Question about Zenith Televison & Video
Hooked up Zenith VCR model UR4255HF. I will not play forward but will reverse.
    Top Expert:
  • Zenith Master
  • 12,962 Answers
The drive belts have stretched and need to be replaced for unit to work properly.
Posted on Apr 30, 2017
I replaced my TV and now my VCR Zenith Model 2100 will not record
Digital TV can use component video and stereo connections to record on analog VCR. Analog VCR needs DTV converter to record digital TV channels. VCR play back use AV channel on TV.
Feb 11, 2012 | Zenith Televison & Video
I have just bought a second hand good condition Phillips VR Video Machine. I can play tapes, eject, reverse and forward on the machine itself, but the I can't track, get menu, reverse, forward or play...
The chances are that the person who supplied it to you gave you a Phillips remote for another VCR. Many makers remotes will work parts of a different model of the same firm, but only the true remote will operate ALL functions.
If you have the user manual check to see if it list the part number of the remote. If you don't have it look around the net for Philips VR630 remote. See if it matches yours. If it doesn't you will have to replace it.
Nov 01, 2010 | Philips VR630 VHS VCR
DVD disc reads that it is playing, but there is no
what tv connection are you using from the dvd make sure connection are fully pushed in, try another dvd player with the same tv and connections.
Aug 25, 2009 | Zenith XBR616
My Zenith VCR is not working with the digital converter box
When the VCR is "off" the converter signal should go right through the box, which you say it does. Then, when you turn the VCR "on" the picture disappears. That, so far, how it should be. To get your picture back while the VCR is "on" you must set the VCR to "receive" channel 3, and use your new converter box to change channels...accordianman
Dec 16, 2008 | Televison & Video
Tv/digital converter box & vcr-dvd hook-up
ok cable sat wire goes into input of dvd-vcr input then coming out from the dvd vcr and into the moulator then a wire out to the tv now make sure your vcr is set to the right setting you can record 1 cable..2.vcr dvd..3 make sure vcr is set to monitor
Dec 04, 2008 | Philips Magnavox DVD/VCR Dual Player
I have a vhs and dvd player all in one
I have a converter box hooked up to my tv and vcr , dvd player combined
I can play my movies on the tv. ok.
you have to have your tv and vcr set on channel 3. if that is what your main tv is set up with. Or 4 if you have your tv set up with that.
Mine plays ok. My settings are for channel 3
My suggestion would be to check your hook ups. maybe they are not hooked up correctly
I had to go to and did searches to help with hook up.
I can also record station I am watching with vcr on vsh tapes. I do not have a dvd recorder.
I found out that you have to have 2 converter boxes hooked to one tv., in order to record on on station while watching another. I have not tried that, as I don't have 2 converter boxes for one tv. I found that by doing google search also. Good Luck
Dec 04, 2008 | Televison & Video
VCR won't record
Check to make sure the cables on the VCR are hooked up correctly. If the in and out are reversed, this might cause your problem. Hopefully it's as simple as that. if not leave a comment and I'll get back to you.
Oct 03, 2008 | Quasar VHQ400 VHS VCR
Usaly there is a button on the remote for input but if you do not have that you might try changing chanels below chanel 1. Some Goldstars hide the front input down there
Mar 03, 2008 | Goldstar GVR-DD1 VHS VCR
Only plays picture when fast forward.
Cleaning or video head replacement time....accordianman
Feb 11, 2008 | Zenith VRB420 VHS VCR
Video noise at bottom of screen
Try adjusting the tracking on your VCR. This symptom would typically be caused by a slight tracking error in your VCR or video heads that need to be cleaned. Your Zenith TV may be a little more sensitive to video synchronization problems than your other TV is.
If VCR tracking adjustments have no effect on the symptom, then the problem could be in the TV, but I'll need more details to assist you with troubleshooting. For example, how do you connect the VCR to the TV?
Jan 27, 2008 | Zenith B27A11Z 27" TV
Televison & Video Logo
29 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
