Trying to hook up with Bluetooth so I can use my new wireless speaker
When using wireless microphone for karaoke it cuts out on my Bluetooth speaker spa040. Any way to fix? When hooked up to my TV through USB port doesn't have any sound except through microphone.
Probably you're getting out of range with the Bluetooth for their other devices in your friends including your cell phone why don't you just hardwire what I mean by hard wire is connected directly or get a fully wired microphone the microphone to the unitthis will avoid the cutouts that Bluetooth often creates and when you hook it up to your TV I think you're doing that incorrectly because you're hooking the microphone up to a speaker out so then the sound out port so then microphone is becoming speaker which is not what you want to do
Mar 18, 2018 | Audio Players & Recorders
There is no bluetooth listed under my devices on my new Vizio D43-D1 tv. Can I connect it to Bluetooth speaker?
Unfortunately, you can't connect Bluetooth speakers to this TV. You can connect a wired sound bar, home theater sound system (receiver and speakers) or wireless headphones with a wired based station (RCA or digital audio input from the TV's audio out). These wireless systems use RF or Bluetooth signals to the headphones. See this page, http://stereodevelopment.com/#what-are-wireless-tv-headphones , for a few models of wireless headphones that will be compatible with the D43-D1.
I wish that I had better news for you. You may be able to find an audio receiver that supports Bluetooth. However, these usually are Bluetooth devices, the same as the Bluetooth headphones. They can't pair and send a signal to your headphones.
Feb 28, 2017 | Vizio Audio Players & Recorders
JBL Charge 2 stopped wifi connecting to pc
Problem connecting Windows 8.1 pc to JBL Charge bluetooth speaker ...
answers.microsoft.com/.../windows/.../windows8...connecting-windows...
When I try to connect the pc through Bluetooth to the above wireless speaker ... 2) What is the model of the JBL Charge Bluetooth speaker? ..... I am already able to play music from my iPhone 5 on this speaker via Bluetooth with no problems.
Cannot connect JBL Charge Bluetooth - Networking, Internet ...
en.community.dell.com/support.../network...wireless/f/.../t/19525571
Dell
Sep 22, 2013 - 16 posts - ‎11 authors
23 Replies; 16 Subscribers; Postedover 2 years ago ... I'm trying to connect my JBL Charge Speaker bluetooth with my Dell Studio 15 laptop to listen .... I am having the same problem, did you find a fix for this? ... not support audio output, then you need to add a Bluetooth adapter which includes a CD driver.
JBL Charge 2 ' Portable Bluetooth Speaker with USB Charger
www.jbl.com > Wireless > Portable Bluetooth Speakers
JBL
Rating: 4.3 - ‎110 reviews
Most popular JBL Charge 2 wireless portable speaker can charge any devices via USB... You can easily connect Charge 2 to any Bluetooth-enabled device by giving the portable's ..... Charge with proper charger or a USB port form computer.
Jan 28, 2016 | JBL Audio Players & Recorders
Can find Bluetooth on my Toshiba Satellite laptop .
Since the Toshiba Satellite uses Windows it will not recognize Android. But speakers shouldn't "have an operating system". In any case your computer does not support Bluetooth. If you can get a Bluetooth adapter that will plug into a USB port, you should be able to run the speakers. Lesson: don't mix mutually exclusive wireless devices. Second lesson: Buy wired speakers with their own amplifiers and run them through your headphones. That is always foolproof.
Dec 11, 2014 | Toshiba Satellite Computers & Internet
Great sounding speaker, but nothing but trouble with the bluetooth. It appears that I can only have one device paired at a time. In order to connect another device, it breaks the current pairing. A
Yes this is a 'feature' of Bluetooth. (I have never seen the point of Bluetooth... Wi-Fi does everything it does, but better !)
It DOES usefully enable a phone or tablet to play though headphones or speaker and to use a headset 'cordlessly'...
Consider instead a 'Bluetooth Receiver' (under US $10 from China) connected to a FM Stereo Bug (Transmitter) - Then you can use any number of quality FM Radios (including phones with built in FM) up to 50 metres or so away...
example: http://www.ebay.co.uk/itm/Wireless-3-5mm-Stereo-Audio-Adapter-A2DP-Bluetooth-Dongle-Transmitter-Receiver-/141227224470?pt=UK_Home_HomeDecor_Accessories&var=&hash=item20e1cc6d96
Dec 10, 2014 | Marshall Stanmore Bluetooth Speaker
How to get bluetooth speaker to connect already apired and is showing but wont connect
Hello, I have already met this issue: after pairing a bluetooth speaker on a first host (computer or iPad), then pairing it on a second device (as another computer for example), when I try to pair it again to its original host device, it doesn't work.
The solution consist in
1) on the host computer, in the list of the Bluetooth devices, delete the line of the bluetooth speaker and forget this bluetooth device,
2) push on the Bluetooth detect button on Bluetooth speaker,
3) scan the bluetooth devices on your computer host, and when you see the bluetooth speaker in the list, select it.
Jul 28, 2014 | Toshiba Satellite Laptop with AMD Athlon...
Connecting big blue speaker to LCD tv
How do you hook up the big blu speakers to your television
Oct 26, 2012 | Brookstone Big Blue Live Wireless...
Want to hook uo bluetooth
First switch on bluetooth (settings---bluetooth).
Start > Settings > Communications and Add new Bluetooth headset. htc will search bluetooth headsets and find it. it will ask you to enter bluetooth passcode, usually it is 0000. then finished and you have paired Bluetooth headset with HTC
Mar 26, 2010 | HTC Cell Phones
How to setup bluetooth external speaker on Dell Studio 17 laptop
Ensure Bluetooth is installed and on in the notebook, then turn on the Bluetooth speakers, they should be detected by the system, then pair the devices in bluetooth manager.
Sep 13, 2009 | Dell Studio 17 Laptop
I'm trying to connect my computer to my Sansui A3100 receiver so that I can listen to my computer music via my speakers which are also hooked up to my receiver. Everything is hooked up correctly. Can you...
I would connect the computer directly to the speakers not the receiver to confirm the impedance is compatible. Connecting via the receiver complicates the issue.
Which output channel are you selecting on the receiver.
Oct 12, 2008 | Sansui Audio Players & Recorders
 Grubhead
Grubhead
