I would like to hook up to Bluetooth so I can use my wireless speaker....having many, many problems.....please help..thank you...
JBL Charge 2 stopped wifi connecting to pc
Problem connecting Windows 8.1 pc to JBL Charge bluetooth speaker ...
When I try to connect the pc through Bluetooth to the above wireless speaker ... 2) What is the model of the JBL Charge Bluetooth speaker? ..... I am already able to play music from my iPhone 5 on this speaker via Bluetooth with no problems.
Cannot connect JBL Charge Bluetooth - Networking, Internet ...
Sep 22, 2013 - 16 posts - ‎11 authors
23 Replies; 16 Subscribers; Postedover 2 years ago ... I'm trying to connect my JBL Charge Speaker bluetooth with my Dell Studio 15 laptop to listen .... I am having the same problem, did you find a fix for this? ... not support audio output, then you need to add a Bluetooth adapter which includes a CD driver.
JBL Charge 2 ' Portable Bluetooth Speaker with USB Charger > Wireless > Portable Bluetooth Speakers
Rating: 4.3 - ‎110 reviews
Most popular JBL Charge 2 wireless portable speaker can charge any devices via USB... You can easily connect Charge 2 to any Bluetooth-enabled device by giving the portable's ..... Charge with proper charger or a USB port form computer.
Jan 28, 2016 | JBL Audio Players & Recorders
I have an emachine ez1711 set up as a jukebox and was wondering if there was I way I could play the music through Bluetooth or any other way to an external speaker wirelessly. Thanks in advance.
1. Bluetooth option: need to buy a USB Bluetooth adapter (make sure it supports Bluetooth A2DP profile and (optional) AVCP profile and Bluetooth speaker or Bluetooth headphones (or both speaker and headphones). I have to warn you that finding a Bluetooth adapter that works with yor computer may not be an easy task.
2. Regular wireless headphones (no speaker). Attach the transmitter piece to your jukebox's headphone jack and listen through the headphones from anywhere in your home.
Dec 30, 2014 | Cell Phones
Can find Bluetooth on my Toshiba Satellite laptop .
Since the Toshiba Satellite uses Windows it will not recognize Android. But speakers shouldn't "have an operating system". In any case your computer does not support Bluetooth. If you can get a Bluetooth adapter that will plug into a USB port, you should be able to run the speakers. Lesson: don't mix mutually exclusive wireless devices. Second lesson: Buy wired speakers with their own amplifiers and run them through your headphones. That is always foolproof.
Dec 11, 2014 | Toshiba Satellite Computers & Internet
How to get bluetooth speaker to connect already apired and is showing but wont connect
Hello, I have already met this issue: after pairing a bluetooth speaker on a first host (computer or iPad), then pairing it on a second device (as another computer for example), when I try to pair it again to its original host device, it doesn't work.
The solution consist in
1) on the host computer, in the list of the Bluetooth devices, delete the line of the bluetooth speaker and forget this bluetooth device,
2) push on the Bluetooth detect button on Bluetooth speaker,
3) scan the bluetooth devices on your computer host, and when you see the bluetooth speaker in the list, select it.
Jul 28, 2014 | Toshiba Satellite Laptop with AMD Athlon...
Iphone won't detect bluetooth
It's probably not the speaker, your phone is not recognizing the device. This is the link How to troubleshoot Bluetooth Connections from Apple:
Dec 25, 2013 | Brookstone Big Blue Live Wireless...
Want to use a wireless speaker via bluetooth. How do u turn on the bluetooth? I push the FN, and F3 and get 'no device'. I need to 'pair' the speaker (HMDX Jam Wireless). Well, help
Does you laptop have Bluetooth? Open start menu, search, type Buletooth, Does it come up? OR, Open Device Manager, Network Adapters, is Bluetooth adapter listed? OR, Open Services, do you see Bluetooth? If you find the Bluetooth Software, open Settings.
Feb 06, 2013 | Acer Aspire One PC Notebook
I am trying to connect my T305 portable bluetooth car speaker phone to work with my iPhone 3G, but I keep getting Motorola T305 not paired What should I do?
Hold the power button in on the speaker system until the indicator light turns purple. Have your Iphone scan for bluetooth devices and select the T305. The first time it connects it will ask for a security key which should be 0000. If that doesn't work try 1234 as well.
At that point it should pair successfully and you should be good to go.
Please leave feedback if you found this helpful. Thanks.
Mar 25, 2011 | Motorola Mobility Bluetooth Hands-Free...
Ps3 at v3.15, sony headset paired but cannot get speaker on tv
Go to the Audio Settings above the Bluetooth setting and change the Audio output to "wireless headset"...
Jan 10, 2010 | Sony Bluetooth Wireless Headset for...
I'm trying to connect my computer to my Sansui A3100 receiver so that I can listen to my computer music via my speakers which are also hooked up to my receiver. Everything is hooked up correctly. Can you...
I would connect the computer directly to the speakers not the receiver to confirm the impedance is compatible. Connecting via the receiver complicates the issue.
Which output channel are you selecting on the receiver.
Oct 12, 2008 | Sansui Audio Players & Recorders
26 people viewed this question
