What do I enter to get to taskbar so I can go to Bluetooth?
Dell E5410 bluetooth not ditecting
Hi Ratnayake RM,
your Dell E5410 is a superb machine. I am telling you some ways to fix the Bluetooth issue. , (assuming you're using Windows 7) if the Bluetooth drivers are installed, then you can right click on the Windows Taskbar, select Properties from the pop-up menu, now in the Taskbar tab's Notification Area select Customize..., see/make-sure that the Bluetooth Icon can be displayed on the Taskbar. After that (assuming that it hadn't already been visible on the Taskbar), you should be able to enable/disable Bluetooth from its System Tray Taskbar icon.Head into Device Manager and check to see if the bluetooth drivers are installed. I'm guessing you are using Windows 7, so go to the stat menu, right-click 'Computer' and press 'Manage'. This will open the Computer Management window, from here click Device Manager on the left coloumn. There should be a Bluetooth Radios drop down menu.
If that is there and there are no question marks next to the items, it means the bluetooth drivers are installed and it should be working. You should also see some bluetooth items under the Network Adapters drop down.
If you cant see the Bluetooth Radio's drop down, it may be because the drivers arent installed. If that's the case, the radio should be listed somewhere down the list with a question mark next to it. Go to the manufacterurs website and find the drivers for the bluetooth module and that should fix it.
OR
Have you tried pressing Windows Key+X? It brings up the Mobility Center in Windows 7. Your Bluetooth may be off or something.
Try these ..these will surely help you
May 31, 2016 | Dell Computers & Internet
Tip
How do I remove a Bluetooth Taskbar?
<p>The taskbar at the bottom right of the computer screen displays the status of most device applications, including Bluetooth functions. This toolbar programs are usually those who have always, even running in the background. You can select the Bluetooth icon, or to delete another icon on the taskbar if you still want to use the function without seeing it. <br /> <p><br /> <p>1. Click the Start menu and Control Panel. <br /> <p><br /> <p>2. "Bluetooth" type in the search field at the top. Click open "Bluetooth Settings." <br /> <p><br /> <p>3. Uncheck "Show the Bluetooth icon in the system." <br /> <p><br /> <p>4. Click "Apply" and "OK" to save the settings and exit. <br />
on Jun 26, 2011 | Computers & Internet
I have internet connection but cannot access internet
Bluetooth connections allow devices to connect without the use of wires or cables.
Some users of the Sony Vaio laptop computer have encountered problems with the connection of Bluetooth devices with their computer.
The problem lies with turning on the Vaio's Bluetooth function.
This is turned on through the computer's Wireless Switch Settings manager.
The icon for this is in the system tray in the taskbar when the computer is first purchased.
Double-click the "Wireless Switch Settings" icon in the system tray of the taskbar.
It is a a blue-green icon with "LAN" in one corner and "B" in the other.
Check the "Enable Bluetooth Device" setting in the Bluetooth Device section.
Click "OK."
If the device was already enabled, change the wireless LAN from "2.4GHz" to "5GHz" because, as the warning message should say, using the 2.4GHz wireless LAN and the Bluetooth device can make the connection unstable.
Click the "Apply" button after the appropriate boxes are checked to activate the Bluetooth signal. A blue light should come on near the computer's on/off switch for the Wi-Fi radio.
Click "OK." Another dialog box should appear explaining that the Wireless Switch Settings icon should now be in the taskbar.
Use this icon if you need to turn off or on the Bluetooth device in the future.
http://supportforsony.iyogi.com/vaio-f-series/bluetooth-4.html
sony support
Apr 15, 2014 | Sony Vaio Tap 20
Usb dongle is not working
Step 1:
A Bluetooth dongle is an external Bluetooth device used to enable your PC's Bluetooth connection. Many Bluetooth dongles come without installation disks since the software is pre-programmed into the actual USB stick. These Bluetooth dongles are very useful on netbooks that don't have Bluetooth connection, since netbooks have no CD-Rom drives. Turn on your PC. Insert the USB Bluetooth dongle into the USB port on your desktop tower, or the USB ports located on the perimeter of your laptop. Wait for the program to auto run. Once you connect your dongle, the driver program should launch. Follow the onscreen prompts to install the dongle. A dialogue box should open that says "Installing Drivers" from the taskbar. Allow the driver to install completely before closing the box. Unplug the dongle and restart your PC. Once the PC has been switched on, insert the dongle. Double-click "My Bluetooth Places." This is the Bluetooth icon located in your taskbar, and it should launch the "Initial Bluetooth Configuration Wizard." Click "Next" on the first screen. Next, type in the name of your computer and select your computer type from the drop-down menu, then click "Next." Click "Skip" on the onscreen prompts, then finish. Pairing the Devices Turn on your external Bluetooth device. Double-click "My Bluetooth Places." Select "Find Bluetooth Devices." The name your Bluetooth device should display in the next window. Right click the icon for your Bluetooth device, and scroll down to "Pair Device." Enter the Bluetooth pin code for your external device in the "Bluetooth Pin Code Request" pop-up window. Then click "OK." The default pin code is normally "0000" or "12345." You can find your pin code in your user manual. If you are pairing a cell phone to your PC, you will have to enter the same pin code on your cell phone to establish the Bluetooth connection.
