icemaker. The new icemaker part # is WR30X10093
    Sean
    Mar 30, 2011 | GE Freezers
    I have a PSS26 ge profile fridge and it quit making ice
    The icemaker is bad . You have an electronic icemaker and the internal boards cannot take the freezing and the heat (freezing moisture) . Just replace the icemaker .
    Jul 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
    My GE side by side fridge/freezer is working, water dispensing ok, but not making ice. I switch off the fridge, than ice maker but still not making ice. I try all the hints from Manual but no luck. Water...
    fill the ice maker with water manually, if you have ice in the bucket you know that the ice maker is working , after check the water valve if is opening , if it is replace main board
    Jun 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
    Freezer stopped making ice cubes
    If temps are ok, then be sure you ice ben is in properly. if that checks ok, check for water/ice in ice maker mold....Try turning unit off and then on in 5mins. this resets the ice maker...if that doesnt work, need to check for power at icemaker. good power means bad icemaker. no power means bad board.(usually) Would suggest you to have a cert GE Sercvice company look at it if no power to ice maker.
    Jun 09, 2009 | GE GSH25JFR Side by Side Refrigerator
    Ice maker not functioning
    maker you dont have a defrost problem could be water valve or icemaker
    Apr 05, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
    Icemaker
    IT DOESNT MEAN YOU GETTIN WATER IN THE WATER DISPENSER THAT THE VALVE IS OK.MOST FRIDGES ARE FITTED WITH TWO VALVES.CHECK THAT THE ICE MAKER VALVE IS WORKING IF THATS OK YOU MIGHT HAVE A PROBLEM INTERNAL ON THE ICE MAKER BEST YOU GET A TECHNICIAN TO CHECK THAT.GOOD LUCK.MOHAMED
    Sep 12, 2008 | KitchenAid Superba Architect KSCS25INSS...
    Ice maker part WR60x0202
    Your part number is for and auger motor. I believe the "pump" you are talking about is the water valve part#-WR57X10023 if the icemaker doesn't send voltage to the valve then it would need to be replaced part#-WR30X0327
    Sep 19, 2007 | GE Profile 26.6 cu. ft. Side-by-Side...
    Ice maker not working
    have you felt water in the ice maker or ice cubes thats the only way you know for sure.. just cause water in doors works doesnt mean icemaker getting water.. got different valves giving water to different places Is your freezer temp. right.. has to be right temp for icemaker to work.. check back wall in freezer make sure no frost buildup and if fan working
    Sep 02, 2007 | GE Profile PSW26P Stainless Steel Side by...
    Refrigerators Logo
    96 people viewed this question
    Top Refrigerators Experts
    Sal DeAngelo
    Charles T Nevin
    Charles T Nevin
    Andrew Taylor
    Andrew Taylor