Apr 10, 2013 | Computers & Internet
I can not connect to samsung mobile to my laptops by bluetooth why
ensure you have installed bluetooth driver, turn it on, on the right below corner taskbar should appear bluetooth icon, right click it then add device, turn on your mobile bluetooth, the laptop should search for new bluetooth device, enter the passkey when given by laptop on your mobile, wait for awhile for adding new services
Good luck
Feb 03, 2011 | Samsung Computers & Internet
I am using Acer Aspire 3500. I have a bluetooth button next to my Lan button. The Lan works but the bluetooth says on screen 'no device'. There is a blue tooth symbol next to clock on taskbar on screen...
In order to use the Bluetooth connection, you have to have a Bluetooth device to pair with your computer. Put the device in pairing or listening mode, then right click on your Bluetooth icon and choose the option for searching for a device. (You may be required to enter the device's passcode -- if you don't know it, try 0000.)
Dec 27, 2010 | Acer Aspire 3100-1405 Notebook
My laptop have got a build in bluetooth but i dont know how to connect it please help
hi
  • Open your computer's Control Panel center to access your Bluetooth Device settings. Click on the Windows icon or the "Start" icon on your computer desktop's taskbar at the bottom of the screen. When the pop-up menu opens, click on the "Control Panel" link.
  • Step 2 Access your Bluetooth Device settings. When the Control Panel opens, click on the settings link that reads, "Bluetooth Devices." This link will display all of the possible actions and settings you can take regarding your laptop'smag-glass_10x10.gif Bluetooth technology.
  • Step 3 Configure your laptop's Bluetooth technology. Select the "Start the Bluetooth Device" action. The blue and white Bluetooth icon will appear in the Windows System tray within the computer desktop's taskbar.
  • Step 4 Network with another device in order to import and export files. Double-click on the blue and white Bluetooth icon on your computer desktop's taskbar. A Bluetooth dialog window will appear on your screen displaying your Bluetooth technology portal. Click on the "Add Devices" action. You will then be asked if your laptop would like to search for other compatible devices. Click "Next" to proceed. You will be prompted to choose a passkey for the pairing. Create a simple passkey and click on the "Pair" option. When the notification is received by the other device, enter the same passkey to pair the device to your laptop.
  • Jun 20, 2010 | Acer Aspire 5500 5570-2609 Laptop
    Bluetooth on samsung nc10 netbook
    go to control panel then open printers or other hardware then hola you can see your bluetooth icon and check the show the blluetooth icon in the notification area or if you'd check the two boxes on the option tab and connection area then try to connect thru bluetooth device so you'll see the bluetooth icon on the taskbar.
    Nov 09, 2009 | Samsung NC10-14GW Notebook
    Sony VAIO FE690P Bluetooth device doesn't work.
    Before doing anything whit the bios, try this if you havent alredy
    Turn on the wireswitch in the front of your laptop
    Double-click on LAN/B icon on the taskbar to display the wireless device switch window
    Select the eneble bluetooth device option
    Click OK and try if it works.
    Yuo dont see the B in your taskbar cos it isent activate
    Good luck to you
    BTW, if you vae installed diferent drivers, i sugest you uninstall them and install back the original ones
    Dec 11, 2008 | Computers & Internet
    How to install games in smg e250
    1) Download SoftickPPP and Samsung Java Uploader.exe from here. Also JADmaker if required.
    2) Install SoftickPPP according to this Polish website. I don't understand Polish, but the pictures tell enough of the story. Set up your bluetooth COM ports in the SoftickPPP bluetooth/serial settings. My Bluetooth COM ports are either 24, 25 or 26. I leave them all ticked.
    3) Enter *#52828378# on the phone to access the Java Test Menu. Choose OTA type setting, choose Serial bearer OTA. Click select. (This seems to need to be changed back to GPRS bearer OTA for Samsung PC Studio to connect)
    4) Start SoftickPPP. Click on cancel for the missing USBPort.dll error message. Accept bluetooth connections for DUN and Serial connections on the phone.
    5) Choose 'Activate PPP' by right clicking on the icon in the taskbar. Accept connections on phone again.
    6) Start 'Uploader.exe' and then add the required jad file. Leave the program open.
    7) If you are not still in the Java Test Menu then enter *#52828378# on the phone again. Select 'Serial test', 'PPP Up', 'Bluetooth' on phone, 'Serial download'. My phone sometimes restarts at this point in which case I have to choose 'Shutdown PPP" in the taskbar icon and then re-activating it once the phone has restarted and then re-do step 7 after entering the Java Test Menu again.
    A Java splash screen should appear with a progress bar showing the upload of the file. The game then starts automatically.
    There we go. It works for me
    Aug 16, 2007 | Samsung SGH-E900 Cellular Phone
    Computers & Internet Logo
    David Payne
    David Payne
